Old 05-20-2009, 07:08 AM   #9526
raven101's Avatar
Send a message via MSN to raven101 Send a message via Yahoo to raven101
is there a problem with the factory tc5r shocks? i am not a big fan of cross breeding my tc.
associated tc5r, academy sb v2, associated tc6, tekin,
castle creations, orion, novak, reedy. lets all have fun. support your local hobby shop, and dee and mee if its not local.
raven101 is offline   Reply With Quote
Old 05-20-2009, 07:11 AM   #9527
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by Jerry P View Post
You need the Losi Offroad pistons.
Jerry P: so would those be the ones for the XXXS since the 4wd offroader, the XXX4 is based on the XXXS? the old XXXS shocks were basically the offroad shocks only shorter. .... sorry, not too clear on what you mean so needed to clarify. thanks.
Originally Posted by mr crum View Post
well to answer ur question the losi pistons are #57 i dont use them but ive seen it on the thread and as far as shocks ft tc4 shocks reliable and work great
mrcrm: yes, i am aware they are #57s and also #56s which basically refer to the size of the drill bits used to make the holes in the pitons, but there are two kinds ... namely the older #57s/#56s that came with the XXXS which had rounded edges and there are the newer 10mm #57s/#56s which came out when the changed their shocks when they released the JRXS/JRXS Type R. thats where i am a bit thrown off as to which one it is.
appreciate the help guys...
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 05-20-2009, 07:25 AM   #9528
ROBORAT's Avatar
Jerry P.: i figured it out. its the old ones that came with the XXXS and the XXX4 which are the offroad type pistons. the JRXS ones have a different moulding on one side which is needed to hold the piton in place since they are screwed on to the shock shaft rather than the traditional use of e-clips. thanks again!
Old 05-20-2009, 07:43 AM   #9529
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey raven, no problems with tc5 shocks if you build em right. use green slime on o-rings and hold shaft with shock shaft pliers so you dont scratch them. ive been racing my tc5 for 2 years and never have a problem with the shocks leaking and they are super smooth
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 05-20-2009, 08:10 AM   #9530
raven101's Avatar
thanks for the info i have had no prob with mine as they were built the way you said with the green slime and they have not leaked i just wanted to make sure there was not a problem the reason i was reading about going to the losi or tamiya shocks.
Old 05-20-2009, 09:22 AM   #9531
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
What is the green slime that you are referring?
IIGQ4U is offline   Reply With Quote
Old 05-20-2009, 09:30 AM   #9532
geeunit1014's Avatar
Post
Green slime
Its supposed to help seal the shocks better
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 05-20-2009, 10:07 AM   #9533
Hyde's Avatar
Hey,IIGQ4U. green slime is a product people use to make the shocks smoother and a tight fit around the o-rings. Its also good for when your biulding or re-rebuild to put some on the shaft then when your ready to put the shaft in the bore lube up the shaft so you don't damage the o-rings with the thread when putting together.
If you want a life time supply of green-slime buy some petroleum jelly "vaseline" its the same thing. Besides the the green colour and the name
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 05-20-2009, 11:36 AM   #9534
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
When I was going over my TC5 I bought used I decided to change the shock oil and opted to use the Losi 57 pistons. They fit great and worked just as well for me. They fit nice in the shock body so you don't get much if any blow by. My suspension was very smooth for me on a medium rough track with 35wt oil. Very happy with the results.
I do use green slime on my o rings to help with the seal. Has always worked well for me.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-20-2009, 11:38 AM   #9535
IIGQ4U's Avatar
How often do you guys completely rebuild the shocks and how often do you simply refill them with oil?
Old 05-20-2009, 12:00 PM   #9536
wyd
Tech Legend
wyd's Avatar
For me if the shocks rebound correctly and still feel smoth I leave them alone and just change the oil. If they are getting a little grabby or I notice the oil discoloring and find dirt in the shocks then I go ahead and rebuild them.
If you run on dirtier conditions you might want to change the o rings more often. Touring car shocks seem to stay alot nicer than my offroad shocks did where I needed new orings every couple weeks because of the amount of dust getting suck up into the bottom of the shocks.
Old 05-20-2009, 12:10 PM   #9537
Gents,
Ill be buying one of these very soon and getting it ready for winter racing,
just a quick question im getting the tc5 r does it have imperial or metric screws?
thanks
Megacrash is offline   Reply With Quote
Old 05-20-2009, 12:12 PM   #9538
IIGQ4U's Avatar
Metric
Old 05-20-2009, 12:30 PM   #9539
Metric
Almost metric, for example screw from diff is imperial
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 05-20-2009, 12:47 PM   #9540
Metric
Nice one matey
as i have so many 1.5, 2, 2.5, 3mm drivers its unreal didnt want to buy more
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
