Old 07-14-2009, 06:37 PM   #10231
Originally Posted by Fabricio View Post
- TC5R cam holders, they got more adjusting them the originals I got.
What makes the R cam holders so special? How are they different from the FT?
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 07-14-2009, 08:16 PM   #10232
katfish317's Avatar
They have alot more room for adjustments, which really allows more free play in the belt for stock and more adjustments for mod also!!
katfish317 is offline   Reply With Quote
Old 07-14-2009, 09:03 PM   #10233
LOSI123's Avatar
Trader Rating: 63 (100%+)
Originally Posted by LOSI123 View Post
couple of ?'s
1. Is there a Steel outdrive Spool for this car
2. Is there a fix/mod for the back end arm mounts so that there is no force on the hinge pin holders when doing up the screws and having say 3 deg rear toe.
Anyone??? Pls
LOSI123 is offline   Reply With Quote
Old 07-14-2009, 09:15 PM   #10234
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Default steel spool
TOP USA has TC5 steel spools available.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 07-14-2009, 09:25 PM   #10235
Thanks for the info, looks like I should get some R cam holders. I've got my belts loose as possible with the FT ones, but the front feels like it could go looser.
Old 07-15-2009, 06:46 AM   #10236
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Top also makes a nice aluminum spur gear holder which I have on my TC5. Just got it a few weeks ago from TOP. No more worries about stripping ouot my screw holes anymore.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-15-2009, 07:26 AM   #10237
Valkman's Avatar
Scooter - the original FT cam holders are P/N ASC31186, the type R cams with more adjustment are P/N ASC31184, they make a big difference.
Wyd - can you post a link to Top USA ??
Lazer Speedway / Woodville Mall
Associated TC5R/TC5F
Trinity Duo's by Express Motorsports
Sorex SJ-R's by Speedworld Hobby
Paint by Splat Graphics
Valkman is offline   Reply With Quote
Old 07-15-2009, 07:33 AM   #10238
Cheers for that, at least with the part being proper AE I should be able to get it fairly easy. If I knew about that earlier today I could've ordered some when I did my TC5 spare parts order with Harris R/C earlier. At least I'll have spares and silver springs before the SA state titles, which will be a good thing.
Old 07-15-2009, 09:06 AM   #10239
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
What is the difference in settings for belt tension? Does tighter or looser change the performance at all? I am using the FT cam holder and I believe they are on the loosest setting...they feel good to me and the drivetrain spin freely...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 07-15-2009, 09:41 AM   #10240
Valkman's Avatar
IMO - a looser drive train equates to less rolling resistance which generally equals a faster, more efficient car. Less resistance also equals lower electric motor loads and lower motor temps. I run 17.5 and have my belts rather loose, but not loose enough to skip or damage the belt.
Lower turn BL motors require the belts to be tighter. Mod motors will rip up belts if they're too loose. So it depends on what your running, but the least amount of resistance is desireable.
Your FT cams may be fine if your front belt is fairly broken in. Mine was a bit tight when new, so I swtiched to the R cams. After almost a year, I could probably switch back, but there would be no advantage.
Old 07-15-2009, 11:15 AM   #10241
wyd
Tech Legend
wyd's Avatar
www.topracingusa.com I called them and told them I would like to order the TC5 alum spur gear adapter. The emailed me the price with everything I needed and I then Paypaled them. Very quick and easy. Only took a few days to get the part. TOP Racing had great service considering how busy they are with the new Photon and all the shipping they are doing right now.
Old 07-15-2009, 11:37 AM   #10242
jag88's Avatar
Josh Posted this on the Photon thread, could be useful .......
Josh Cyrul
Trader Rating: 0
I understand that you are trying to make the transmission as free as possible but keep in mind that you are probably hurting yourself. At top end rpms, running the belts too loose will cause them to bounce all over the place and really make the transmission actually bind up. Loose belts = good punch off the corner but they make for terrible top speed (to a point). The belts should have a maximum of 4mm deflection (from relaxed position to pushing on them with firm tension). Anything more than this will actually cost you top speed and run time.
CEFX, T.O.P. Racing, Thunder Power, Shepherd Micro Racing, Novarossi, Jaco, Hacker, Ko Propo, Kimbrough, Faskolor, MuchMore & Reilly Paint
www.cefx.net - www.topracingusa.com - www.thunderpowerrc.com - www.team-shepherd.com - www.kopropo.com/america - www.novarossi.com
jag88 is offline   Reply With Quote
Old 07-15-2009, 12:08 PM   #10243
wyd
Tech Legend
wyd's Avatar
Great post from Josh and I think very useful info. My belts are right on the mark I would say. My front belt is a tad stiffer than the rear but like I posted before they are very smooth and no tight spots when you spin the wheels. My car might not free wheel as long as some other brands of touring cars I have but just as smooth as any of them over all.
Old 07-15-2009, 12:22 PM   #10244
I'm running VTA and was wondering from experience if JOsh H's setup or Juho's world setup would be better for a parking lot asphalt track low to medium grip.
home13oy75 is offline   Reply With Quote
Old 07-15-2009, 01:05 PM   #10245
wyd
Tech Legend
wyd's Avatar
Not sure but you have to remember they are running modified so their setup would most likely be very aggressive and since VTA is alot slower you might find your car oversteering.
They other thing is they are normally running on well prepared surfaces and at the Worlds the track would be very well prepared with excellent traction.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 21 (0 members and 21 guests)
