Old 09-20-2009, 11:12 PM   #10861
Originally Posted by spam77 View Post
Hi,
Anyone run an LRP SPX (mode 6 or 7) and an Epic Duo 2 (17.5) brushless?
I'm looking for an FDR starting point for medium traction asphalt track. Any help would be very appreciated.
I was using 3.69 with a Novak Havoc 17.5 system... but was told this may be too low for the LRP/Duo2 and it might burn it up.
Thanks!
-AJ
I would try somewhere between 4.7 and 4.3. One of the people I race with went from 3.5 to 4.3 with a SPX on 7. But this is also on a very large track that is on the side of a hill.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 09-21-2009, 06:57 AM   #10862
Gain Time's Avatar
Originally Posted by Murray View Post
So would you recomend buying a "TC5F" and switching out the chassis and the top plate for rubber tire?
Way cheaper to buy the Rubber kit and the hard parts.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 09-21-2009, 07:03 AM   #10863
Warren Weaver's Avatar
Trader Rating: 43 (100%+)
I run the tc5f on asphalt with no handling issues very fast you just have spring the car softer and it works great.
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 09-21-2009, 12:22 PM   #10864
Scooter79rs,
Thanks!!! Much appreciated!
spam77 is offline   Reply With Quote
Old 09-21-2009, 07:30 PM   #10865
Thats why I got the FT, one I got it before the price hike (TC5 kits went up by $70-$100) and two I already had the soft springs from my TC4. All I've done is got the ITF top deck and the car is awesome to drive on low bite ashphalt.
My FT drives just as well as my R, but seriously if you're racing ashphalt just get the ITF top deck and you'll be fine, the ITF chassis does make a difference but not enough for me need change the FT chassis to an ITF one.
Old 09-21-2009, 07:36 PM   #10866
revo61's Avatar
Trader Rating: 18 (95%+)
+1 I do the samething.
My FT drives just as well as my R, but seriously if you're racing ashphalt just get the ITF top deck and you'll be fine, the ITF does make a difference but not enough for me need change the FT chassis to an ITF one.
JQ The Car White Edition/Reds R7E/Reds 2113 pipe
Airtronics MT4/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM /WWW.DIALEDHOBBIES.COM /WWW.TALLAHASSEERC.COM
revo61 is offline   Reply With Quote
Old 09-23-2009, 04:42 AM   #10867
anybody have any good low grip(pollen covered large track) ft tc5f non additive brushless lipo setups,lrp sxx tc,40c trinity 5000mah,lrp x12 4.0
tamiya_008 is offline   Reply With Quote
Old 09-23-2009, 06:50 AM   #10868
Try this, it should put you in the ball park. I haven't raced this setup yet as I've just started using it for Super Stock (10.5) I just haven't had a race meet yet, but it has had a good days practice against other cars.
Old 09-23-2009, 10:11 AM   #10869
MikeR's Avatar
Trader Rating: 14 (100%+)
Hi,
Thanks!
-AJ
Depends on how hot your track is but start with 4.0. Temp the motor after 3 min and adjust FDR from there. Max motor temp should be about 150. Fan is a must or the motor can fade at the 3 min mark. If the motor feels like cogging a little then gear down or turn the profile down a few clicks. SPX is a beast
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-23-2009, 03:49 PM   #10870
A buddy is running the SXX with 17.5 motor with 41/70 - 3.41 FDR.
Motor comes off super hot (190-210) and ESC/batt is cooler. Most other guys in the class are claiming to be running 3.5 FDR and I need to compete. Buddy thinks I should start where he is at but do not want to burn up motors....what do you all think I should run?
Small to med track asphalt
ATX
bohdi is offline   Reply With Quote
Old 09-23-2009, 06:33 PM   #10871
geeunit1014's Avatar
A new ESC will make the biggest difference. Get a Tekin RS or a SPX, and your car will really come alive , and you wont have to gear as high, and then you should run cooler as well. With the new tekin firmware (200 vs 198), ive noticed about a 20* drop in temp with 13.5, because the timing advance lets you gear lower. Should see similar results in 17.5. Like MikeR said, you will probably want a fan in 17.5 anyway, and that will help with temps
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-23-2009, 07:16 PM   #10872
I would start at 3.5/3.6 When I was using a TC Spec I was at 3.5 this was one a very large open track that was designed for nitros and 1/5th's. But if you track is flat you may get away with 3.4.
On my TC Spec I was geared at 3.5 with my Tekin RS (v200) I'm geared at 4 and is much faster then the TC Spec.
Old 09-23-2009, 08:03 PM   #10873
my question is why the motor is so hot compared to ESC and batt...I thought that meant it was under-geared? I have seen him burn up 2 motors geared his way...190-210 was an estimate...it was smoking hot!
I run off road 10th and 8th scale electrics and none of my motors get over 160.
ATX
Old 09-23-2009, 08:08 PM   #10874
revo61's Avatar
What kind of timing is he running? It should not be that hot. Either he is running a lot of timing or he has his brakes at a high setting and is using them a lot.
Old 09-23-2009, 09:01 PM   #10875
It's the hacker E40 17.5...I did not know it had adjustable timing so I am a bit unsure
ATX
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
