Old 07-20-2009, 12:32 PM   #10306
Maybell's Avatar
Originally Posted by jquackjr View Post
local asphalt racing "club" has started running a "spec" class, any car but only 13.5 motor and 36r tires.
today had a really hard time with the back end not sticking well, was really loose .
1) any good setup sheets fo rthis kind of setup
2) what ( other than tires) do you all change to get the rear end to stay planted in corner better?
3) i have doen lots of off road racing and with that you can tell when the tires are wearing, how do you know a set is bad/doen with onroad ( i cannot buy tons of tires)
thanks in advance for your help
if you coudl PM me with ideas or to let me know a response is posted i woudl appreciate it.
Changes that will help with rear grip...
-More rear toe-in on the inner hing pin holders (inboard toe)
-less rear arm down travel
-softer rear shock or stiffer front
-be sure to check the outer glue job on your tires after every run
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 07-20-2009, 12:39 PM   #10307
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
What can you expect to see from going from 2a on the arm mounts to 3a? I saw a difference on some of the AE driver sheets and wondered...you are really messing with squat or dive, just the height of the arms...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 07-20-2009, 05:40 PM   #10308
Trader Rating: 76 (100%+)
hey guys, I started the Exotek TC5 Euro build tonight. As you can see from the pics, I milled out a little more that came from Exotek to accomodate the new rear bulkheads I bought from Greig. So far everything is literly falling together. The machining from both people is dead on, and it's going way better than expected. I can't wait to get this thing built and runnin' on the track. I didn't have any issues with the rear diff getting pinched by the shocktower assembly, but I did have to file down the spacer on the layshaft about 10 thousands to get it to fit in between the new bulkheads. This only took 15 minutes and it's as free as it was. I used a hand file and rubbed the spacer on it. If anyone has any questions, let me know. Exotek and Greig both have outstanding products.
MUDVAYNE is offline   Reply With Quote
Old 07-20-2009, 08:53 PM   #10309
Suspended
For the people who said our bulkheads would bend in a crash due to having no screw past the motor, this is what happens with the standard associated part with all screws fitted shows what happens when you use a poor grade alloy over our superior machined bulkheads ;-). Also they look superb on the chassis above!
Nick Priest is offline   Reply With Quote
Old 07-20-2009, 08:56 PM   #10310
Trader Rating: 29 (100%+)
Default thanks for the help
I appreciate the input, sound like checking and increasing ( most likely) the rear toe is where i will start. Without actually measuring , you are probably right.. my T4 has more rear toe than the TC5 does right now and i probably should have thought of that. I will give it a go and let you all know
thanks again
Off road, On Road , On the water On the rocks and in the air, these are the places my RC's go
jquackjr is offline   Reply With Quote
Old 07-20-2009, 08:57 PM   #10311
Suspended
Also thanks for the good words on the bulkheads mudvayne :-)
Old 07-20-2009, 08:57 PM   #10312
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Yup, I bent one as well due to 4 cars tagging me while in pole position in the first corner. Wish people would learn to be patient off the line...
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 07-20-2009, 09:53 PM   #10313
Ain't that the truth, it happened on the 2nd final on Sunday's race meet. I started in 3rd with a Losi XXX-S in 2nd and another TC5 in 1st, 1st and 2nd got tangled up on take off which I managed to dodge. The Losi was one the road waiting for a marshell when 6 other cars managed to hit at near top speed breaking multiple parts on it. That would not of happened with the A and B from qualifing stayed as seperate classes.
That Exotek chassis looks real sweet, if I had the money and the Aussie doller was better I would consider getting one. But at least with my parts order arriving yesterday I'm now able to set up my car to how want it, yay for silver springs
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 07-20-2009, 10:07 PM   #10314
Seriously....thats terrible. I hope the others offered to pay for the broken parts...
If Im not on pole, I don't floor it off the line, in fact now, I will get out of the way, sometimes count to 5, then take off and pass most of the crashes in the first lap, usually fighting for a podium position by lap 2....
Old 07-20-2009, 10:17 PM   #10315
Jon Kerr's Avatar
I have bent one right front bulkhead on the car so far. How much are, and where can I get a set of those?
Jon Kerr is offline   Reply With Quote
Old 07-20-2009, 10:19 PM   #10316
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
PM Nick Priest. They are shipped from the UK. I believe that there is a set on eBay at the moment.
IIGQ4U is offline   Reply With Quote
Old 07-21-2009, 03:21 AM   #10317
Yes, Nick put me in touch with a gentleman named Greig, from the UK. As of right now, I believe he's only doing the rear bulkheads, but if people start requesting fronts you never know what will happen. Like I said before, excellent machining work, and the parts lined right up with no problems. The Exotek chassis is machined excellent as well. Very happy customer here.
Old 07-21-2009, 04:15 AM   #10318
Trader Rating: 23 (100%+)
For those of you running your TC5R in vintage, what droop are you starting at?
bmcallister is offline   Reply With Quote
Old 07-21-2009, 04:28 AM   #10319
Hey, great comunication and fast shipping with a quality product, what else can I say?. If greig has a screen name here I would like to give him some good feedback as well.
Old 07-21-2009, 05:09 AM   #10320
Dunno, I think the guy had spares. I was one of the couple cars that didn't hit it, and the initial colision happened right in front of me.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
