Old 07-12-2009, 01:34 PM   #10186
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Joe, your car is DIALED.
Bigedmond is offline   Reply With Quote
Old 07-12-2009, 01:37 PM   #10187
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by trdsupra88 View Post
What do you guys recommend I do to get my car to be more responsive? I am running rubber on asphault with rick howarts thailand setup. The car feels like it still has some initial push when steering, not loose at all. I considered taking some rear toe out but at the moment I am running 2 small shims. Would decreasing the wheelbase in the front help? There is 1 small shim on each bulkhead in the front. Thanks guys...
I found on previous brand touring cars I have ran that when I move the front a arms back and shorten the wheelbase that I have more overall steering. 4 degree caster blocks would help (not sure what Rick had on as you might already have them on). Taking rear toe in out will loosen up the car a little and would give you more steering but not sure if you will acutally see more initial steering by taking rear toe in out. You would have to try it to see if you like it.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-12-2009, 01:41 PM   #10188
wyd
Tech Legend
wyd's Avatar
Originally Posted by DaveW View Post
You guys ARE using a tweak station, right? Makes a huge difference. Check it every run.
I use one at home and have one I take with me to the races. I check it every run or two and especially if I take a pretty good hit.
Old 07-12-2009, 01:41 PM   #10189
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
It was OK, still too easy to drive with that push, you would have been right there with me if you didnt break...
Originally Posted by wyd View Post
I found on revious brand touring cars I have ran that when I move the front a arms back and shorten the wheelbase that I have more overall steering. 4 degree caster blocks would help (not sure what Rick had on as you might already have them on). Taking rear toe in out will loosen up the car a little and would give you more steering but not sure if you will acutally see more initial steering by taking rear toe in out. You would have to try it to see if you like it.
I had the wheelbase and width mixed up but that makes perfect sense because NASCAR and Formula car turn well because they arent as long as top fuel dragsters. Its kinda like pushing one shopping cart VS pushing 40 of them...Ill look at what I have and compare it to the other driver sheets. Thanks a ton...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 07-13-2009, 05:32 AM   #10190
Picked up a new TC5 this weekend and would like a setup for 13.5 rubber any one, thank you.
Ramyuras is offline   Reply With Quote
Old 07-13-2009, 06:17 AM   #10191
wyd
Tech Legend
wyd's Avatar
I would start with the kit setup first since it is a new car. Get a feel for the stock setting and then start making changes to fit you. Gives you a base feel of the car before you start changing things all around.
Old 07-13-2009, 07:00 AM   #10192
Questions?? Rolling resistance in drive train
Hi!
I have a simple question for advanced TC5 users
How is drag in drive train?
When I take my tc5 with new clean bearings, belts has got soft tension,
spur and pinion is 64p or 48p with very nice mesh, engine is 9.5T or 10.5T with
low drag (small rotors), and I take front tire (solid axle) and try turn, it give
some drag, I must put more load then I do this with TRF416 or Xray ... (even Serpent S400).
What I fu... up and what's going on?
Last day I have clean car, put a kungfukawaski to GM ESC and engine,
take top end with 80C and others are faster ... Car was fast but ...
Now I got trf416 belt for front, looking for team bomber for rear or 63T from cyclone TC (maybe fit, I know that tc5 at rear has 64T).
Maybe when I change belts it will help or not? Or if help how much?
How much I can got when use better spur and pinion? this time play
with HotBodies/HPI and Edit ... maybe must use better one?
For 1st time I have stock trf416 belt and wait for low friction one ....
Regards!
m.
ps: I'm a little disappointed, got this chassis for 1.5y, put a lot of work and
when meet tamiyaz or xrayz got fuu ... and I don't like it in spec 9.5T/5cell class
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-13-2009, 07:21 AM   #10193
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by M.Abramowicz View Post
Hi!
I have a TC5R and an Xray 009. I can't get the TC5 drive line to run nearly as free as the Xray, I've tried everything, so don't feel bad. Having said that, the TC5 is not any slower on the track than the Xray.
pcar951 is offline   Reply With Quote
Old 07-13-2009, 07:28 AM   #10194
I feel bad because my tc5 is
What do you try with your chassis?
Regards!
m.
Michal Abramowicz
Old 07-13-2009, 10:22 AM   #10195
Default setup
Hi all, yesterday at the Stafford outdoor track, I got my rear end handed to me. I just wasn't fast enough to be honest. I've been looking at setup sheets for what gearing to run, and they're running something like a 100 tooth spur, and 44 pinion! I was running an 87 spur, and went from a 28 pinion to a 30 which increased the speed a little, but resulting in me rolling in some corners. I'd taken practically all the weight off the car as there wasn't any weight limit yesterday, but was running 45g of weight on the battery bar to balance the car out, but my ride height was 11mm just to stop it from spinning out.
I've got two weeks to the BTCC at Stafford, and to make the min weight, I normally need to add about 200g of weight, but I also need to find at leat 2 seconds worth per lap to the next fastest person. Anyone got any suggestions?
www.sldmodels.co.uk
www.rc-kars.com
sldmodels is offline   Reply With Quote
Old 07-13-2009, 10:25 AM   #10196
RFALLON's Avatar
Send a message via AIM to RFALLON
Why dont you lower your ride height? If its spining out check and see if there is tweak and if not find more traction
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 07-13-2009, 10:37 AM   #10197
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by sldmodels View Post
..... but my ride height was 11mm just to stop it from spinning out.
....but I also need to find at leat 2 seconds worth per lap to the next fastest person. Anyone got any suggestions?
Those are some HUGE numbers. 2 seconds is a ton of time to shave from S/U changes.... .5 secs. is a lot.
11mm ride height, my gage only goes to 10...are you running the General Lee body??
I highly recommend you talk to some local racers to help you sort out these issues, there must be another TC5 there. Find a fast TC5 and make a friend.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 07-13-2009, 10:37 AM   #10198
I did, it was spin central. Was trying part of drescher's setup, but didn't set it up all how he had.
www.sldmodels.co.uk
www.rc-kars.com
Old 07-13-2009, 10:48 AM   #10199
Default testing
well I'll look at what I can alter on the car tomorrow, and do some testing later in the week, but I think I need to increase the pinion size to about 32 or 34 too.
Indoors, the car is good, and I normally have a good even battle with one of the people who beat me yesterday outside.
www.sldmodels.co.uk
www.rc-kars.com
Old 07-13-2009, 12:14 PM   #10200
revo61's Avatar
Trader Rating: 18 (95%+)
What motor and carpet or asphalt? Rubber or foam? I run 10.5 geared 32/87 48 pitch on foam/asphalt.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
