Old 07-03-2009, 07:46 PM   #10081
grouch's Avatar
I started looking but there is a lot to sift through so maybe someone could help. What is the difference between the Factory TC5 and the TC5R. I understand what the difference between the 5R and 5F but don't see the other. Why is there such a huge price gap? Thanks.
-Jarrett
grouch is offline   Reply With Quote
Old 07-03-2009, 08:34 PM   #10082
Trader Rating: 23 (100%+)
one is old and one is new. the r has a itf chassis and top plate for rubber tire racing, thinner.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 07-03-2009, 08:42 PM   #10083
Originally Posted by mr crum View Post
sway bars take away traction and body roll example put one on the front and it takes away front grip but also keep the car from rolling over which make the car feel tight
I did notice that that would slide when the rear did but I also found it easier to control when it did slide other then just pivoting on the front wheels. My track is med bite at best with both on and off camber corners. The whole track is on the side of a hill.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 07-03-2009, 10:00 PM   #10084
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by pakk View Post
I just picked up a one way for my tc5. There seems to be a lot of space between the one way hub and the carrier bearing. What are you guys doing to clean up this space? It seems like too much to just ad washers.
--pakk
if i were a bettin man i would say u have a oneway from a tc3 which will fit but is much narrower than a tc5 one way
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 07-03-2009, 10:46 PM   #10085
pakk's Avatar
Trader Rating: 79 (100%+)
Well I pulled my tc3 one way out and they are different. The tc3 is a lot smaller. I got this new sealed so it has to be right. When tighten down the caps, the side to side movement is greatly reduced, but there is still some there.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-05-2009, 11:26 PM   #10086
Kajman's Avatar
Edit after cutting previous spam post
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 07-06-2009, 04:25 AM   #10087
Trader Rating: 76 (100%+)
Originally Posted by bertran View Post
FORGET THE TC5! GET THE "AWESOMATIX" WHEN IT COMES OUT!!!
Awesomatix? What kind of name is that? And who are the factory pilots?
MUDVAYNE is offline   Reply With Quote
Old 07-06-2009, 05:15 AM   #10088
It is an Russian car, but it is of interesting design. http://www.awesomatix.com/
I think it's just some that is going 'OMG AWESOME CAR, lets spam RC tech about it'
Old 07-06-2009, 08:44 AM   #10089
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Default tc5 setup
I have been struggeling to get my tc5 to handle well I had it for a race then it went away could anyone tell me where or what pages to look on to find some good asphalt setups. The track I have been running on it old seal coat wairing off and orange soda for traction. I have tried Rick Hohwart's and don't relly like it.
twelvegauge is offline   Reply With Quote
Old 07-06-2009, 10:27 AM   #10090
There is no god setup you must play with chassis
Now, start from this: http://www.rc-setups.com/setups/204/edit (it is
based on Howart's) or got my last http://www.rc-setups.com/setups/209/edit
Car drive easy and rear don't spin out
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-06-2009, 10:45 AM   #10091
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
It is a shaft car that this guys keeps bragging about that has not won anything at any Major race that people here would care about. Keep hearing from this guys how great this car is when it has not results at a MAJOR race, not some National champ from Siberia as that don't count. We want to see it do something at Snowbirds, IIC, The Worlds (this is where it counts for me as the best around are racing here).
ST Racing Concepts (STRC)
Old 07-06-2009, 11:40 AM   #10092
Ahhh, now it makes since.
Old 07-06-2009, 12:23 PM   #10093
Regards!
m.
what do you think about the arm mounts it says to use the #3 mounts all around I had the #2 mounts and it seemed to have more room to play with the suspension. A car I just bought has the #2's on front and #3 on the rear but that was run on carpet.
Old 07-06-2009, 12:28 PM   #10094
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
In order to obtain sufficient suspension travel with the high arm mount position, you must shave 1mm or so off of the shock shaft, ball cups and spring retainer. Once you do this, you will have a good amount of travel.
IIGQ4U is offline   Reply With Quote
Old 07-06-2009, 01:51 PM   #10095
Maybell's Avatar
The FT TC5 parts fall between the R and the F kits. The older FT kit comes with the thick chassis and topdeck, but soft suspension parts. It also comes with 2 plastic diffs. The R and F come with the aluminum units.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
