Old 05-23-2009, 02:35 AM   #9571
John_S's Avatar
Originally Posted by Hyde View Post
I've read here that people take off a motor mount mounting screw?
Which screw is that? The one that goes in the bulkhead or the front chassis screw?
Its the screw that connects the motor mount to the rear bulkhead
John_S is offline   Reply With Quote
Old 05-23-2009, 11:10 PM   #9572
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Hey guys, I am looking for a little set-up help...I cant get my car to stop pushing...I have the problem in every part of every corner, on and off power. I have the same chassis setup as most of the expert drivers at my track and cant seem to get it right. I am running rubber tire outdoor on smooth asphault sprayed with soda.
I have silver springs and 45w up front and have tried blue and green with 40wt in the rear wich is what everyone else is running. I have the droop set at 5mm all around and 5mm ride height in front and have tried 5 and 5.5mm in the rear. I am running 36rs which seems to work for everyone else. Brushed 27t. Chassis balanced with equal amounts of weight in the front and rear of the battery side. 6* caster. I have gone from 1* to 2* camber front and rear and .5* to 3* rear to and 0 front toe.
When I first set the car on the track with clean tires in hooks up great for a lap than starts fading and feels like plastic tires up front after 3 laps...
Thanks for any advice you can give, Joe.
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 05-24-2009, 12:57 AM   #9573
KennyClark's Avatar
Try 4 deg caster.
Move your rear shocks to a more upright position on the mount and try running the front shocks on the inner most hole on the mount and outer most hole on the wishbone.
-2 camber all round.
I always run with 2 deg inboard toe in at the rear with 1 deg hubs which helps the car rotate a bit better.
When using the spool I run 1 deg toe out in the front.
In the shocks try the losi black pistons with a tamiya diaphragm and no rebound foam.
Droop 6 front and 5 rear.
5.5mm rear ride height and 5mm front.
I have been running HPI Blue rear spings and HPI Silver fronts recently which I have liked.
Muchmore
Team Durango
KennyClark is offline   Reply With Quote
Old 05-24-2009, 01:14 AM   #9574
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Which 36Rs are you running and what are the temps of the track? It sounds like you may be lacking overall grip.
IIGQ4U is offline   Reply With Quote
Old 05-24-2009, 09:54 AM   #9575
trdsupra88's Avatar
Thanks Kenny Clark, I am running the Speedmind premounted Sorex 36s...The first heat was about 105* and the main was about 80* but the car felt the same all night.
I cut my own hair ☆
Old 05-24-2009, 06:30 PM   #9576
ctg1129's Avatar
Originally Posted by Chuckyluv View Post
why not run a rubber band and twist it till it almost breaks!!!!... I hope you find a combination here that we will all try and maybe run out of town
chucky you know i only use the bread ties on the nitro heli
ctg1129 is offline   Reply With Quote
Old 05-25-2009, 01:45 AM   #9577
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
i always thought it was the front screw on the chassis ... wrong again! anyway, what does removing the screw connecting the motor mount to the bulkhead do?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 05-25-2009, 02:55 AM   #9578
Originally Posted by xtrememadness View Post
hey guys i had the same problem. there was a bad batch of chassis and associated knows about it. i sent mine back and they sent me a replacement and it was perfect
I haven't seen a lot of people mention this, but I figured I'd add that I haven't had any luck contacting Associated. I'm guessing they were busy last week preparing for the Reedy Race, but multiple phone calls to customer service went unanswered (I was on hold as the #1 person in line for 10+ min each times). My voicemail also went unanswered and I tried faxing them a form last Friday (near the end of the day).
Did you have to mail your chassis back for them to send a replacement? At this point, I'm kinda frustrated. QC and customer service have cost them the sale of a B44. I'm gonna end up buying a ZX-5 or D4 for off-road.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 05-25-2009, 04:54 AM   #9579
Redwood's Avatar
I have tried both removing the bulkhead screw and the forward motor mount screw and I think it's a better idea to remove the forward motor mount screw that screws from beneath. Someone pointed out that removing the bulkhead screw might cause havok with you drivetrain since the pinion can separate from the spur slightly which I have to concede might cause problems at high cornering speeds.
Regards
Neal
Redwood is offline   Reply With Quote
Old 05-25-2009, 06:28 AM   #9580
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Does anyone make an aluminum spur gear holder for the TC5 instead of the plastic one that comes stock for the car?
ST Racing Concepts (STRC)
Old 05-25-2009, 06:30 AM   #9581
mr crum's Avatar
Send a message via Yahoo to mr crum
i seen one but its from that europe company that people have trouble getting there orders sorry bout the name i forgot it
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-25-2009, 06:32 AM   #9582
wyd
Tech Legend
wyd's Avatar
Thanks. I guess I will have to have a buddy of mine make me a one then.
Old 05-25-2009, 09:19 AM   #9583
stonedgti's Avatar
Trader Rating: 15 (100%+)
TOP racing makes one. I've been using it for a year now, and it's very good.
http://www.topracingusa.com/
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 05-25-2009, 11:16 AM   #9584
wyd
Tech Legend
wyd's Avatar
Thanks. I just emailed them to see if you have any in stock. Appreciate the info.
Old 05-25-2009, 01:36 PM   #9585
Jason Turner's Avatar
Trader Rating: 64 (100%+)
I have never heard of any problems like this for the B44 it's made by AE I heard the TC5 is made by someone else so maybe thats why?
Jason Turner is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
