Old 04-06-2009, 09:04 PM   #9241
geeunit1014's Avatar
Originally Posted by AssocRacer View Post
I ordered mine from ebay. They are the same size that the duratrax 1/18th scale uses for wheel bearings.
They are 6x10x3. than manual is a typo
ive not had any problems with the spur gear rubbing on my car
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-07-2009, 08:56 AM   #9242
speedsterblade's Avatar
Originally Posted by yodace View Post
I lowered the spur to lvl. Whats a good belt tension setting for the rear for a 13.5?
Anyone have mod to do for the spur to move away from the top deck? where it doesnt look like its touching...
I had to slightly sand down the top deck for clearance using a presision spur w/ countersunk screws. that spur is a little thicker than stock at the screw/mounting location...I figured those screws would clear but didn't. Quick sanding and was good to go.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 04-07-2009, 09:13 AM   #9243
Takt's Avatar
Trader Rating: 15 (100%+)
I have a slipper spool that continues to come loose.
I know it's been discussed before, and I looked it up and bought the new T3 nut and screw and tightened it up and superglued it together.
It's still coming loose.
I'd appreciate suggestions on what I'm doing wrong.
Takt is offline   Reply With Quote
Old 04-07-2009, 12:29 PM   #9244
poochy's Avatar
Originally Posted by IIGQ4U View Post
My spur gear is touching ever so slightly. There are a number of inconsistencies with this car. The car can definitely perform but we must put up with a lot!
maybe unscrew all the upperdeck screws and screw them back in x pattern.....its very very important that the screws screw back in freely--if not you may tweak the upperdeck enough to cause it to touch the spur....
poochy is offline   Reply With Quote
Old 04-07-2009, 12:31 PM   #9245
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
^^^ Thanks, unfortunately, that is not my issue.
IIGQ4U is offline   Reply With Quote
Old 04-07-2009, 12:50 PM   #9246
poochy's Avatar
hey, anybody have a really good bumpy parking lot setup (140 ft. backstretch)?
my ride height will need to be about 7mm to avoid small scratches.
Old 04-07-2009, 01:04 PM   #9247
poochy's Avatar
do you have both the shims (asc31162, page 11 step 4 on the manual) installed on the center shaft?
also - did you remove any screws from the upperdeck to get more flex?
Old 04-07-2009, 01:38 PM   #9248
John_S's Avatar
On my spool i glue the pads to the outdrives to reduce slip. Also double up your nut in the t nut. By that i mean put 2 of the metal nyloc nuts into the t nut, this gives the screw more to hold on to. Also put some threadlock on your diff screw before you thread it through and you shouldnt have any more problems. hope this helps
John_S is offline   Reply With Quote
Old 04-07-2009, 02:39 PM   #9249
Originally Posted by mr crum View Post
wow ur still running 0 degree blocks yeah man just like back in the day tc3/tc4 use the 4 degrees it will help cornering alot
Well it runs sweet as it is, so I'll try it and see how it goes, got round 1 of the torc in less than a fortnight.
www.sldmodels.co.uk
www.rc-kars.com
sldmodels is offline   Reply With Quote
Old 04-07-2009, 03:10 PM   #9250
You may want to look at setups from the '08 ROAR paved nats, the track there was very bumpy.
Mike Gee
Old 04-07-2009, 04:39 PM   #9251
can someone tell me what the difference is - ae silver ball stud & ae black ball stud. thanks!
franc furter is offline   Reply With Quote
Old 04-07-2009, 07:45 PM   #9252
DARKSIDE's Avatar
this might have been answered before but Im trying to get into 17.5 touring rubber ...its out doors with around 75-120 foot straight...right now Im at 100/47*2= 4.25fdr...any help would be great..thanks
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Final On-Road Race
Summit RC Raceway June 17th
Ft. Wayne IN
DARKSIDE is offline   Reply With Quote
Old 04-07-2009, 07:46 PM   #9253
IIGQ4U's Avatar
Final Drive too High. Switch to a lower final drive.
Old 04-07-2009, 07:56 PM   #9254
DARKSIDE's Avatar
smaller pinion?...say 40?
Final On-Road Race
Ft. Wayne IN
Old 04-07-2009, 08:05 PM   #9255
IIGQ4U's Avatar
Change your spur to about 72 and run a large pinion in the 40 range. You need to gear lower to around 3.5 depending on motor.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
