Old 06-01-2009, 06:57 PM   #9646
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Even though this pic is way to bright, at least it will add some color to the TC5 thread, .
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 06-01-2009, 08:04 PM   #9647
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Originally Posted by Rojna View Post
You should START with the spool, not leave it for last, as it will help you a lot.
Also try adding more drag brake to your esc, that will transfer more weight off throttle and add more steering coming into the corner
Cool thanks...there are about 10 guys in the expert class and most of them use diffs and Ive matched their setups as close as I can...I run brushed motor so I have a good amount of drag brake...they say the track is too small to use a spool...I never gave it a try because of this but all the driver sheets from the pros use it...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 06-02-2009, 02:06 AM   #9648
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
anybody have juho's and rick howarts 2009 reedy race set ups?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 06-02-2009, 03:02 AM   #9649
Redwood's Avatar
What camber are you running? I find my car is quite sensitive to small camber changes. Also are you running around 3* rear toe in? If so you can try adding some toe out to the front, 1* max, that gives a little more steering at the cost of some stability and straight line speed.
Did you check your droop? It is one thing that is not obvious from checking other people's cars, and is often overlooked but if there is not enough rear droop then the car cannot rise in the rear to shift weight to the front, and will effect your steering (off throttle) and likewise with too much droop up front (on throttle).
Correct me if my thinking is backwards, that seems to happen a lot.
Regards
Neal
Redwood is offline   Reply With Quote
Old 06-02-2009, 06:57 AM   #9650
trdsupra88's Avatar
That makes perfect sense, Ive tried 2*, 1 1/2* and 1* all arouns and the same for rear toe and it seems to handle the same either way...thanks
I cut my own hair ☆
Old 06-02-2009, 07:11 AM   #9651
mo
mo's Avatar
I ran the same setup that Rick did. You can find my setup on my site at www.mo-net.ws under car setups. Juho ran something a bit different. I'm sure they will put it up on www.rc10.com eventually.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-02-2009, 07:29 AM   #9652
nice
elementforlife is offline   Reply With Quote
Old 06-02-2009, 07:49 AM   #9653
Hi mo!
I have questions :-)
- how do you set drop?
( like this ? #3987 Droop Gauge. Supplement to the manual
http://aedownloads.com/downloads/ins...droopgauge.PDF)
- have foam in top of shock (bladder) ?
- total weight?
- chassis was balanced R/L ?
- chassis lean nice when you pass corner ?
Your setup is almost like my based on old Rick Howart ...
Regards!
m.
ps: sorry for my English I try do my best )
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-02-2009, 07:51 AM   #9654
Default No foam in shocks
I have noticed some set-ups that state no foam in bladder. What effect does removing the small and/or large foam pieces in the shock have?
Cubic$Racing is offline   Reply With Quote
Old 06-02-2009, 07:55 AM   #9655
Hi!
I removed large foam and set rebond for about 40-45%, shock work smooth and
and main job is done by spring, suspension is softer. I must play with shocks
for same speed for uncompress (compress shock and watch how fast piston back).
Hope this helps!
m.
Michal Abramowicz
Old 06-02-2009, 07:59 AM   #9656
Originally Posted by M.Abramowicz View Post
Hi!
Hope this helps!
m.
Michal,
I am experiencing a lack of rear traction that I cannot get a handle on. Would removing the foam in the shock help or make that condition worse? And would I remove it in both the front and rear shocks?
Old 06-02-2009, 08:04 AM   #9657
mo
mo's Avatar
Hi mo!
- total weight?
Regards!
m.
Droop- Yes, just like that PDF.
Bladder- No foam
Total weight- 1508g
Chassis Balanced R/L - yes
Chassis lean- The chassis rolls a lot in high speed sweepers but it doesn't drive like it's leaning too far. My motor is quite scratched up from 2 large right turn sweepers that were on the Reedy layout.
Old 06-02-2009, 08:16 AM   #9658
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Those instructions for setting droop are simply downstop aren't they? I thought that droop was considered uptravel which is measured over ride height.
IIGQ4U is offline   Reply With Quote
Old 06-02-2009, 08:25 AM   #9659
Yes!
You have right! When I set my setups I always wrote about gauguage,
usually I have 2mm drop at front and 2.5mm at rear, it depends on spring preload, for my chassis I set it for F about 3mm and rear 2mm :-)
Regards!
m.
Michal Abramowicz
Old 06-02-2009, 08:27 AM   #9660
IIGQ4U's Avatar
^^^ Those numbers make more sense to me.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
