Old 09-29-2009, 10:20 PM   #10921
geeunit1014's Avatar
I just take the top plate off, and take the spur gear side layshaft cam off. no diff needs to be removed
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-29-2009, 10:27 PM   #10922
pakk's Avatar
Trader Rating: 79 (100%+)
so do I, but these guys have different rear bulkheads that require one bulkhead be removed.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 09-29-2009, 11:26 PM   #10923
Scottmisfits's Avatar
I haven't really paid much attention to this thread as I am an offroader in the summer. What's the benefit of flipping the belts? What's needed to do it or is it literally just flipping the diff's and the layshaft? Will the oneway still work with flipping the belts?
Scottmisfits is offline   Reply With Quote
Old 09-30-2009, 04:14 AM   #10924
Redwood's Avatar
I flipped my belts because of the 'new improved' bulkheads I bought. With these bulkheads I found the pinion interfered with the belt, so I switched them around to solve that problem. You simply swap the belts over and flip the diffs, easy. As a bonus it is also much easier to change pinion now with them flipped. Downside is that you cannot use a one-way without modifying it, you basically have to switch which side the pulley sits on the one-way and them shim it out to the correct position, there are pictures earlier in the thread, no idea where though.
Regards
Neal
Redwood is offline   Reply With Quote
Old 09-30-2009, 04:16 AM   #10925
Redwood's Avatar
Originally Posted by Nick Priest View Post
My tc5r now for sale, after a good 8 months run I fancy a change of car and a rest from Tc driving for a while
Team Associated Tc5r + Spares
Hey Nick,
I see that you use the TRF shocks on the TC5, I was considering this too, my car doesnt really handle the bumps as well as I would like.
My question is, what adjustments to the mounting brackets for the TFR shocks need to be made? Can I use the ballcups and upper mounts from my current TC5 shocks?
Cheers
Neal
Old 09-30-2009, 04:16 AM   #10926
defcone's Avatar
Trader Rating: 15 (100%+)
You can also mod it so you can have your servo perpendicular to your chassis, if you're using a lpf servo you will have much more room for your electronics.
defcone is offline   Reply With Quote
Old 09-30-2009, 08:40 AM   #10927
Originally Posted by Redwood View Post
Hey Nick,
Cheers
Neal
On my car, I got the tamiya ball ends for the shock tower mount, as the AE ones are ever so slightly larger (you can still use them I think, but you egg out the plastic peice quickly), and I used the AE shock ends, so the only thing you need to get is the tamiya ball ends for the shock tower. HTH
Mike Gee
Old 09-30-2009, 10:02 AM   #10928
Suspended
Hey Nick,
Cheers
Neal
I use the tamiya ball ends in the wishbone and standard associated mounts on the shock tower, fit's perfect
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 09-30-2009, 10:11 AM   #10929
Suspended
Default TC5R Mods.
Hey guys just wanted to post this up here. I was able to carefully grind out my factory motor mount, move it inline with rear bulkhead, flip my belts (which made pinon change easier as well as allow for more centered weight), and moved my servo like Keven's car! I noticed a big difference while balncing the car left to right. I was able to put weight where I WANTED it as opposed to where I NEEDED it! Big Difference! If anyone would like more pictures I will post them! Let me know!
BOSS RC MOTORSPORTS
Horsham Rc; Horsham, PA
Trains and Lanes Raceway; Easton, PA
Jackson RC; Jackson, NJ
X_________________________________________________ _Nathan "Nate" Laskey
Quiet Storm is offline   Reply With Quote
Old 09-30-2009, 11:06 AM   #10930
Castradamus's Avatar
Trader Rating: 52 (100%+)
I would like to see pics with the motor out
Destiny | Xenon USA | SpeedzoneUSA.com | TQ Wire | NAO | dIgItS pAiNt
He who is not courageous enough to take risks will
accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 09-30-2009, 12:18 PM   #10931
Suspended
Default Motor's Out
Here you go!
BOSS RC MOTORSPORTS
Old 09-30-2009, 12:21 PM   #10932
Suspended
If you notice the top plate screw on the left bulkhead it has been screwed through the top plate, the bulkhead, then finally into the motor mount. Giving the motor mount three points of contact. After I was finished I put the car on a tweak board and all was well!
BOSS RC MOTORSPORTS
Old 09-30-2009, 12:33 PM   #10933
Trader Rating: 38 (100%+)
At the rate in which everyone is moving to the Exotek chassis and modifying/buying new bulkheads perhaps Associated should investigate making a TC5R-LS (lipo spec).
Changes could be:
-Narrow rear bulkheads
-New chassis (narrower, modified for new bulkheads, lipo weights included, optional holes for the Keven servo mod)
-New upper deck for the narrow bulkheads
-Revised one-way in which the pulley could easily be mounted for a flipped belt configuration
-Revised steering to optionally allow for Keven servo mod
-Anything else?
Other changes could include:
-More flexible belts??
Seems like it could even be offered as an upgrade kit.
or8ital is offline   Reply With Quote
Old 09-30-2009, 08:37 PM   #10934
Mark506's Avatar
Trader Rating: 41 (100%+)
How did you do the servo mod? Can you give me steps? Im looking to do it in mine. Thanks
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 09-30-2009, 09:41 PM   #10935
hollywood tc5's Avatar
nice do you want an award
jk looks good brother set it as you avitar
BOSS MOTORSPORTS
wrecking ball,sox,hollywood
BOSS MOTORSPORTS
hollywood tc5 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
