Old 04-09-2009, 10:51 AM   #9271
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by outlandr91 View Post
Do you know what the part #s are? Thanks
There are three different lengths of threads for each one. They are listed towards the bottom of this page.
http://67.199.85.166/main/maincatego...&nav=on1.10nav
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-09-2009, 01:57 PM   #9272
Default 4deg tc4
I have it on good authority by an Associated sponsored driver team, that the FT TC5 comes with 4 degree castor blocks as standard, which would make sense with it being the FT TC5, doh!
www.sldmodels.co.uk
www.rc-kars.com
sldmodels is offline   Reply With Quote
Old 04-09-2009, 02:32 PM   #9273
CL
CL's Avatar
Trader Rating: 32 (100%+)
Thanks guys! That clears it up. I was going to get the Factory Team version(the no longer in production version) and the one piece spool, but that is not exactly what I needed.
CL is offline   Reply With Quote
Old 04-09-2009, 03:35 PM   #9274
Thanks, Craig
outlandr91 is offline   Reply With Quote
Old 04-09-2009, 07:28 PM   #9275
Trader Rating: 26 (100%+)
Default TC5R Shocks
Maybe someone here can give me some advice. I have a TC5R. I was having a problem with one of the shocks, I don't know what the part is called, but it is the larger black piece that holds the black plastic washer and the "o" ring in. It would not lock into the bottom of the shock body, so when I ran it, it would get loose and allow the "o" ring to come loose and allow all the oil to leak out. I had an upgrade kit for the F/T TC4 shocks, part # 31123. The larger black piece has a different shape, but I tried it and it seems to be a tight enough fit to secure the "o" ring. My question is, are they interchangeable? Is the shock body the same? If they are should I change all 4. Or, should I get a rebuild kit with the current large black piece # 31120?
svines1972 is offline   Reply With Quote
Old 04-09-2009, 08:18 PM   #9276
Super Moderator
Kraig's Avatar
Yes they are the same shock body so the insides should work. Don't mix and match the insides though. If you have the VCS2 rebuild kit then use what is in the package. If you have the latest and greatest pieces from Associated then use everything in that package.
Old 04-10-2009, 05:08 PM   #9277
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
anyone have a problem with the tc5r chassis being countersunk to deep
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-10-2009, 05:25 PM   #9278
Jerry P's Avatar
Trader Rating: 44 (100%+)
Warren,
A few people did. Contact AE about it. My TC5R only had an issue where the servo mount is. Other than that my car was good everywhere else.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 04-10-2009, 07:37 PM   #9279
Suspended
I had a problem with the holes in my chassis ben drilled too close together for the servo.. so took a few mm off the servo mounts and now it's fine..
Weird thing is my friend who is running the shame chassis (itf) and same servo (S9551) has the servo mounted in the same way as me just his servo has a bigger gap between the bulkhead and the front of the servo... Weird cars...
Easy to drive and easy to setup though which as a plus.
Nick Priest is offline   Reply With Quote
Old 04-10-2009, 07:56 PM   #9280
bvoltz's Avatar
Does anyone know of a new motor mount for the TC5, that gives a greater range on the motor movement and a bigger opening for the pinion? Just asking.. I did try a search but it craps out every time I run it.
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 04-10-2009, 08:24 PM   #9281
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey warren whats up. i have been dealing with this problem since i bought the itf chassis. i sent it to associated and they sent me back one that was worse i cant even tighten my bulheads. so im sending the new one back tommorrow and we will see what happens. in the meantime ive been running the standard chassis with the itf top plate at jackson and the car works beautiful
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 04-10-2009, 08:25 PM   #9282
Hyde's Avatar
Wow i never heard that before....what motor doesn't work? Or you wanna run taller gears? More like tall 48p?
We should email digity desgns for an all new one....with some fins to release heat too
Hyde is offline   Reply With Quote
Old 04-10-2009, 08:30 PM   #9283
6Venom's Avatar
Trader Rating: 44 (98%+)
Do you mean access to the pinion?
I completely agree with what a huge pain in the butt it is to get to the pinion and adjust the mesh.
6Venom is offline   Reply With Quote
Old 04-10-2009, 09:17 PM   #9284
bvoltz's Avatar
It works, but you are really limited on the spur to pinion, because the adjustment holes are limited on the range of movement. I figured someone by now would have made something. also trying to get a 30 plus tooth pinion though the hole is not possible. With the FDR for 13.5 and 17.5 this is a big pain in the butt. When you are trying run the two classes with one car it is a bit of a problem.
Old 04-10-2009, 11:06 PM   #9285
Damnit Man's Avatar
Send a message via MSN to Damnit Man
Sorry if this has already been asked, but I couldn't find it. I was wondering if there are any advantages to running the slipper spool over the regular spool. Will the slipper part of it cut down on busted blades?
Damnit Man is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
