Old 07-02-2009, 11:25 PM   #10066
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by zake540 View Post
MikeR,
Is there a chance that you would sell the lipo weights and the brackets separate? I would love to install just those items on my ITF chassis.
Maybe eventually. Once demand is met on the lipo chassis.
Ok guys- in stock and ready to ship!!
TC5X LIPO CHASSIS
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-03-2009, 12:05 AM   #10067
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I got mine in today Mike. Thanks. It looks great. I just wish I had a car to put it on.
Jon Kerr is offline   Reply With Quote
Old 07-03-2009, 01:08 AM   #10068
Trader Rating: 27 (100%+)
That Chassis is nice... Does anyone have a good base setup for carpet? And also what does the oneway do?
C_Money is offline   Reply With Quote
Old 07-03-2009, 02:22 AM   #10069
Redwood's Avatar
Originally Posted by TeckLancer View Post
how would i drive the tc5 with a spool compared to a diff on asphalt?
I find that you have to drive with more throttle.
With a diff I would brake before the corner, coast to the apex and then accelerate out of the corner. Nothing special.
With a spool however, your steering comes from what is essentially torque steer. Since you have no diff effect you car doesn't turn well on corner entry, so to make it turn you need to be on the throttle, to get that torque steer.
So I find for best results you should brake before the corner, then instead of coasting to the apex, keep a little throttle on, so that you get steering and then accelerate hard out of the corner. You can get on the throttle sooner as well since you have so much on throttle steering with a spool.
It can take some getting used to, since you need to get the confidence to use throttle mid-corner and find the point which you can accelerate soonest, which is earlier than I expect.
Hope that helps.
Regards
Neal
Redwood is offline   Reply With Quote
Old 07-03-2009, 04:44 AM   #10070
Trader Rating: 76 (100%+)
TC5X LIPO CHASSIS
Mike, I sent you an e-mail last night. My addy is [email protected]. Was wondering if you have had the chance to get to your e-mails yet?
Ken
MUDVAYNE is offline   Reply With Quote
Old 07-03-2009, 07:12 AM   #10071
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
Here is the set up sorry for delay busy at work
ride height 5mm f and r
2degrees of camber front 1.5 rear
6 degree caster
rear hub toe 0 degree
0 degree front toe
rear total toe 3 degrees
hex spacing .5 front and rear
2 mm wheel base f and r
1 and b steering link
2.5 mm bumpsteer
front shock position 1
rear shock position 2
camber links f and r 3
outer ball shims 0 f and 2.5 rear
arm mounts 3 f and r b
droop 6 and 5
1.5 mm roll bar f and r
25 wt oil f and r with losi 56 and full rebound
blue springs f and r
spool front/diff rear loose
let me know if i left any thing out
warren
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 07-03-2009, 08:30 AM   #10072
Trader Rating: 23 (100%+)
visit page 660, second post down.
the best setup, minus the the swaybar.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 07-03-2009, 08:52 AM   #10073
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Originally Posted by twelvegauge View Post
I am looking for a used tc5 to run VTA if you have one for sale let me know, I have the electronics some not so great so if they have the steering servo it's a plus.
I found one thank to all who replied.
twelvegauge is offline   Reply With Quote
Old 07-03-2009, 08:55 AM   #10074
*setup specs*
warren
My setup is quite close to that, is just me but does removing the front sway bar actually increase the speed of the car. I was testing the other day intially it was a spring change, but then I removed the bar and the car became more responsive with more speed and this was noticable with motor temp. Since then I have changed rear wheelbase from 1mm to 0mm hopefully that'll improve things.
Hopefully I can do better then 4th on my second clubbie, I finished 4th overall with the first club race that I ran my TC5 in.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 07-03-2009, 08:58 AM   #10075
MikeR's Avatar
Enjoy! Thanks for your support.
Ken
Got it , replied, thanks!
Old 07-03-2009, 09:52 AM   #10076
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Originally Posted by Kajman View Post
Put diff and try, I always have beed driving diff. Since I bought spooled tc5 I learn to drive it this way as I hear nobody more drives 2 diffs. There has to be something in it...
Hope that helps.
Regards
Neal
Nobody at my track runs a spool. It is a very tight and tech track. Would I be better off chasing their setups or running a spool and start with a pros setup? I am tired of fighting the car but dont have time to experiment too much...we race every other week at a Hobbytown and have 30 minutes of practice before the heats...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 07-03-2009, 12:12 PM   #10077
mr crum's Avatar
Send a message via Yahoo to mr crum
sway bars take away traction and body roll example put one on the front and it takes away front grip but also keep the car from rolling over which make the car feel tight
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 07-03-2009, 02:15 PM   #10078
mr crum's Avatar
have any of u guys ever broke a shocktower where the ball stud for the camber link gos it didnt break but it looks like the cf delaminated
TEAM B.R. RACING
Old 07-03-2009, 03:43 PM   #10079
pakk's Avatar
Trader Rating: 79 (100%+)
I just picked up a one way for my tc5. There seems to be a lot of space between the one way hub and the carrier bearing. What are you guys doing to clean up this space? It seems like too much to just ad washers.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-03-2009, 07:19 PM   #10080
--pakk
didnt notice that much space in mine.
Mike Adamec
Trackside Hobbies
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
