Team Associated TC5
agreed. But that extra bit of info just saved me some money. Thanks
Why not use the official associated horn? You can get a set of 4 for less than 3 quid, part number AS9180. I have a Futaba S9551 and the 'F' associated horn is perfect.
Regards
Neal
Regards
Neal
Suspended
Spot on...
Standard associated arms are perfect for the job!
Not all servos fit the AE horns. I'm using a Spektrum servo which is JR horn and the AE 'J' horn doesn't fit it, so I've been using a modified heavy duty JR horn.
....Because I moved the servo as far to the middle as possible. I can move it out and the arm will be strait, but I don't want to. If I have to choose between angled arm(which affects nothing) and move the servo out, I choose angled arm.
--pakk
--pakk
does anybody know if ae has any plans on making new steering blocks and rear hubs that will fit thicker bearings?
17.5 gearing
what size pinon and spur gear are you guys using in a tc5r for 17.5 motor
Tech Legend
Trader Rating: 51 (100%+)
Gearing will depend on multitude of things, including track size, motor/speed controll (and what version software it is if you have a tekin), and ambient temperature, so we will need a bit more info to give you an answer
lrp tc spec for the speed control speed passion 17.5 temp is about 80 degrees track is trackside
For 17.5 ive been running a 100t 64p with a 40-46.
diff height
hi guy, afound alot of good info on this thread,but i have question on diff heights that in the bulkheads . has anybody tried changing height in the bulkheads to see how effects car handling?
anyone have a problem with the exotek upper deck hitting the center shaft? Here is what is happening to mine. I'm going to just dremel it down a bit and CA it up.
