Old 05-14-2009, 12:24 AM   #9481
Robert_K's Avatar
If tried to flip the belt's. Only bad thing is the long (front) belt will then be scratching the battery (or atleast be really close to it).
I've also tried to mount the spurgear in the center of both pulley's. Like Tamiya has it, to balance the layshaft better. That also didn't work.
Good luck, if you have an solution please post some pictures.
Greetings Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 05-14-2009, 02:47 AM   #9482
robk's Avatar
Trader Rating: 22 (100%+)
I have flipped the belts on my car. It helps if you run lipo, since most move the battery out.
Old 05-14-2009, 03:28 AM   #9483
Redwood's Avatar
I have thought about swapping the belts round, since my belt seems to come very close to my servo horn, what are the other benefits, if any of swapping the belt?
Regards
Neal
Redwood is offline   Reply With Quote
Old 05-14-2009, 10:50 AM   #9484
hi guys right now i have the worlds setup on it and WOW is it dialed. i am running 10.5 and i ran it yesterday and the air temp was 58 deg and the track temp was 90 ish. i ran and after running the motor temped at 145 and the speedo was at 105 deg. i am geared at 74 33 and i know that when it really starts to heat up i wont be able to run this gearing because it will thermal. but does anyone have any suggestions as to a different gearing that will give me the same speed but allow my motor to run cooler? right now the thing is a freakin rocket.
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 05-14-2009, 12:40 PM   #9485
John_S's Avatar
What speedo/ motor do you run?
John_S is offline   Reply With Quote
Old 05-14-2009, 06:39 PM   #9486
Jason Turner's Avatar
Trader Rating: 63 (100%+)
I'm running the SPX speedo on power profile 8 with gearing 87/32 with it coming off the track at about 117 - 127 degrees it seems great like a 2 speed or something.
Anyone else using this speedo? And what gearing and results are you coming up with?
Jason Turner is offline   Reply With Quote
Old 05-14-2009, 07:07 PM   #9487
mr crum's Avatar
Send a message via Yahoo to mr crum
hey guys i flipped the belts and it freed up enuff space to put receiver next to the speedo and i run a one off lipo tray so i dont have to worry bout the battery hitting the belt so i think im all good i will post pics tomorow
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-14-2009, 08:53 PM   #9488
Verndog's Avatar
Trader Rating: 16 (100%+)
The worlds setup is awesome for asphalt. I haven't run alot of 10.5 but your gearing works out to 4.48 which is geared too high for 10.5. Likely your not reaching top speed. You might want to move to around 5.5 FDR tops which would be dropping to a 27T pinion with your 74T spur.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-14-2009, 10:22 PM   #9489
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
This Worlds setup?:
http://67.199.85.166/racing/setups/t...orlds_2008.pdf
or this?
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 05-14-2009, 11:02 PM   #9490
its the first one not the testing one
Old 05-15-2009, 08:31 AM   #9491
Maybell's Avatar
Originally Posted by rezenclowd3 View Post
Those 2 setups are very similar, so just pick one and try it. I am running a blend of the 2 and my car is great. Be sure to run lighter oil unless you are running in very hot conditions.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 05-15-2009, 11:43 AM   #9492
6Venom's Avatar
Trader Rating: 44 (98%+)
Originally Posted by poochy View Post
i cant take credit-somebody else on here gave me the advice-but im realizing nobody really knows about it
=the source of the majority of the tc5 steering slop is from the fitting between the steering post and its bearing (the upper bearing). put threadlock there and the remaining 10-20% is from the ballcups-no big deal there. this is a night and day result-try it!
Sorry for not understanding but put threadlock where exactly? Thanks!
6Venom is offline   Reply With Quote
Old 05-15-2009, 01:14 PM   #9493
I just looked at it. Its actually almost exactly the same to what I have been running for the past year. I just have some anti-dive and my shocks are opposite of the setup sheet.
Ya, I run here in Cali, so 40wt is almost always used due to the heat.
Old 05-16-2009, 08:50 PM   #9494
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Ran my new to me TC5R and a loose asphalt track and I have to say for the first time running touring cars in almost 2 1/2 years and running brushless touring for the first time it was dialed. Couldn't be happier with my car for the first time out. Just went with kinda neutral setup and with the things I knew from previous touring cars I raced from the past and the TC5 worked great. Look forward to working on the setup more and progressing with my setup.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-16-2009, 09:04 PM   #9495
geeunit1014's Avatar
Excellent I can't wait to get back up to frederick, ive definately figured my car out some more since last time. Might have a few more ponies too
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
