Old 07-07-2009, 07:52 PM   #10126
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Would you guys be using a spool on a tight technical track instead of a diff?
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 07-07-2009, 08:05 PM   #10127
geeunit1014's Avatar
What tires/surface are you running?
For rubber/asphalt, you pretty much always run a spool. some people run oneways, but you cant really go wrong with spool
For rubber/carpet, I think its spilt between oneway/spool, depending on many factors (driving style, layout, traction, etc). Again, spool is a safe bet.
for foam/carpet, always run a diff.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-07-2009, 08:19 PM   #10128
Trader Rating: 23 (100%+)
oneway's are the fastest way around a carpet track. well to me and some others.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 07-07-2009, 09:37 PM   #10129
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
I say spool for asphalt low to med grip and diff or oneway for carpet.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 07-08-2009, 01:14 AM   #10130
Hi!
I'm little confused
for asphalt and rubberz solid axle at front (slipper spo,ol)
for carpet and foamz one-way or diff,
for carpet and rubberz which one solid/diff/one-way ?
Best drivers in Poland use solid axle each time for rubber tires on asphalt or carpet, I know only one person who drive on carpet with rubber and diff ...
but he is a little slower then others ...
So ?
Thank you!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-08-2009, 01:28 AM   #10131
Originally Posted by M.Abramowicz View Post
Hi!
I'm little confused
So ?
Thank you!
m.
For carpet using rubber tires you can go on any of them depending on the track layout if it requires a lot heavy breaking and multiple hair pin or 180 you don't want oneway spool is your best bet but with smooth and fast layout diff or oneway is the way to go. Then what it really boils down to is your own driving style if you like late breaking you definitely need a spool and if you like coasting and smooth driving oneway or diff.
Here is the pics of my TCX kit installed on top of home made balance thingy
Team Associated TC5-rc-057.jpg   Team Associated TC5-rc-058.jpg   Team Associated TC5-rc-059.jpg   Team Associated TC5-rc-060.jpg   Team Associated TC5-rc-066.jpg
#1 Sponsor: Wifey
Novice Class
Old 07-08-2009, 01:33 AM   #10132
Thanks for story about fronts.
Btw, I have hudy balance tool and it's stnks better for me is use fishing line and
2 holes in towers
Nice chassis, but I will stay with oryginal tc5.
m.
Michal Abramowicz
Old 07-08-2009, 10:16 AM   #10133
Hi guys, I have a couple of questions about the TC5R. I am coming back to the onroad scene after somewhat of a long hiatus. I was running the Xray T2 before and loved it, but I am now looking for a new chassis to race with. I have been pulling my hair out for the last couple of days trying to decide on which chassis to get. I have chosen this platform due to great parts availability and it seems like a solid car. I was just wondering if there was anything I need to pay attention to during the build or should buy. Also, is the TC5R lipo ready? Meaning will it fit most batteries without modification? Thanks for all your help guys.
--Stan
skinart76 is offline   Reply With Quote
Old 07-08-2009, 11:43 AM   #10134
speedsterblade's Avatar
--Stan
Getting the diff bolt together w/ the nut is a real PITA...be careful or you'll strip out the nut real easy...then be waiting on parts to finish your build. I also has to do some slight trimming on the rear hubs for full clearance on the arms. Belt tightness...the manual's settings didnt work for me..you just have to play w/ the tensioners to get'em right.
I can't think of anything else specific to the tc5, just the typical build stuff...sand & seal the chassis, ensure the suspension components are buttery smooth. ..balance it all out and run it.
Lipos... I've been running smc 5k packs, just taping them in and added lead to balance it all out and help hold the lipo in/keep it off the belts. It clears the top deck by 3-4mm or so but not sure what the height limit is..
Here's on of the lipo plates avail.
http://www.ppdbillet.com/RC_accessories.html
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 07-08-2009, 12:11 PM   #10135
Great! Thanks for the info, I will be sure to be very careful with the diff nut. Can't wait to get my hands on one and join the AE crowd.
--Stan
Old 07-08-2009, 12:22 PM   #10136
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
--Stan
Fit and finish might not be as perfrect as the Xray is but hell for the price you could almost buy two completely new kits for the price of on Luxury Touring sedan from Xray!!!!!!! When my shop gets me parts I laugh at how cheap the parts are.
I have the PPD lipo plate in my car and it fits like a glove. Now for me I went with the Diggity offset lipo battery mount and I used his standard lipo battery mount before I bought the new offset one. This weekend will be my first weekend with the offset lipo battery mount. Will see how it goes.
As with any care just take your time building it correctly and you will be fine. This car does seemingly have more steering than any touring car I have had in the past. I have to get use to that kind of steering as I normally like a slight push in my cars.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-08-2009, 12:44 PM   #10137
Yeah, the pricing and the availability of the replacement parts was what made me decide on this chassis. I want another Xray, but you've said it, at $475 I can get almost two TC5R's for one '009EU. Yes, please let me know how you like the offset holder. I will be running this in the 13.5 class and the tracks are going to be medium size/semi technical tracks. The surface will be on both carpet and asphalt with rubber tire setup. Also, the front spool is an optional item or is it included in the kit?
Old 07-08-2009, 01:10 PM   #10138
pakk's Avatar
Trader Rating: 79 (100%+)
Guys with the TCX chassis,
Please post your results. Let us know if the increased grip is there. I'm still kinda on the fence about it. I'm sure others are too.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-08-2009, 01:35 PM   #10139
Kajman's Avatar
I have a little problem, my front belt is turning upside down (upper part teeth up) very often, any ideas why can this happen?
Back to hobby after years ;)
Kajman is offline   Reply With Quote
Old 07-08-2009, 02:24 PM   #10140
Default TCX
I haven't really mess with mine all I did was balance the car and drive it arount my front yard just from driving around my front yard I can already tell there is a difference on the way it handles it's a more noticeable flex on the rear end and consistent flex on both sides. I will be racing the car this weekend at DHW here in san diego on a prepared asphalt track with low to medium grip. I will be running in a modified class since the class has a less traffic and it will give me more time learn how to drive the car.
#1 Sponsor: Wifey
Novice Class
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
