Old 09-01-2009, 08:44 PM   #10696
geeunit1014's Avatar
Question for the set up gurus (maybe Rick H can help me on this one)
The setup im currently running uses a 3 wheelbase in the front, and 2 in the rear (IE, 3mm shim in front of the front arm, and 2mm in front of the rear arm). What would be the effect of going to a 2 in the front, and 1 in the back, keeping the wheelbase the same, but moving the arms forward and relative to the chassis?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 09-01-2009, 09:22 PM   #10697
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Mark506 View Post
whys everyone selling there TC5?
From what I can tell as asphalt season nears an end in many areas, people are getting ready for either offroad or carpet season....so they sell. I bought my TC5 a little over 2 years ago, and since have run a second car (007 and 008) and to this day, the TC5 still handles as well if not better then either "luxury car".
I've seen several of our areas better racers go away from the TC5 and then come back and buy another one. As new models come out people want to find the holly grail of sedans, often finding they gained nothing and only lost time and money.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 09-01-2009, 11:14 PM   #10698
pakk's Avatar
Trader Rating: 79 (100%+)
Default Arm mount positioning
Keeping the arms level, what affects do you have using the three different arm mounts?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 09-01-2009, 11:22 PM   #10699
You can get pro/anti-dive (front) and/or pro/anti squat doing this will effect castor angles so you wanna check how degrees of dive compared to the castor block. For example with 6 degree castor blocks with 2 degrees of anti-dive will give you a total of 4 degrees castor.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 09-01-2009, 11:24 PM   #10700
pakk's Avatar
Isn't that what you get when you use different mounts? I mean, if you ran all 1 dot mounts all the way around versus running 3 dot mounts all the way around.
--pakk
*Photon* *SC10 4x4*
RCRD
Old 09-01-2009, 11:33 PM   #10701
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
--pakk
That would just change your roll center.
Scooter is referring to using different dot blocks in the front front and front rear which will give you anti dive or kickup. Same difference for the rear.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-01-2009, 11:35 PM   #10702
pakk's Avatar
Ok, that is what I wanted to know.
It changes roll center.
*Photon* *SC10 4x4*
RCRD
Old 09-02-2009, 04:15 AM   #10703
mr crum's Avatar
Send a message via Yahoo to mr crum
shorter the wheelbase the better turn in but u loose stability
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 09-02-2009, 06:39 AM   #10704
Can anyone give me dimensions for the diff rings or drive rings that are used in a TC5 or TC4. And if they are D-rings???
OD/ID and thickness would be great.
thank you
Walter
Anytime72 is offline   Reply With Quote
Old 09-02-2009, 08:18 AM   #10705
Thats not what I am asking. In short, im wondering what will happen if you move both front and rear arms forward, but the wheelbase stays the same
Mike Gee
Old 09-02-2009, 08:50 AM   #10706
Default Just got a new TC5R
Okay guys need some help. I just got the TC5R car and started buying a body some replacement parts etc.
I am also purchasing a Futaba 603FS reciever since I have a Futaba 4pk transmitter.
I also will purchase a Futaba low profile digital servo. Is that okay?
Need advice on the Motor and Esc.
What KV range should I be looking in to get good speed and balance of low end torque. What is a dependable unit with fan. Any thoughts on which units are more efficient with better run times. Mostly club racing, some cobbled together parking lots, mid to long straights quite a few turns and switch backs.
Castle, Novak, LRP --- any brand recommendations also.
Do these electrics require as many holes in body for cooling like the Nitros?
Jim
authorjim is offline   Reply With Quote
Old 09-02-2009, 09:21 AM   #10707
Trader Rating: 38 (100%+)
Jim
Racing or bashing? If racing, what class?
or8ital is offline   Reply With Quote
Old 09-02-2009, 12:13 PM   #10708
Trader Rating: 30 (100%+)
Thanks for the help guys, thanks joe I appreciate it. I think I am going to just run the diffs. Do you guys think a spool is 100% necessary on carpet? How about a 1 way? Any thoughts...
Chuck Harris
[email protected]
702-373-0505
chuckharrisjr is offline   Reply With Quote
Old 09-02-2009, 12:23 PM   #10709
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
You wont dig running the diff in the front, look at all the driver sheets from the past few years adn they all run spools...all you need to do is remove the balls and put the slipper pads in...your choice though...You may fight setup if you are following a setup from a spooled car...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 09-02-2009, 02:43 PM   #10710
Default Class, what are the classes
To: or8ital
Trying to get some people together for parking lot club racing. I don't yet know about classes, please enlighten me.
Couple of more questions popped up, what's a spool?
What tires, by brand and what wheels?
Sorry for all the questions but I'm new at electric. Used to GT2 nitro.
Jim
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
