Old 07-27-2009, 01:29 PM   #10411
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
What is your setup and on what surface are you driving?
IIGQ4U is offline   Reply With Quote
Old 07-27-2009, 01:35 PM   #10412
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by geeunit1014 View Post
Hey Craig. Unfortunately I dont think im going to be able to make it to the Xray challenge For setup though, i would suggest making a few changes to free the car up a bit, as it will be more planted with the exotek. On my car I took a bit of toe out of the rear (only have a 2mm shim now), and I shortened up the wheelbase in the front, and that really helped the car rotate. Oh, and since theyre running blues for that race, you may need to take the swaybars off your car, since most likely youll be searching for a bit of overall grip. Hope that helps.
cool mike thanx. i got the whole kit wth the super flexy topdeck so maybe i will run it since the jacos are horrible
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 07-27-2009, 02:20 PM   #10413
geeunit1014's Avatar
You will definately want it with the jacos If you want I can get you a setup of what I ran @ Jackson
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-27-2009, 02:27 PM   #10414
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Very close to Howart's bangkok setup on asphault sprayed with soda 140* temp...Ive tried fast setups at my track and it just pushes no matter what I do...tight track with front diff is the difference from howarts
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 07-27-2009, 02:35 PM   #10415
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Front diff is probably the biggest problem. Put a spool in it.
Jon Kerr is offline   Reply With Quote
Old 07-27-2009, 02:50 PM   #10416
trdsupra88's Avatar
I have tried it and it does not work for our track, 60+ racers and 2 guys use them...Is it possible that a car that is too light would handle poor? I am running brushed, small GTX ESC, and small 3200 orion LiPos...getting to the bottom of the barrel now...
I cut my own hair ☆
Old 07-27-2009, 02:57 PM   #10417
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Joe, after the first qual, everyone had push. Then you started making changes, as the track started coming in.
Like we talked about saturday, learning to drive the car in different conditions with the same setup is better then making huge changes as the track conditions change. Friday night was hard on everyone.
Also, what tires were you running. I had great results with sorex 32r's
Bigedmond is offline   Reply With Quote
Old 07-27-2009, 03:36 PM   #10418
thanx mike i would greatly appreciate that
Old 07-27-2009, 04:22 PM   #10419
mr crum's Avatar
Send a message via Yahoo to mr crum
+1
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 07-27-2009, 04:32 PM   #10420
IIGQ4U's Avatar
How old are your tires?
Old 07-27-2009, 06:08 PM   #10421
Here ya go Craig
Mike Gee
Old 07-27-2009, 06:37 PM   #10422
trdsupra88's Avatar
I have a set of 32s ill try if I can find some inserts...
Originally Posted by mr crum View Post
+1
Im going to give the spool another try and be super aggressive with it and attack corners drive through slow and power out...
Not extremely old...total of 40 minutes on sorex 36s...
I cut my own hair ☆
Old 07-27-2009, 06:48 PM   #10423
Here ya go Craig
thanx mike
Old 07-27-2009, 07:14 PM   #10424
Trader Rating: 30 (100%+)
Im stumped, my car turns more aggresively to one side. If I turn all the way to one side it will kinda push, not loop out, if I turn all the way to the other side my car will just loop out. I used setup station to get my epa exactly the same, full throw basically. I checked all the bearings, shocks, hinge pins, swaybars, rear toe is identical. my car is balanced side to side. Everything is free. I dont get it. Is it just the diffs? Is this normal? I run a bl 17.5, anyone any ideas?
Thanks in advance.
Chuck Harris
Luckylinedesigns@yahoo.com
702-373-0505
chuckharrisjr is offline   Reply With Quote
Old 07-27-2009, 07:28 PM   #10425
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Come on you telling me you don't like those tires!!!!!!!!!!! The newer tires with the new insert I will say had much better wear than the tires with the older insert in them. The Jaco tires for me just don't seem to produce the overall grip vs some other tires I have ran in the past.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
wyd is online now   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
