Old 05-26-2009, 09:02 AM   #9601
Redwood's Avatar
Originally Posted by Nick Priest View Post
Titanium Racing products are shit.
Yes that is from experience
Good to know before I bought anything off them. Could you elaborate on what exactly went wrong? I know there were a few problems with people not receiving things but there are some others that are quite happy with them.#
Regards
Neal
Redwood is offline   Reply With Quote
Old 05-26-2009, 10:16 AM   #9602
John_S's Avatar
I had a shot of a tir sppol and the quality was a bit pants. The driveshaft pins stick in the spool outdrives and make the suspension travel sticky. On a previous car with new tir driveshafts they gave the car about 3 degrees of camber change because the axles were to small to fit in the bearings properly. Would never touch them again tbh
John_S is offline   Reply With Quote
Old 05-26-2009, 10:30 AM   #9603
Redwood's Avatar
Thanks for the heads up.
Their stuff looked good when I went to the site, but actually the very reasonable prices made me think twice.
I have the associated alumnium spool at the moment, a few runs in a bone blade came out and tore up the outdrive a little. I bought a ton of blades after that, but the next meeting out, they lasted all day, no problem. Although I managed somehow to lose all 4 screws attaching the pulley to the axle! Just gone, no damage, I replaced them and loctited them and it was fine.
What spool do you run? I saw the JAAD one sale and it looked to be the same design as the TiR version, anyone have any experience with that one?
Regards
Neal
Old 05-26-2009, 10:33 AM   #9604
John_S's Avatar
I run a slipper spool with the pads glued to the outdrives for less slippage
Old 05-26-2009, 10:53 AM   #9605
Originally Posted by Redwood View Post
.... I bought a ton of blades after that, but the next meeting out, they lasted all day, no problem...
The blades will usually only snap when you hit something on power, that is why they are there ... better to snap a blade then a outdrive or dogbone
Rojna is offline   Reply With Quote
Old 05-26-2009, 12:21 PM   #9606
Regards
Neal
Hi Neal,
I have run the Jaad Spool in my Yokomo BD for a season indoors and outdoors and as long as the outdrives are greased it holds up well.
Bryan D is offline   Reply With Quote
Old 05-26-2009, 03:04 PM   #9607
nutsisneat's Avatar
I tried the Jaad, the TIR and the original spool.
The jaad is by far the best, but it's very hard to get spare outdrives (almost impossible). If somebody knows a shop which ships internationally please PM
TIR is crap, two of three threads were already worn out when i assembled it the first time.
Original is in the middle, i think not suitable for modified racing imho
nutsisneat is offline   Reply With Quote
Old 05-26-2009, 03:48 PM   #9608
Redwood's Avatar
Originally Posted by Bryan D View Post
Hi Neal,
Thanks for the info. How often do you have to replace the outdrives on the JAAD? I found them here: http://www.muchmoreracing.com/store/...oducts_id=2883 however they only sell to trade, so getting your hands on them might require some emailing around different UK hobby shops, nightmare.
Regards
Neal
Old 05-27-2009, 02:20 AM   #9609
Jason Turner's Avatar
Trader Rating: 64 (100%+)
What do you guys think of my build?
Anyone else run there transponder here? If so any problems?
Jason Turner is offline   Reply With Quote
Old 05-27-2009, 05:11 AM   #9610
Redwood's Avatar
Looks like a nice build, wish mine was still that shiny.
I have turned my lipo around so that the connectors are at the rear of the car, makes the wires shorter and neater in my opinion, although I never see others doing that, maybe there's a reason that I overlooked.
How is it for left to right balance and total weight, I had to ballast a good 100g AFTER getting the left to right done.
Regards
Neal
Old 05-27-2009, 09:39 AM   #9611
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I have my personal in the same location as yours.........right in front of the lipo. Works well for me in that location.
ST Racing Concepts (STRC)
Old 05-27-2009, 09:51 AM   #9612
My wires are in back as well.
I also attached a strip of lead to the outside of my LiPO like Jason did. I've got a fairly light Tekin 3400 power cell, and a strip that is the length of the LiPO is not enough. I'm waiting for some cheap scales to arrive in the mail.
Jason, the thing that sticks out to me about your build is the transponder wire. Is it somehow mounted to the chassis so it won't hang off the left edge or get caught in the bellcrank? It looks like it is, but I can't tell how.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 05-27-2009, 09:51 AM   #9613
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Looks good. I would remove the blue rings around the screws on the upper deck. Removing them will reduce chassis tweak. The rings don't allow the screws to fully seat and upon impact can cause the car to hold a tweak.
IIGQ4U is offline   Reply With Quote
Old 05-27-2009, 10:05 AM   #9614
John_S's Avatar
The rings are required when using the upper deck flex kit
Old 05-27-2009, 10:11 AM   #9615
IIGQ4U's Avatar
They cause tweak. I would rather have a car that is consistent than one that is going to tweak anytime there is contact. I used to use them but I don't any longer. The car has sufficient flex without the rings anyway.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
