Old 04-03-2009, 09:18 PM   #9211
Hyde's Avatar
I've ran .2 c-hubs and it was pretty good but not much stearing. took a huge step and put some .6 alloys i had laying around and it was much better stearing but at the end of the day i paid with killed tires. i guess depends on grip
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 04-04-2009, 04:25 AM   #9212
John_S's Avatar
my car did that when i put lipo in for the first time and never had any weight on to balance it so that may be your answer.
John_S is offline   Reply With Quote
Old 04-04-2009, 04:38 AM   #9213
Just picked up a front one way. Where do the two rubber o-rings go? I am guessing that they go in the outdrive where the dogbone goes, correct?
Thanks.
Under200
under200 is offline   Reply With Quote
Old 04-04-2009, 05:13 AM   #9214
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Thanks.
Under200
that is correct
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 04-04-2009, 05:16 AM   #9215
Originally Posted by xtrememadness View Post
that is correct
Thanks.
Tony
Old 04-04-2009, 08:15 AM   #9216
Jerry P's Avatar
Trader Rating: 44 (100%+)
Thanks.
Under200
What i found when i installed my one way is that depending on how wide you're running the car you may not need them. It is a very tight fit with them in there on a narrow car.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 04-04-2009, 05:58 PM   #9217
hey guys i ran my tc5r today on asphalt and left my rubber tire carpet setup from josh honstien and it was dialed all i did was change to sorex 28s because it was cold. and a front spool. i love when i dont have to change my whole setup
Old 04-05-2009, 02:27 AM   #9218
Trader Rating: 17 (100%+)
Default layshaft
hi there without going through all the past threads does anyone know if there is a one piece layshaft available for the TC5 just got new pulleys for the layshaft but they still have heaps of slop in them
cheers Lee
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 04-05-2009, 02:30 AM   #9219
Originally Posted by or8ital View Post
The acer bearings are no good. the APS ceramic bearings are the ones to get.
where can I buy these from?
Team Awesomatix
R1 Wurks
RC Maker.com
Old 04-05-2009, 10:05 AM   #9220
lethallee69
After you have the pullies assembled CARFULLY super glue each one to the other with thin CA.
Bob Oaks
bob o is offline   Reply With Quote
Old 04-05-2009, 10:21 AM   #9221
cheers Lee
I think TOP made some but they didn't last very long. They were aluminum and the steel pin would eat through them pretty fast.
I usually add a few drops of ca glue to the slots where the pin rides in the pullies as I assemble the layshaft.
Josh Hohnstein is offline   Reply With Quote
Old 04-05-2009, 04:17 PM   #9222
B-DAWG's Avatar
Originally Posted by Keven H View Post
Here is the latest setup I have been running for 13.5 or 10.5 ! It is the one I used at Snowbirds !
Front :
ride height : 4.2
camber :1.5
caster :6
Toe : 1 out
hex spacing .5mm
wheelbase : 1mm
steering link : 2B
Bumpsteer : 3mm (silver ballstud )
Shock position : 2A
Camber link : 3
Arm mounts Both 3A
2.5mm for arm mount shim
1.5mm uptravel
black rollbar
60 weight oil
#3 piston
xray 28lbs spring
Thick Grease in front diff
A3 belt tension (midlow)
REAR :
ride height : 4.2
camber :2.5
1 deg Hub
Toe : ~2.75 deg
hex spacing .75mm
wheelbase : 2mm
Shock position : 2B
Camber link : 3A
Arm mounts Both 2A
1mm for arm mount shim front
2.5mm for arm mount shim rear
1.5mm uptravel
black rollbar
30 weight oil
#57 piston
xray 17lbs spring (white)
B15 for belt tention (lowest)
Parma Magenta Tires (new compound)
56.4mm
protoform r9 body
hope you guys like it !!!
Thanks for all the help and info on getting my car right. I've tried this setup and love it! Today got the TQ and 1st place today. Put the smack down on 2 T2 009's and 2 T2 008's as well. Even though I bought my springs form one of the guys
Spektrum DX3R
Revo - RB Mods OS .18 TZ
RC8 - RB Mods OS .21 Vspec
Mugen MTX4R - OS speed .12 TZ
TC5 - Mamba Max 5700Kv
B-DAWG is offline   Reply With Quote
Old 04-05-2009, 05:11 PM   #9223
Trader Rating: 38 (100%+)
http://www.buyrc.net/catalog/product...oducts_id=1676
or8ital is offline   Reply With Quote
Old 04-05-2009, 05:12 PM   #9224
katfish317's Avatar
cheers Lee
Ti racing had some that they sold and I got one, it is not much better than the stock one other than being titanium. I do not even use it, the drive train feels freer with the stock one anyway!! I think the slop cmoes from the molds at the factory because I have tried replacing them myself a few times for wear and they do not improve at all. The only way I think you could improve it is too super glue it together or something.
katfish317 is offline   Reply With Quote
Old 04-05-2009, 07:27 PM   #9225
MNF1SAND's Avatar
Anyone have the shock spring kit number?
FG: Comp F1x2, Beetle x2. KYOSHO: Javelin, Optima, TomahawkX2, ScorpionX2, Turbo ScorpionX3, Sidewinder, Beetle, Assault, Advance, Integra, Landjump, Vanning, Rowdy Baja. AE: 18r Exotek, TC5, Original RC10X5, Tekin RC10,RC10T,RC10GT. TAMIYA: BruiserX2, Rough Rider, Super Champ, Cheetah. SERPENT: 720, F180.MISC: Clodzilla IV, Berzerker, TXT, Rock Rider, Rockbull III, F350. Traxxas: T-maxx, Radicator, Bullet, Hawk, Blue Eagle. Xray T3 011,012.
MNF1SAND is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
