Old 06-19-2009, 06:51 PM   #9856
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Originally Posted by mr crum View Post
one quick fix that makes the most diffrence is rear toe atleast 3 degrees or even 3 1/2 per side rear toe in
Ok, I have that already I guess I will just try every thing till I get what it how I want it thanks.
twelvegauge is offline   Reply With Quote
Old 06-19-2009, 08:16 PM   #9857
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by MikeR View Post
Hi Jon,
Back to blue? You've gone full circle! Hold off on any carbon chassis purchases if you are running lipo. I have something very interesting releasing next week! See me this sat.
i hope your talkin about that sweet exotek lipo chassis i saw at my local track very impressive
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 06-19-2009, 08:24 PM   #9858
Mark506's Avatar
Trader Rating: 41 (100%+)
Anyone aware of any company's making TC5 chassis for carpet or such? I don't know of any, and that's kinda surprising that BMI of CEFX hasn't step up and made a thinker one considering the popularity of the car. Just a though.
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 06-19-2009, 09:16 PM   #9859
I thought thats why the F existed, optimised for carpet.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 06-19-2009, 09:45 PM   #9860
geeunit1014's Avatar
You gonna be @ the East Coast Race of Champs @ Jackson?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-19-2009, 09:52 PM   #9861
Originally Posted by not home View Post
Question for you guys, what aluminum washer are you guys running behind your motor screws? i got a new motor mount today and i dont wanna mess this one up. if you could show me a link or a part number that would be great.
thanks.
hi!
Just use this:
http://67.199.85.166/main/productdet...ory=4016.tc5xx
For 5months after change motor mount, I don't have problem
Regards,
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-19-2009, 10:11 PM   #9862
Trader Rating: 23 (100%+)
used those, when im wrenching on them they are it up. im using the stock b4 ones, cap head ones.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 06-20-2009, 03:10 AM   #9863
Default Washers on motor screws
I does not matter what type of washer you use as long as they fit in the slot and the screw goes through the hole.
The obeject is to protect the aluminium from the chewing of the screw as it tightens and also to reduce the tendency for the motor to move as you tighten.
I use steel washers and they are fine. Do not use spring washers.
regards
Don
donwhit is offline   Reply With Quote
Old 06-20-2009, 07:42 AM   #9864
I should probably use some washer as I'm using a couple of the short black non-countersunk screws for the motor.
But I found a problem with running a 69 spur gear, it rubs on the upper deck.
Arrow points to where the rubbing accurs, all I did to fix this problem was to use a bench grinder and some rough sand paper to remove some of the upperdeck to stop it from hitting. At a guess with a 70/71 spur probably won't rub.
Old 06-20-2009, 08:08 AM   #9865
Mark506's Avatar
I would deff. Just switch to 64 pitch. It's so much easier to work with, and more ways of tuning for speed. And the spurs are more narrow, and shouldn't rub.
Mark Ament
Old 06-20-2009, 08:43 AM   #9866
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I run 48 pitch and had the same problem. I just lightly sanded the topdeck a little like you did and then I respaced out my topshaft. I took the thick silver alum spacer off (roughly 2mm thick) and used two 1mm ones on each side of the layshaft and it moved the gear over ever so slightly. Now it won't ever rub and my driveline is just as smooth or mabe a tad smoother than before so it was a win win overall.
With the new speedos out gearing with 48 pitch is not a problem unless you run the first generation brushless speedos where you need to really gear motors hard to get the speedo you need.
Nice thing is they run smoothly and have a little more room for error without strpping a gear. The other great thing is thos 48 pitch spurs like you have on are really cheap and will last a very long time.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-20-2009, 09:03 AM   #9867
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
I have been thinking about switch ing to 64 but I dont want 40 gears rollin around my box, Ill wait till I switch to brushless
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 06-20-2009, 09:22 PM   #9868
transplantlife's Avatar
Trader Rating: 43 (98%+)
hey guys im a newbie to onroad more into nitro off road plz no bashing!!!! wanted to ask i jus picked up a tc5r plan to run indoor carpet what mods are you guys doing.... ive heard of guys running losi cvd's to save weight at 4 corners???? tamiya belts for smoother operation???? different motor mount for better meshing???? even tho i probally couldnt tell a difference ... have any you guys tried any of the mods i stated also was looking for a base indoor carpet set up thanx for your time.
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 06-20-2009, 10:53 PM   #9869
Rdog's Avatar
Trader Rating: 83 (100%+)
Im not sure about those mods but as far as set up for carpet search this thread for Josh H's setup not sure oh the last name spelling but its dialed
Rdog is offline   Reply With Quote
Old 06-21-2009, 04:27 PM   #9870
yeah mike i'll be there for sure
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
