Old 09-09-2009, 07:08 PM   #10756
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Originally Posted by RMKinWI View Post
Building first TC5R - There are no diff balls in the front spool - Gear sandwiched between the outdrives - is this correct? This is how I assembled it and it is next to impossible to spin the outdrives in opposite directions.
Sorry for the newbie question!
Its a spool drive. If you want a diff you will have to buy the parts to build one.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | McFactory | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 09-09-2009, 07:15 PM   #10757
RMKinWI's Avatar
Actually, I believe the kit comes with the parts to make it a diff.
I just want to make sure there is supposed to be no or very little movement in the spool, when turning the outdrives in opposite directions?
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 09-09-2009, 08:02 PM   #10758
revo61's Avatar
Trader Rating: 18 (95%+)
That is correct.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 09-09-2009, 08:44 PM   #10759
hollywood tc5's Avatar
hey guys where can i get the rear bulkheads that move your motor 5mm in????????
BOSS MOTORSPORTS
wrecking ball,sox,hollywood
BOSS MOTORSPORTS
hollywood tc5 is offline   Reply With Quote
Old 09-10-2009, 06:06 AM   #10760
Trader Rating: 38 (100%+)
Ive tried to track them down myself. I emailed the guy that made them with no response. Best Ive learned is you just have to wait to see if he posts more on ebay.
or8ital is offline   Reply With Quote
Old 09-10-2009, 04:38 PM   #10761
Default Also a newbie question
Originally Posted by revo61 View Post
That is correct.
I also just got a TC5 R kit, I have collected everything to build it.
One question, should I use a spool in the front if I am running on asphalt? If so or not, why?
Jim
authorjim is offline   Reply With Quote
Old 09-10-2009, 05:26 PM   #10762
mr crum's Avatar
Send a message via Yahoo to mr crum
Jim
slipper spool without a doubt
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 09-10-2009, 09:36 PM   #10763
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hum...i was studying setups posted on associated website and it got me confused on rear toe ins , it mentioned 2.5 total , with all rear caster block avaliable ( 0 , .5 ,1 ) how do they acheive 2.5 toe ins ? , or does it means 1.25 each side ? really confused , any advise or input is much appreciated..
Tag is offline   Reply With Quote
Old 09-10-2009, 09:42 PM   #10764
Verndog's Avatar
Trader Rating: 16 (100%+)
You add up what is on the hub + the amount that the arm mount is shimmed. .5 on hub + 2.0 on arm = 2.5 toe. This is always measured per side not total of both sides.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 09-10-2009, 10:05 PM   #10765
Tag
Tag's Avatar
oh i see, are you saying the stock rear lower arms already has 2 degree negative toe ins ?
Old 09-10-2009, 10:24 PM   #10766
geeunit1014's Avatar
He just picked a number as an example. The shims behind the rear arm mount will determine how much inboard toe the car has(toe in the arm), and then you add whatever toe you have in the hubs for the total toe in. The kit comes with 1*, 1,5* and 2* toe in shims for the arms.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-10-2009, 10:43 PM   #10767
Verndog's Avatar
Exactly. Just read page 9 of the manual and you will see the placement for the C shaped shims giving the desired angle of rear arm mount.
---Team Hoarders---
Old 09-11-2009, 08:02 AM   #10768
Tag
Tag's Avatar
hello, thanks for good info guys, yeh page 9 of the manual had really explained it ...just picked up this car and still trying to learn the car , i know most of the questions probably have been answear somewhere in this thread but kinda hard for me to go through them all
okay, so if i use the 2mm shim that means i can run a "0" rear hub carrier and still achive 2mm toe ins that i want ?
Old 09-11-2009, 08:08 AM   #10769
Verndog's Avatar
Yes, if you want 2 degs. But if your running on asphalt prob. 2.5 - 3.0 degs. will plant the back better. I prefer the 0 deg hubs, all things equal, they are the same right and left and if you break 1, the hub will work for either side.
---Team Hoarders---
Old 09-11-2009, 09:08 AM   #10770
Anyone out in Vegas see any intresting bits on Josh's or Keven's cars? Theyre looking very good so far Keven is TQ in 13.5/rubber after thursday
Mike Gee
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
