Old 06-05-2009, 01:59 PM   #9706
Originally Posted by M.Abramowicz View Post
Hi!
In my setup: http://www.rc-setups.com/setups/198/edit
I have F drop about 2mm and rear 2.5mm
Hope this helps!
m.
I have sent you a PM
Cubic$Racing is offline   Reply With Quote
Old 06-06-2009, 01:12 AM   #9707
Rdog's Avatar
Trader Rating: 83 (100%+)
Hey guys I just picked up a TC5R and am having a very hard time trying to get the diff's to tighten up. Its like the trust screw is too short or somthing. I was just wondering if any of you guys had any similar problems or maybe im just doing somthing wrong? Any help or advice would be great. Any yes I have compressed the diff spring and all that kind of stuff.
Rdog is offline   Reply With Quote
Old 06-06-2009, 02:06 AM   #9708
Hi!
Have you push lock nut into plastic part to the end ?
I have alu diffs made from plastic version (foam kit), I only replace outdrives for alu one and I don't have this problem :-)
I don't have oryginal diff set from tc5r, maybe from foam kit screw is longer then R version.
Regards,
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-06-2009, 03:44 AM   #9709
Default TC5 diff screw
The good news is - you're not the first to have this problem.
First make sure that the nut is fully pressed into the black plastic T-nut.
Next, you need a bar of a size to go in the slot and press against the T-nut.
You then need enormous force to press down on the driver to compress the spring enough to start the thread. The bar stops the T-nut from moving.
I hold the bar in a vice and use my whole weight to press down.
And your problems aren't over yet.
Be VERY careful when you tighten the nut to set the diff adjustment.
It will strip the thread very easily. Make sure you have a spare nut to hand.
HTH
Don
donwhit is offline   Reply With Quote
Old 06-06-2009, 06:44 AM   #9710
Trader Rating: 62 (100%+)
Randy if you can't get it bring it to FW tomorrow or come up north today I'll be racing at Lowes
The Wease is offline   Reply With Quote
Old 06-06-2009, 07:18 AM   #9711
Someone advised that I use Associated part #6575 T-Nut & Diff Bolt and I did. With this part the diff went together without any problems or frustrations. It is a simple fix for anyone that is having trouble putting the diff together.
Old 06-06-2009, 04:33 PM   #9712
Will a motor run cooler with 64 pitch vs 48? What's the advantage of 64
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 06-06-2009, 06:59 PM   #9713
mr crum's Avatar
Send a message via Yahoo to mr crum
the biggest diffrence is that u can find more intricate gearing the gear value of 48 changes alot just by adding one tooth
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 06-06-2009, 07:59 PM   #9714
Trader Rating: 23 (100%+)
if your a stock racer like me and keep eating 88t 64p gears for no reason at all, it is very hard to find a pinion being somewhere like a 39t (what im running) and a small spur in 48p because generally it isnt needed. apparently 64p is smoother but quieter.
would anyone know why i keep eating spurs? i had paul lemieux mesh the gear for me and it still go eaten up, along with a few other people because i thought it was me. i changed pinion gears too incase that may have been a factor too along with the spur gear hub. its kinda funky for this to happen.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 06-06-2009, 10:52 PM   #9715
mikel33's Avatar
Trader Rating: 2 (75%+)
I chewed up a couple because the mesh was too loose, but mostly its when I hit something hard enought to move the motor.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 06-07-2009, 01:22 AM   #9716
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Q, Do you guys find tweak a problem with TC5R's ?
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 06-07-2009, 02:15 AM   #9717
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
When I got my TC5R used from a buddy of mine they had some spur gear problems. The topshaft had some side to side play in it and that is whey they kept chewing up spur gears. Check to make sure you top don't have any excess play in it. I know my car has zero slop in it.
Another problem I hactually have when messing my gears is my motor mount is worn from the motor screws and gets dented up and then when you try to tighten up the motor it moves around while tightening since the motor mount is screw holes get a little chewed up. Nice thing is the motor mount is really cheap.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-07-2009, 07:31 AM   #9718
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
My motor mount use to do that till I use that blue alluminum spacer as a washer for the motor mount.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 06-07-2009, 07:52 AM   #9719
make sure the nut is all the way in and you either make one of this tool or buy one I'm not sure if they still make it instead of using allenwrenches I made one myself to make my life lee miserable when rebuilding my diffs.
GOODLUCK!!!
#1 Sponsor: Wifey
Novice Class
Old 06-07-2009, 07:56 AM   #9720
mr crum's Avatar
go to ur lhs get a t nut and thrust screw for a rc10 t3 off road truck and u will have zero problems
TEAM B.R. RACING
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
