Old 05-21-2009, 06:39 AM   #9556
Suspended
For anybody in the uk wanting a setup plate
My friend who does the lipo plates and bulkheads will also be making these very soon.
i'll keep you posted..
Nick Priest is offline   Reply With Quote
Old 05-21-2009, 10:27 AM   #9557
Guys,
started to build the kit and i have already ran into difficulty
building the shocks the seal retainer is really really tight into the shock body do i need to trim this down or something as i cant actually push it in! without severe force
Megacrash is offline   Reply With Quote
Old 05-21-2009, 10:35 AM   #9558
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default shocks
Not sure if this the absolute correct way of building the shock...but it worked for me...
I filed the edges, very very little taken off (more to round off the edge)...just enough to squeeze it in
placed shock oil on the edges before placing into shock cylinder
use the shock tool in the kit to make it easier..
Went in snug, way easier than trying it straight from the pack...
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 05-22-2009, 01:36 AM   #9559
Redwood's Avatar
Originally Posted by Megacrash View Post
Guys,
Do not trim down the retainer. I did this and ended up with leaking shocks. When I got my rebuild kit I replaced the retainers, and they were very hard to put in, made easier by the shock kit.
So percevere with the retainers as they are, I ended up with a red mark on my hand after installing them, a small red circle where I was pushing hard on the shock tool. Since then though I have had zero problems, couldn't be happier.
Also if you didn't already know, dont include the large blue foam in your shocks, unless you really want to have that extra rebound.
Regards
Neal
Redwood is offline   Reply With Quote
Old 05-22-2009, 04:50 AM   #9560
ctg1129's Avatar
ok guys allow me to introduce my self,my name is Chris live in the southeasteren part of georgia,been into rc for over 20 years,mainly helis and planes for the past few years.
just got my tc5r a few days ago for parking lot racing at my LHS.
now for a few ?s, i have been lurking around here for a couple of weeks now and answered most of my ?s that way,
is box setup a good place to start ie tc5r settings?
any word on losi xcelorin motors and esc,i can get a new one for 130 bucks with usb and software or should i go with the novak. i like the fact i can program with my pc,but is it wort it?
the track we are running is VERY tight.lanes are about 8ft wide with a front streach at about 110ft and then lots of turns,like i said very tight,any input on tight track setting would be great
thanks Chris
ctg1129 is offline   Reply With Quote
Old 05-22-2009, 06:22 AM   #9561
Redwood's Avatar
thanks Chris
Just had a look at the kit setup for rubber and it looks pretty good, should be fine for starting, seems like a nice 'nuetral' setup. Just make sure that you setup the car precisely, I see a lot of new guys just roughly throwing setups on, you will be repaid all the time you spend being precise with faster laptimes. I would recommend buying a set of shock springs, so that you can tune with those since the level of grip will change drastically which springs work best.
As for the electronics I hear varied reports on the excelorin speed control. I think its one of the many Hobbywing products rebranded so it should be OK, but with anything, you get what you pay for. If you like ease of programming and don't want to have to use a PC then I can recommend the speed passion LPF (6.5t motor limit) or GT(2.5t motor limit) as it comes with a hand-held programming card, which is great.
I haven't heard any reports of the Novak system but Novak are a good brand and I'm sure you wouldn't be disappointed.
Regards
Neal
Old 05-22-2009, 06:44 AM   #9562
Thirtybird's Avatar
thanks Chris
I have run the Losi Xcelorin with a Losi 13.5 in my touring car, and it showed just how my old car can't handle todays speed and handling I had some issues with mine regarding the steering glitching with my FM radio - I told the Speed Control I had a 2.4 GHz and it went away My last problem is getting the braking power sorted out (the light comes on, but the car doesn't even slow down). If you can get it cheap, I'd say go for it.
Welcome to the car world
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 05-22-2009, 10:18 AM   #9563
CTG i have a novak havoc with 13.5 new for 150 used 2 times let me know
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 05-22-2009, 11:27 AM   #9564
Trader Rating: 23 (100%+)
thanks Chris
novak motor and look into the new lrp tc sxx esc that has just came out. online stores have got them in and lhs's will soon.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 05-22-2009, 11:39 AM   #9565
ctg1129's Avatar
thanks for the input guys,i will do some more research on what esc and motor combo im gonna get ,i will let everyone know what direction i go and the end results after
thanks Chris
Old 05-22-2009, 12:18 PM   #9566
raven101's Avatar
Send a message via MSN to raven101 Send a message via Yahoo to raven101
Chris i am running the xcellerin 13.5 at the parkinglot races here at my lhs and everyone calls it a cheater 13.5. it does have a higher kv than anyother 13.5 but the speed control is the week point. friends i race with use the same motor with the venom speed control which is the same as the speed passion just rebadged and it seams to be a little better. but i have no complaints about the losi system at all. it does cost alittle more than the havok system though.
associated tc5r, academy sb v2, associated tc6, tekin,
castle creations, orion, novak, reedy. lets all have fun. support your local hobby shop, and dee and mee if its not local.
raven101 is offline   Reply With Quote
Old 05-22-2009, 12:36 PM   #9567
Hyde's Avatar
I've read here that people take off a motor mount mounting screw?
Which screw is that? The one that goes in the bulkhead or the front chassis screw?
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 05-22-2009, 07:15 PM   #9568
mr crum's Avatar
Send a message via Yahoo to mr crum
the new speed passion 2.0 is a beast and customer support is second to none love them
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-22-2009, 08:05 PM   #9569
why not run a rubber band and twist it till it almost breaks!!!!... I hope you find a combination here that we will all try and maybe run out of town
Chuckyluv is offline   Reply With Quote
Old 05-22-2009, 08:09 PM   #9570
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
thanks Chris
I know are shop we have lots of problems with the Losi brushless motors. I just burned up a 17.5 this week on the 2nd run and it wiped out my speedo as well. Motor was 149 degrees the 1st run, then I ran my 2nd heat and changed nothing and the motor went over 200 and now is a expensive paper weight. The shop over the winter season of racing only had problems with the Losi motors. I know the shop owner is going to send all his remaining stock back.
Not sure about the speedo. I was told they are smooth but don't have as much timing as many of the newer speedos out so take it for what thats worth.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
