Team Associated TC5
If you'll be running rubber tires on carpet, you'll want the TC5R. Factory team car has the plastic diffs, different chassis etc... The R and F are the updated cars and are specific for rubber or foam ties.
Or maybe another pulleys?
From losi 41T is to big
Now I test that with trf416 172T belt is a little loose on front (need some belt tensor) on rear is quite OK.
Regards!
m.
ps: I will try with my second tc5 build front slipper spool and test overdrive
I'm assuming the TC5 pulleys are 40 tooth then (I haven't counted them) I'll order one next time I place and order and try it. I always loved overdrive on the Losi cars years ago.
Need Set-up help
local asphalt racing "club" has started running a "spec" class, any car but only 13.5 motor and 36r tires.
today had a really hard time with the back end not sticking well, was really loose .
1) any good setup sheets fo rthis kind of setup
2) what ( other than tires) do you all change to get the rear end to stay planted in corner better?
3) i have doen lots of off road racing and with that you can tell when the tires are wearing, how do you know a set is bad/doen with onroad ( i cannot buy tons of tires)
thanks in advance for your help
if you coudl PM me with ideas or to let me know a response is posted i woudl appreciate it.
hey guys i took my ft tc5 on carpet for the first time with asphalt setup and 27 tires the thing was hooked drove great after i clean it im gona take some pics of mods ive done so maybe u old tc5 drivers can try and make these thick chassis hook up on asphalt
My setup changes worked well during yesterday's race, got a new personal best of 20.030 seconds with 15 laps, the car went heaps well until I needed a new CVA joint or re-build kit.
good info here
That there is
Considering I'm new to this car and learning the general stuff about car setup (only been racing since last Oct/Nov) this thread and other TC5 owners have been very useful.
Tech Legend
Trader Rating: 51 (100%+)
Well I broke down and ordered the new Exotek chassis and toplate. After looking at a few of the cars with this setup I decided to give it a try. Damn it Jon if your car didn't look so killer maybe I would of not bought one. Ok thats my story and I'm sticking to it.
Glad I could help.
Tech Legend
I ordered the chassis from Exotek on Sunday night and I already have my confirmation that is is shipping out today. Looks like by Wed or Thurs I will be tearing my car down and getting everything over to the new chassis. I will make all my changes to my car now and then all I have to do and transfer everything to the new chassis. I will have all the hard work already done. Weekend is looking brighter already.
If you are racing on asphalt, you will definitely be pleased with the Exotek.
Tech Legend
Yes I run on asphalt. Most of my touring racing is asphalt rubber tire and a rare possibility I might run rubber tire carpet. The rubber tire carpet will be very rare at best since carpet tracks are pretty far away for me to get to.
