Old 05-16-2009, 09:55 PM   #9496
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey guys i noticed that setup has no sway bars. my car touches down on left side of chassis and the motor scrapes the ground in the sweeper. this is 13.5 and i run sway bars. any thoughts on this. thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 05-17-2009, 06:30 AM   #9497
mr crum's Avatar
Send a message via Yahoo to mr crum
dude ive been tryin to get my motor from scraping i made a few changes to my car gona try them today if they work i will let u know but if not and u find somethin let me know plzzzzz
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-17-2009, 07:22 AM   #9498
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
For you guys with your motor hitting are the setups you using have alot of body roll or are the ride heights low? I ran my car for the first time and didn't have this issue but don't mean I can't in the future so just wonder what type of setups guys are using that have this problem.
The track I ran on was a bit bumpy in some areas so I went from 40wt oil with Losi 57 pistons to 35 oil and it really helped out. I run 2a on the roll centers and Associated blue front springs and Associated silver rear springs.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-17-2009, 08:58 AM   #9499
Verndog's Avatar
Trader Rating: 16 (100%+)
Another suggestion to try. Not enough weight on side opposite the motor. This can be especially true when changing to lipo, and either not rebalancing the car, or not getting the weight far enough from center of the car. I see people load up the inside of the battery with weights, and although the car may balance on beams, when you go into a corner the weight shift will not react the same as weight further from center.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-17-2009, 11:48 AM   #9500
wyd
Tech Legend
wyd's Avatar
Thanks. I know this time back into touring I weighed every piece of electronics, including the lipo pack and the new PPD weight I have. I had the electronics side at 11.2oz and the battery side was at 13.6 I added 2oz ot tungstun steel weights I have that are super small and bring it up to right at 13.4 to 13.5 on the electronics side so my balance when I was all done and checked everything was excellent for me. I might look into the Diggity offset lipo tray holder. I currently have the standard lipo tray from Diggity.
Old 05-17-2009, 12:10 PM   #9501
thanx verndog. this might be something to look into. i have the ppd bottom and side plate and my car balances perfect but maybe i need the offset tray i have the standard one from diggitty
Old 05-17-2009, 12:11 PM   #9502
mr crum im gonna try verndog suggestions and move the battery out mory on chassis i will let you know how it goes
Old 05-17-2009, 02:19 PM   #9503
mr crum's Avatar
1a and associated blue all the way around
TEAM B.R. RACING
Old 05-17-2009, 02:39 PM   #9504
wyd
Tech Legend
wyd's Avatar
Thanks. I know when I got my TC5R used it had 1a on it. I know the last time it was run was rubber tire carpet.
Old 05-17-2009, 08:39 PM   #9505
Verndog's Avatar
Also not sure if anyone looked at this or if it applies, but some people are loosening the upper motor mount screw, or leaving out completely for increased chassis flex. If you have, also try to tighten it back up...possibly a small amount of additional flex or movement there could add to the problem.
Good luck...let us know what it was. I've seen a few reports of this now.
As a rule of thumb, running a 9-10+ oz 5000+ size pack and a 3 oz base plate, getting the battery right at the chassis edge should not drag motor with little to no additional weight (in most cases.)
---Team Hoarders---
Old 05-18-2009, 03:13 AM   #9506
mr crum's Avatar
i run without that screw ill try that
TEAM B.R. RACING
Old 05-18-2009, 07:03 AM   #9507
Redwood's Avatar
Just for a reference, I ran with the motor mount screw missing, blue springs front and back, 5mm ride height, Diggity Designs offset Lipo tray with all extra weight along the centre line or forward or rearward of the lipo, but still on the chassis and I have no problem with my motor hitting the ground.
On a side note, I have since replaced the screw attaching the motor mount to the bulkhead and removed the forwardmost motor mount screw (from below) and was happy with the result.
Regards
Neal
Redwood is offline   Reply With Quote
Old 05-18-2009, 09:42 AM   #9508
wyd
Tech Legend
wyd's Avatar
Regards
Neal
Did you gain more overall traction when you removed the screw from the front part of the motor mount? Did it seem to make the car feel more consistant? I'm new to the TC5R and have not caught up on all the mods guys are doing to the car.
Brian
Old 05-18-2009, 07:11 PM   #9509
Trader Rating: 8 (90%+)
Default the best way to balance a car
I was wanting some of your opinions. I have been told to just set the ride height and not worry about scaling the car. I scale the car with my ride height and it scales way off. I will adjust the preloads to get the car to balance out but my ride heghts are off. Just wanting to know what you guys think. I am running both TC5s one in foam and one in VTA
bigdanes is offline   Reply With Quote
Old 05-18-2009, 08:16 PM   #9510
robk's Avatar
Trader Rating: 22 (100%+)
You want your car to tweak straight. As long as it passes minimum ride height, don't worry if it's a bit off corner to corner.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
