Old 07-29-2009, 11:33 AM   #10471
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Originally Posted by espresso1967 View Post
Anyone using the Diggity Wide lipo mounting brace (not the offset one) with ppd 3oz base and 2oz side weight? I am using the smc 5200 40c lipo and wanting to get my car balanced properly once my tekin rs pro arrives this week.
Will be using four scales to balance car out once esc arrives.
Yes, I have been using all 3 for over a year now. I run a Reedy 5A pack though. My car balances perfectly with the edge of the battery pushed in about 3mm from edge of chassis, however this is dependent of the electronics you use. I did shim the Diggity brace up 2mm and now I have yet to have the battery fall out using the battery strap, HOWEVER as of last time out, I started taping my packs in. I was about 15g over weight (1500g min), and taking the battery tray out, along with the associated strap hardware, I am now 5g under depending on body and paint used.
I did find the larger of the Diggity braces to actually be wider/longer than what he specifies. Ill give you the actual measurements later today of both non-offset braces. I have also found the SMC batteries size measurements to be off as well, as the case is not perfectly rectangular. (The middle seam is puffed out on all SMC packs that I have seen with Deans connectors)
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 07-29-2009, 01:10 PM   #10472
OI82lose's Avatar
Originally Posted by Verndog View Post
If your running 48P then I'd start with a 78T spur and a 30T pinion. That will put you at 5.2 ratio and you'll have a little adjustment to go up and a lot to go down. With that spur you can go to 17.5 class without changing.
The stock pinion is 87 tooth.
This is the first time I have run a small KV motor. These numbers seem odd to me, but I go with experts here.
So need to order some Pinions and Spurs here.
What would be a set to get?
I am thinking a 78T spur, a 75T spur, and some monster large pinions, like 30T, 32T, 35T?
All my pinions are 12-18 tooth range.
What gearing would I use to run a 13.5 motor in the 17.5 class?
That would be go for me to start slower.
What final drive ratio should I look for to keep my motor cool?
Associated said 4.42 and you say 5.2, so I guess somewhere in between these numbers will be ok?
I called Associated and they said run 73/33, or 73/34. The funny thing is I can't find a 73T Spur in there catalog, I only see a 72T and a 75T.
Thanks for the advice.
OI82lose is offline   Reply With Quote
Old 07-29-2009, 02:53 PM   #10473
Trader Rating: 23 (100%+)
go 64 pitch. smoother and quieter. you can go like 96/50 or something.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 07-31-2009, 01:14 AM   #10474
Who do we contact to order the custom bulkheads?
bmcallister is offline   Reply With Quote
Old 07-31-2009, 01:17 AM   #10475
pakk's Avatar
Trader Rating: 79 (100%+)
Here is his ebay auction. It has ended, but I talk to him through there. He seems busy though. He got back to me a few times, but it has been a week or more now with no response.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-31-2009, 03:32 AM   #10476
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
My buddy ordered the new rear bulkheads from Ebay and had them in a little less than 2 weeks.
ST Racing Concepts (STRC)
Old 07-31-2009, 08:26 AM   #10477
Suspended
--pakk
Greig has been very busy at work as of late, i'll be seeing him at racing later on so i'll tell him to check his mails!
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 07-31-2009, 09:01 AM   #10478
Trader Rating: 76 (100%+)
It took about a week and a half to het them.
MUDVAYNE is offline   Reply With Quote
Old 07-31-2009, 09:12 AM   #10479
Logi Maker's Avatar
Trader Rating: 49 (100%+)
I use the wide offset one with a Reedy 35c (Added about a 2mm shim to lock ing battery). I had an LRP TC Spec, Novak 17.5, Micro Spektrum and Airtronics 9360. I removed the PPD plate (Sorry Kevin!) and needed to add 35 gr to top of battery stap. It was perfect.
Since I changed ESC and new motor arriving today I will have to check again...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 08-02-2009, 07:39 AM   #10480
Just got a hold of a couple of spools off eBay, one slipper and one fixed. Was wandering if people use 'blades' or anything on the outdrives? If so do AE do any or do other brands fit?
Cheers
TC5
www.keiransmart.co.uk
Keiran is offline   Reply With Quote
Old 08-02-2009, 11:24 AM   #10481
wyd
Tech Legend
wyd's Avatar
If anyone is looking I have the Exotech chassis, toplate and battery hold down for sale here on Tech. It is in mint condition. Just PM me is interested.
Old 08-02-2009, 11:25 AM   #10482
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Cheers
The AE brand blades work great...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 08-02-2009, 02:23 PM   #10483
mr crum's Avatar
Send a message via Yahoo to mr crum
y are u selling them is there somethin wrong do they handle ok plz give me some feed back pm if u like fixin to purchase and dont wanna waste money
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 08-02-2009, 02:53 PM   #10484
Old 08-02-2009, 04:03 PM   #10485
wyd
Tech Legend
wyd's Avatar
No it has nothing to do with not liking it. Actually the car was better than it has been since I bought about 2 months ago. I'm switching to another car as I have a deal to run something else.
What I found at are track with the Exotek chassis is I had more traction. I ran 2.5 degrees of rear toe in per side and yesturday I easily was able to 1.5 degrees of teo a side with zero side effect. It was just as hooked up as before but I took a tenth a lap off my time using worn out tires as it was the 3rd week on them. I'm actually very impressed with the chassis overall and if I didn't get a ride I would not of sold the car as the Exotech chassis really was a nice improvement. Steering was very smooth and neutral at are track and weight balance on my car was excellent. On the tweak station I was less than a 1/4 on any one shock differance and thats it.
The fit and finish are excellent on the chassis and I would buy from Exotech again if for whatever reason if I bought another TC5 or even his new Schumahcer MI3 chassis. Very nice stuff.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
