Old 06-08-2009, 07:19 AM   #9736
Originally Posted by Sean Cochran View Post
The original TC5 comes with "stiff" 2.5mm chassis and upper deck, the R comes with the ITF 2.0mm parts. Also the TC5 come with plastic diff outdrives, the R uses alloy with the option of the slipper spool.
Cheers for the info, R sounds good just for the alloy outdrives. After seeing the wear on the alloy outdrives on my TC4 I'd hate to imagine the plastic ones. Strength isn't a problem as car breakege is almost non-existant for my class.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 06-08-2009, 09:05 AM   #9737
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Jason Turner View Post
Okay guys I bought the ITF chassis and mounted it sealed it ran it and now noticed that it's one of the ones with the counter sunk holes too big is there anything I can do about it?
Can it be replaced?
Is it okay that way?
Or can I fix it somehow?
i sent mine in with the upper deck numerous weeks ago just happened to call them today and they said they would get to it today i think the quality control needs to be stepped up a notch considering i paid for the chassis and upper deck a while ago and also spent lots of time glueng the chassis till it looked like glass ae get it together and make sure thunder tiger gets it right the first time been running ae cars for years and noticed a drop off in quality control since tt took it over
weavernator out
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 06-08-2009, 09:39 AM   #9738
Valkman's Avatar
Hey guys - new to RC Tech, I've been racing a TC5 for about nine months now and it's been a great car. I've read just about every page of this forum and thought it was time to chime in.
Just changed to Rick Hohwart's '08 World's set-up three weeks ago. I run rubber tires on a medium grip asphalt track in MI - Lazer Speedway (Hey Russ and Leslie !!), this setup has been great !!
Made a few changes mainly to shorten the wheelbase because we have a couple of tight 180's, but the car handles and responds fantastic. Running the diffs and a-arms all the way up looked a little strange at first but I think this is the best set-up I've had on the car yet.
Looking forward to helping out where I can and learning from the best !!
Lazer Speedway / Woodville Mall
Associated TC5R/TC5F
Trinity Duo's by Express Motorsports
Sorex SJ-R's by Speedworld Hobby
Paint by Splat Graphics
Valkman is offline   Reply With Quote
Old 06-08-2009, 10:17 AM   #9739
Trader Rating: 76 (100%+)
weavernator out
Sounds like what happened to Losi when Horizon took over. When I bought my first JRXS it literally fell together. When I got the type R, nothing fit right, parts molded wrong, etc.
MUDVAYNE is offline   Reply With Quote
Old 06-08-2009, 11:38 AM   #9740
I'm setting my car up with the Rick's worlds 2008 setup. I'm a little confused with the droop settings. Since the ride height is 5mm both front and back. He's listing front droop as 7 and rear as 6mm. I'm assuming 2mm over RH in the front and 1mm or RH in the rear?
home13oy75 is offline   Reply With Quote
Old 06-08-2009, 12:09 PM   #9741
mo
mo's Avatar
No, those numbers refer to numbers on the droop gauge. It will change depending on the tires you are running but if you go 1mm above rh in the front and 2mm in the rear you should be good.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-08-2009, 02:44 PM   #9742
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Hey guys, when measuring droop...is it correct to have the tires off, take the shocks and sway bars off and use a ride height gauge under the furthest end of the arm? With the chassis on a flat surface. Thanks...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 06-08-2009, 03:54 PM   #9743
mr crum's Avatar
Send a message via Yahoo to mr crum
yes but i leave the shocks on
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 06-09-2009, 01:32 AM   #9744
Like this:
#3987 Droop Gauge. Supplement to the manual
http://aedownloads.com/downloads/ins...droopgauge.PDF
Detach shocks and sway bars.
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-09-2009, 04:33 AM   #9745
Originally Posted by M.Abramowicz View Post
Like this:
Regards!
m.
So if I'm understanding this correctly, the higher the number on the gauge, the less droop you will have?
Old 06-09-2009, 05:20 AM   #9746
Yes. Higher a-arm (downstop) -> less droop, lower a-arm -> more droop.
Hope it helps.
m.
Michal Abramowicz
Old 06-09-2009, 06:13 AM   #9747
Valkman's Avatar
Default Rear Suspension Adjustments
Hey guys, just wanted to hear your thoughts on some rear suspension adjustments.
1. Rear hub camber position A vs. B, what differences would you expect and when would you run one or the other ??
2. Rear hub toe, what's the real difference between running 3 degree rear toe with arm mount shims vs. let's say 2 degrees with the shims and another 1 degree @ the hub ?? Same thing, what difference would you expect and when would you run ??
These are a couple minor adjustments I've thought about recently that are really not covered in the XXX Main set-up book.
Thanks,
Old 06-09-2009, 06:34 AM   #9748
raven101's Avatar
Send a message via MSN to raven101 Send a message via Yahoo to raven101
Default tire issue
well i had another race this past sunday with no problem blowing my tires off. i changed from Jacco 27 to takeoff 30's and they seemed to grip better and hold my line even tighter. i was in 1st place in the main untill i lost a thumb screw for the battery hold down and had a lipo go sliding across the track. which ended in a 3rd place finish. oh well looks like i need to invest in some strapping tape or a lipo tray, or maybe both.
associated tc5r, academy sb v2, associated tc6, tekin,
castle creations, orion, novak, reedy. lets all have fun. support your local hobby shop, and dee and mee if its not local.
raven101 is offline   Reply With Quote
Old 06-09-2009, 06:56 AM   #9749
trdsupra88's Avatar
Hope it helps.
m.
Thanks a ton!!!
I never had a pack come out but my F-ing fingers would be hurting after a race from the thumb screws. Ive since been using tape and I love it...give it a try...
I cut my own hair ☆
Old 06-09-2009, 06:58 AM   #9750
adamge's Avatar
Good to see I'm not the only one who realizes the droop gauge might be the worst way to measure an R/C car ever invented.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
