Old 09-17-2009, 06:08 AM   #10831
Trader Rating: 38 (100%+)
Originally Posted by MUDVAYNE View Post
If you're able to make it next Wednesday night, or maybe even sometime this weekend, I'll show you what I'm talking about.
I'm on vacation next week so I will be there on 9/28 to pick up the TC5 I ordered. I'll check it out then. I have a feeling I will end up just flipping the belts anyway. Looks like mounting and shimming the pulley on the opposite side for the one-way will work fine if I need to run a one-way.
or8ital is offline   Reply With Quote
Old 09-17-2009, 09:03 AM   #10832
Rick Hohwart's Avatar
Originally Posted by geeunit1014 View Post
Which servo horn are you using?
I use an RC8 throttle servo horn. I use the second hole on the short side. and remove the long side.
I wonder how they are getting around the whole pinion hitting the belt issue like I have right now.
I cut the end of the motor shaft off. If you reverse the belts you don't have to modifiy the shaft. I am almost certain that you can use the Exotek center pulley mount that lowers the assembly. This might give you enough clearance so the motor shaft does not interfere with the belt.
Originally Posted by or8ital View Post
What are you referring to? Are you saying associated created some new bulkheads?
The pieces are a stock bulkhead and motor mount that have been machined so that they "key" together. Holes have been re-drilled for the new motor mount location and the opening for the motor enlarged.
Not sure who's car that is. They have something interesting going on with some extra ball studs on the shock towers as well.
It is my car. The extra ball studs have worked on rubber carpet in the past with good results. I also played with them at the '09 Reedy Race gbut ultimately ran the standard setup. My car is right at the minimum weight so I leave then in so it is easy to try them easily.
Also in the pic but hard to see is our new LiPo battery retainer. This mounts using the battery post holes and moves the battery in so that the inner battery socket is accessible. The retainer has a place for the ballast (brass in my case) to balance the car and bring it up to the minimum weight. In my case the brass adds about 80 grams which balances the car left to right and leaves me 3-5 grams under the minimum weight.
Rick Hohwart is offline   Reply With Quote
Old 09-17-2009, 09:09 AM   #10833
jag88's Avatar
Will AE being releasing these parts seperatly or will there be an updated TC5 coming ?
Thanks.
jag88 is offline   Reply With Quote
Old 09-17-2009, 09:13 AM   #10834
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 47 (100%+)
Rick- Would the IIC setups be a good place to start for a Vintage Trans Am car using a FT chassis?
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 09-17-2009, 09:35 AM   #10835
Thanks.
Info about the LiPo retainer will be released shortly. I am working on the other items. There will not be a new car anytime soon.
Yes I would start with Keven's.
Old 09-17-2009, 09:47 AM   #10836
John_S's Avatar
How did you support the motor mount at the back when you moved it inline. I know there is a tab at the front but did you just drill a hole up and tap the bulkhead and put a shim inbetween them? Also did you screw it to the topdeck?
John_S is offline   Reply With Quote
Old 09-17-2009, 10:01 AM   #10837
The holes for the motor mount are simply moved so that the motor mount is in line with the bulkhead. it is no further forward or back. Where the motor mount and bulkhead originally overlap, 50% of the material from each piece has been removed so that the two parts can still be screwed together.
With this setup. The entire assembly works just like it does with the unmodified parts. No fewer screws are used.
The top deck does need to be modified to clear the re-positioned motor.
Old 09-17-2009, 11:21 AM   #10838
Originally Posted by Rick Hohwart View Post
It is my car.
I wondered that after I noticed it was a 6.5 motor in there. Will Associated be releasing the bulkhead trick or is that something you did on your own?
Old 09-17-2009, 11:28 AM   #10839
John_S's Avatar
Ok thanks i will just stick with my silver bulkheads then
Old 09-17-2009, 11:39 AM   #10840
I know I'm not Rick (I wish I had his talent) but I know in general VTA setups and TC setups are wildly different. So I would say it is probably not a good place to start. I would guess some of the VTA threads have some good TC5 setups in them.
Old 09-17-2009, 12:24 PM   #10841
geeunit1014's Avatar
Do happen to have a part # for that?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-17-2009, 01:16 PM   #10842
This is something we did here to test whether or not it would make a difference. it is something we are considering for release.
As far as centering the motor goes, these will achieve the same result.
89008
Old 09-17-2009, 01:42 PM   #10843
Gain Time's Avatar
so the ball studs mounted on the bulkhead are to make the camber links longer?
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 09-17-2009, 01:49 PM   #10844
Rick are those B44 shock caps you are using on your car? Any other mods you can let us in on?
Old 09-17-2009, 02:23 PM   #10845
Yes. if you were to mount the inner ball stud at this location, you will have to add 2mm under each outer ball stud.
They are the new off-road bleeder caps. I was playing with them but they do not really make a difference other than possibly being easier to get rebound equal side to side. Keven H and others drill out the hole on the plastic part of the standard cap to relive pressure behind the bladder.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
