Old 05-08-2009, 02:56 AM   #9436
Redwood's Avatar
Originally Posted by BlueEagle View Post
This seems like a bad idea for the possible effects on your drivetrain.
If you account for the fact that the battery side of the chassis is braced by the battery "strap", I wonder if this negates the asymmetry. I imagine the battery strap provides a lot more stiffness than what is lost from having the battery holes.
I see your point here, and it can be concerning to think that you motor and spur might separate under high flex.
I have considered what 'high flex' is though, and if you take your car and attampt to flex it around the centreline, it is not easy, it takes considerable force to feel and effect at all. If you then consider that optimum gear mesh has a gap between spur and pinion, then there is room for movement between the two without much loss of power (I suspect, perhaps it is significant, but my instinct is that is is almost trivial).
As for the battery bar, I am running lipo with a cuboid shape, and if I screw either thumbscrew too tightly down then the battery strap simply bends at the end. This cannot be good for flex/tweak. So I tighten them till they will not come off, but not so much that it would start to add to chassis flex. Also the bottom of the thumbscrews are bevelled, which will deflect any flex/torque.
There is another way to tackle this problem. I saw some guys running new, custom bulkheads, which can be seen here:
www DOT aeforums.co.uk/forum/index.php?showtopic=3647 (apologies, my post count is not yet high enough)
They attach the motor to the bulkhead directly, and the motor 'floats'. The guys I talked to were impressed by them, and they look good to me, but I have other things on my wish list ahead of these for now.
I believe there was already a discussion about them in this thread before though, so I would recommend looking back for it.
Regards
Neal
Redwood is offline   Reply With Quote
Old 05-08-2009, 03:06 AM   #9437
Redwood's Avatar
The bulkheads can also be found here:
www DOT rctech.net/forum/electric-road/285985-tc5-modified-bulkheads-lipo-plate.html
I attempted to edit my previous post to accomodate this, but it wouldn't let me, so apologies for double post.
Regards
Neal
Old 05-08-2009, 05:12 AM   #9438
medservr's Avatar
Default TC5 steering slop
Fellow TC5ers,
Does anyone have a cure for the steering mechanism slop that is caused by the ball cups and ball ends in the steering mechanism of the TC5? When I move both wheels back and forth with my hands while the servo is in a centered position, it seems that the wheels move independantly of the servo quite a bit. I can see that this is occurring because the contacts between the ball ends and ball cups are not snug. I tried replacing the ball cups, but that didn't do anything. Thanks for your help.
Joel
medservr is offline   Reply With Quote
Old 05-08-2009, 05:37 AM   #9439
raven101's Avatar
Send a message via MSN to raven101 Send a message via Yahoo to raven101
Originally Posted by medservr View Post
Fellow TC5ers,
Joel
while building my kit i used the rpm ball cups through out the car and have not noticed that issue. you could try using them they are a bit tighter than the stock ones.
associated tc5r, academy sb v2, associated tc6, tekin,
castle creations, orion, novak, reedy. lets all have fun. support your local hobby shop, and dee and mee if its not local.
raven101 is offline   Reply With Quote
Old 05-08-2009, 05:46 AM   #9440
medservr's Avatar
Thanks for the suggestion. Why did you go straight to RPM ball cups? Are AE ball cup known to have this problem.
Joel
Old 05-08-2009, 06:00 AM   #9441
raven101's Avatar
Joel
i have just noticed every AE kit i have built there is alot of play between the ball stud and factory cup and i have allways used rpm ball cups. example i just bought an sc10 and i used the factory ball cups, i just touch something with the front wheels and the steering ball cups pop off
Old 05-08-2009, 07:07 AM   #9442
revo61's Avatar
Trader Rating: 18 (95%+)
What size cups did you get?
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 05-08-2009, 08:42 AM   #9443
raven101's Avatar
i used the short shank cups. the ball end on all the rpm cups i do believe are all the same size the shank that the turnbuckle screws in is the only differance i have ever seen.
73381 Heavy Duty Rod Ends (12) 4-40 (White)
Suggested Retail $4.95
Old 05-08-2009, 08:51 AM   #9444
medservr's Avatar
Thanks for your help Raven.
Now for one more question:
Does anyone have any information on the Exotekracing.com TC5 Chassis that is supposed to be "coming soon"? I believe they are calling it the "TC5X Conversion". I can't wait to see this chassis and of course, buy it. I'd love to know when it's coming out and if there are any sneek peek photos out there.
Thanks, Joel
Old 05-08-2009, 09:53 AM   #9445
poochy's Avatar
Fellow TC5ers,
Joel
the slop is from the steering post and the bearings it goes through--remove upperdeck--remove steering blue rign washer--apply threadlock in the gap between the upper bearing and steering post--wait 15 min--WALALAL--90% of the slop gone!
you can do a search on this thread and you'll find that this works.
poochy is offline   Reply With Quote
Old 05-08-2009, 10:57 AM   #9446
medservr's Avatar
That sounds like a great idea. I'm going to try it as soon as I get home. I can't picture in my mind how the threadlock would make that much of a difference, so I can't wait to try it out. Also, as you mentioned, I found this trick on page 533 of this forum.
Old 05-08-2009, 12:11 PM   #9447
Anyone got a solution to stop the motor from scuffing the ground? I've recently gone brushless which is causing me some problems with the motor scuffing along the ground, the picture shows what it looks like only after a few runs. I'm running the car at 6.5mm and have tried putting a bit of lexan between it and the chassis. The only solution I've come to is to wrap lots of tape around it and replace it after every run. Anyone else got the same problem?
TC5
www.keiransmart.co.uk
Keiran is offline   Reply With Quote
Old 05-08-2009, 12:37 PM   #9448
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Redwood View Post
A lot of guys detach the motor mount from the rear bulkhead by removing the screw there, this increases flex, and more importantly makes the flex more symmetric. If you are being thorough you have to grind the bulkhead or motor plate so there is a gap, but I'm happy without the gap.
Regards
Neal
I wouldn't do this for carpet. I have inadvertently left the screw out and the chassis will flex enough to chew the spur.
The reason the motor mount is a separate piece is so that the flex is more symmetrical with all the screws attached. Two different length bulkheads, as it would be if the motor side was one piece, is a bigger problem.
Old 05-08-2009, 12:49 PM   #9449
MikeR's Avatar
Trader Rating: 15 (100%+)
I think you might have bigger issues- if you've raised the ride height that much and the motor is still scuffing (along with how bad your chassis is scuffing by looking at that pic) you need to stiffen up the suspension more. Your car will experience random push then breaking loose effects if you don't do something about all the chassis scraping. 7mm ride heights or more is not uncommon at our loose bumpy home town track just to maintain proper corner speeds
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-09-2009, 02:02 AM   #9450
John_S's Avatar
Buy the new bulkheads
John_S is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
