Old 06-13-2009, 10:13 AM   #9781
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I actually run the solid spool and haven't really experienced any issues. Be sure that you are ready to inspect after any impacts to avoid damaging the outdrives.
IIGQ4U is offline   Reply With Quote
Old 06-13-2009, 11:14 AM   #9782
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 47 (100%+)
I am getting a new in box TC5(not R) pretty cheap and plan on using it for VTA. Does anyone have a good setup and build options I should look into getting as I build it? It will be run with a Tekin RS /21.5 combo and Checkpoint LiPo. Thanks.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 06-13-2009, 10:03 PM   #9783
Trader Rating: 23 (100%+)
What front and rear pully's are being used on the tc5 pictured in the link below? Thanks
http://edseb.smugmug.com/gallery/853...61902792_EbKje
bmcallister is offline   Reply With Quote
Old 06-14-2009, 01:19 AM   #9784
Originally Posted by mr crum View Post
the tc5 takes bone blades on the pins for the diff that is the week point and since the diffs are aluminum and the cvds are hardened steel u can figure which will wear so thats y they use bone blades the tc4 didnt use these thats y u can get away with a solid spool
So are the bone blades a good thing to get? My kit was the FT and it doesn't come with them. Something has gotta give when it comes to comes to wear and tear, it's normal for cars both 1:1 and 1:10 have parts that gotta be replaced more often then others.
Has anyone tried using the TC4 cvd's in a TC5?
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 06-14-2009, 04:16 AM   #9785
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I run the bone blades on my TC5 with the alum rear diff and the alum front spool and really like them. Been running 17.5 and 13.5 for weeks and the bones look great. Cheap and easy to replace
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-14-2009, 04:27 AM   #9786
wyd
Tech Legend
wyd's Avatar
Been running the TC5R for a few weeks now. I must say I been out of touring for a few years but after running the car for a few weeks I find it really steers well most of the time. So much so that this week on the outdoor track I was at even with good tires I had mad steering.
Car seems a little on the stiff side with #57 pistons and 35wt oil in it with Assoc blue front springs and Assoc silver springs. I run 2A roll center blocks all the way around. Car overall seems just a little bouncy of the some of the rough stuff compared to others at are track. Need to work on that a little but as well.
Wonder if it is better to use Associated #2 pistons and 35 instead if they are overall just at touch softer. Still messing with the car and learning it so next time out a few more changes and see what happens. Been fun so far.
Old 06-14-2009, 06:06 AM   #9787
Trader Rating: 76 (100%+)
If it's a pic of a team drivers car, it might be something that they could be testing. Or maybe they're white because someone is trying the yokomo diff pulleys. I'm pretty sure the front belt off the Yokomo car fits the TC5, why not the pulleys too? Someone correct me if I'm wrong about this.
MUDVAYNE is offline   Reply With Quote
Old 06-14-2009, 06:11 AM   #9788
Default 4 deg vs 6 deg front caster
What effect does changing the front caster fron 4 deg to 6 have on the car?
Cubic$Racing is offline   Reply With Quote
Old 06-14-2009, 06:15 AM   #9789
S_fender's Avatar
Rick or anyone at AE who can answer,
Can we hope to see the motor modification available soon ?
Thanks.
Sebastien.
S_fender is offline   Reply With Quote
Old 06-14-2009, 07:12 AM   #9790
wyd
Tech Legend
wyd's Avatar
4 degree blocks have more steering entering the corner and a little less middle exit steering on power. 6 degree blocks are just the opposite. A little smoother on off power entry steering and more middle/exit on power steering.
I found on really high bite tracks 6 degree blocks are smoother to drive but most of the tracks I go to are medium traction where 4 degree blocks work better.
Old 06-14-2009, 07:22 AM   #9791
Where did you race yesterday and how was the car?
Old 06-14-2009, 07:26 AM   #9792
Suspended
Have you noticed the ball joints as well on the diff caps...
Would be interesting to know what sort of difference these make
Nick Priest is offline   Reply With Quote
Old 06-14-2009, 07:30 AM   #9793
wyd
Tech Legend
wyd's Avatar
Trains and Lanes on a medium grip track. Car wasn't too bad but I did have mad on power steering that would rip the back end where ever I wanted it to go. I was working on getting more rear traction.
I'm going ot order the Diggity offset lipo tray as that will balance out my car even more and expect will help with the overall smoothness of my car. Its still a work in progress and I didn't barely scratch the surface of the things I want try try with the car yet but over the next few weeks I will be going back to T&L to work on the car. Going to Frederick is nice but with the high traction it don't really help me when other than that track most don't have near that kind of traction so learning about getting traction in the car don't really do me any good.
Overall still very happy with the car, I just need to learn what it wants vs some of my other cars I had. Plus running brushless just adds to learning setups even more for the car so I have a different learning curve now than I was use to when I quit running touring almost 3 years ago.
Old 06-14-2009, 07:39 AM   #9794
Camber link position maybe?
Thats cool. I willing to bet that you didn't run the blue tires yesterday either. I totally understand about Frederick. Lots of traction there. I remeber almost walking out of my shoes going to my turn marshalling position at the last sedan challenge I went to. I'll give you a call this week. There is some material I got for the cutters that we use at work for touchless car bra's and I think it might be beneficail to our cause. I'll be home today if you wanna call.
Old 06-14-2009, 08:03 AM   #9795
You mean the silver ones on the bulkheads?
I was surprised to see the associated ball cups. I hate those things. So crappy/flimsy. I like to think I'm fairly gentle with these and I broke 2 in the first month, just working on the car (not even racing). The RPM ones feel so much stronger and have less play.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
