Old 09-07-2009, 01:16 PM   #10741
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default spam77
Gear down to range from 4.2 to 4.9...depending on track.
try a start at the middle...4.5....and see how that goes.
run a large fan or the MuchMore ultraRpm fan....
that should help a lot.....
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 09-07-2009, 04:55 PM   #10742
Default thanks
olhipster and crum,
Thanks so much for the feedback, will do!
-AJ
spam77 is offline   Reply With Quote
Old 09-07-2009, 06:51 PM   #10743
Originally Posted by spam77 View Post
Hi,
I just got a TC5R and thought I'd try this question here...
Got a overheating scenario I'd like to run by some of the experienced RC TC5 drivers.
I've got a TC5R, stock kit setup, Novak Havoc Sport Brushless 17.5 system, 40 Sweep tires, 94731 Airtronics servo, use a Reedy 5000mah 20C lipo battery, and run a 3.89 FDR with a pinion of 37 and spur of 72. I race outdoor parking lot asphalt.
I usually thermal on the last lap of my race, somewhere around 4-6 minutes of driving, the ESC will shutdown because temps reach around 160 degrees.
I'm going to try a few things in this order:
1: Change my tires to sorex 36s. I noticed my car sliding a lot, so getting better grip and not wasting so much energy could bring the temp down.
2: Snap on a heat sink
3: install on a fan
4: Gear down a bit to a 35 or 36 pinion
I do like the punch/speed of the car, so that's why I'd like to try to mess with the gearing last if nothing else works. Anyone got opinions on how I'm trying to solve this thermal issue?
Thanks, Any help is appreciated.
AJ
Try another ESC, there should be no reason why you'll be thermalling at that ratio for 17.5. My LRP TC Spec at 3.5 only got to 69c and my Tekin RS with boost at 3.7 got to 73c, in both occasions that speedys never got hot.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 09-07-2009, 06:58 PM   #10744
olhipster1's Avatar
Default spam77
No prob, Spam77
some of the guys are right the Havoc can be replaced with a beefier speedo...
but most likely if running a Havoc then you're probably starting on a budget...
must run it with a fan...until it blows or you get tired of it
I think Novak has a trade up program.....if they do..you can trade up to a GTB or Slyder for a charge...check their website.
CAUSE and EFFECT
Old 09-08-2009, 12:37 PM   #10745
No prob, Spam77
Thanks for the advice olhip and Scooter,
Yeah, I was on a budget... but I did get a fan to help things along until the havoc blows up (or I get the funds to trade up).
Have a good one!
-AJ
Old 09-08-2009, 01:23 PM   #10746
revo61's Avatar
Trader Rating: 18 (95%+)
Here is a reman Spread Spectrum gtb for 109.
http://www.shopatron.com/products/pr...1.26354.0.0.0?
Have a good one!
-AJ
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 09-08-2009, 06:44 PM   #10747
Bigedmond's Avatar
Trader Rating: 18 (100%+)
man my car sucked at IIC today. Insane turn in, and super loose in the rear.
I have removed the sway bar, 50wt in the front, 40wt rear. Silver front, blue springs rear. I dont know what to do. I have my expo at -80, and dual rate around 60
Bigedmond is offline   Reply With Quote
Old 09-08-2009, 06:48 PM   #10748
geeunit1014's Avatar
Switch the springs around.. blue front silver rear. You really shouldnt ever run stiffer springs in the rear than in the front.
This is Josh H's Rubber/carpet setup. Ive personally never used it, but everyone loves it.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-08-2009, 07:36 PM   #10749
mr crum's Avatar
Send a message via Yahoo to mr crum
how much rear toe do u have
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 09-08-2009, 07:58 PM   #10750
Trader Rating: 23 (100%+)
remember, the groove isnt very high yet.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 09-09-2009, 12:35 AM   #10751
Robert_K's Avatar
Agree, Every run the grip will increase fast.
Try raising your front susp arms (Higher Roll Center), and check the amount of toe at the rear.
Best Regards,
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 09-09-2009, 04:48 AM   #10752
olhipster1's Avatar
Default small changes
do small changes....
as some already mentioned
reverse your springs.
then raise your front roll center blocks.
then try long links in the rear. lengthen the inner link first.
i always use the the thinnest sway bar.
or it may be easier to ask the sponsored AE team. they should be able help you very easily.
Don't be shy...and just ask for their help...it's part of why they are there.
Good luck out there.
CAUSE and EFFECT
Old 09-09-2009, 06:44 AM   #10753
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Go find the AE team guys, and bring your car with. They will help get you going in the right direction.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | McFactory | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 09-09-2009, 11:30 AM   #10754
hollywood tc5's Avatar
hey guys where can i get the rear bulkheads that move your motor 5mm in????????
BOSS MOTORSPORTS
wrecking ball,sox,hollywood
BOSS MOTORSPORTS
hollywood tc5 is offline   Reply With Quote
Old 09-09-2009, 07:05 PM   #10755
RMKinWI's Avatar
Building first TC5R - There are no diff balls in the front spool - Gear sandwiched between the outdrives - is this correct? This is how I assembled it and it is next to impossible to spin the outdrives in opposite directions.
Sorry for the newbie question!
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
