Old 05-03-2009, 11:26 PM   #9406
Airflow's Avatar
Some problems with my TC5R:
-Stock aluminum outdrives started to show some wear.
Im expecting the blades to wear off first. Would a composite
diff be durable? My TA05R High Precision plastic outdrives hasnt
shown any wear since 2007 compared to my TC5R which just
started running last March.
-Stock settings of belt tension is tight and causing drivetrain drag.
Will this loosen up after 20 runs more or should I loosen the tension now?
Or can I use better belts from other kits?
Any suggestions?
Airflow is offline   Reply With Quote
Old 05-04-2009, 02:33 AM   #9407
Hm, I have question, do you hit something on track ?
Blades go away when you hit, I change solid axle to slipper spool and
problem disappear :-)
Composite diff when is set to loose, can got hot and mesh ... but if you
have it in good health, composite works too.
Any suggestions?
For belts you should look there:
Team Associated TC5
Originally Posted by tcfree
Team Bomber (#TB20022) Front Drive Belt For BD
or
BD FRONT DRIVE BELT BD516L.
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 05-04-2009, 07:01 AM   #9408
Trader Rating: 62 (100%+)
Originally Posted by Jason Turner View Post
Anyone have any suggestions on gearing for a TC5 with an spx on power mode 8 and a 13.5?
Thanks in advance
Yesterday I ran a 5.2 fdr with spx on profile 7 using a Duo and 10* of timing on profile 8 i would try 5.6 to 5.8 and temp motor after a couple minutes
The Wease is offline   Reply With Quote
Old 05-04-2009, 07:12 AM   #9409
poochy's Avatar
anybody try these bearings ---> beaing
poochy is offline   Reply With Quote
Old 05-04-2009, 01:14 PM   #9410
robk's Avatar
Trader Rating: 22 (100%+)
Any suggestions?
The aluminum outdrives will wear. The blades wear too, but it's not as noticeable since most are tight to start with. The plastic diffs are fine if you are racing stock/17.5/13.5 motors. Some guys didn't like them with mod.
Look at your belts, they should say either "UG" or "UK" on the belt. I can't remember for sure right now, but I think "UG" is the lower friction belt?? Anyone??
Old 05-04-2009, 01:36 PM   #9411
6Venom's Avatar
Trader Rating: 44 (98%+)
Any suggestions?
imho, I would loosen them now. It has been my experience that the supplied belts don't loosen enough with use.
6Venom is offline   Reply With Quote
Old 05-04-2009, 02:43 PM   #9412
speedsterblade's Avatar
My experience also. I'll look at the other tc5 belts when they are shot.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 05-04-2009, 04:30 PM   #9413
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by robk View Post
... I can't remember for sure right now, but I think "UG" is the lower friction belt?? Anyone??
The newer "low friction belt" say UG. I personally didn't notice a huge difference (compared to a worn in original at least).
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-04-2009, 06:13 PM   #9414
Airflow's Avatar
Thank you for your suggestions
Last night Ive re-tightened and cleaned the aluminum diffs and I
could see wear ha ha ha. Will order the FT Plastic Diff Outdrives
soon.
I also serviced my diff holder bearings and loosen the belt tension.
will try run in tomorrow.
Old 05-05-2009, 07:24 AM   #9415
poochy's Avatar
what are the best and most durable 6x10x3 wheel bearings that i can get for this car?
Old 05-05-2009, 07:43 AM   #9416
Can't go wrong with Avid bearings at a $1 a piece or $5 each for ceramics
Old 05-05-2009, 11:45 AM   #9417
katfish317's Avatar
+1 on avid bearings they work great and customer service is great!
katfish317 is offline   Reply With Quote
Old 05-06-2009, 03:29 AM   #9418
Redwood's Avatar
I was also looking into buying some bearings since a few of mine have seized.
I got the sizes from the manual and the steering hub bearings are 6x10x4.
I was going to buy Avid since they seem to be cheap and quality, however Avid do not sell 6x10x4, so what are you guys with Avid bearings doing? shimming them, leaving them or simply not using Avid for the hubs?
Neal
Redwood is offline   Reply With Quote
Old 05-06-2009, 03:40 AM   #9419
revo61's Avatar
Trader Rating: 18 (95%+)
I have been down this road. That was a typo, the bearings are 6x10x3.
Neal
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 05-06-2009, 03:50 AM   #9420
Redwood's Avatar
Aha, come to think of it, I remember them being a little thinner than 4mm now that I think about it.
Thanks, I shall be ordering some now then, do you recommend the rubber or metal type, or the revolution type?
Neal
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
