Old 04-01-2009, 12:59 PM   #9181
John_S's Avatar
Your rear toe is what stands out to me the most. i run around 3 degrees pretty much everywhere. i would put a spool in the front aswell if you arent already running one. If my car was doing that and i had my rear toe set correctly the next thing i would do would be to give it more front droop to transfer more weight rearward when you hit the throttle and give you more rear traction.
John_S is offline   Reply With Quote
Old 04-01-2009, 01:17 PM   #9182
raven101's Avatar
Send a message via MSN to raven101 Send a message via Yahoo to raven101
ok i have the rear tow set at 3 deg on each side. raised ride hight to 6.0 on rear and lowered front to 5.0. i had a spool in the front but opted to remove it and run a diff because of understeer in a hairpin turn. i am not running any of the rubber rings in the top plate and was told that running the chassis so rigid could cause my problem also. i also reset my rear camber to 2 deg and front to 1.5.
associated tc5r, academy sb v2, associated tc6, tekin,
castle creations, orion, novak, reedy. lets all have fun. support your local hobby shop, and dee and mee if its not local.
raven101 is offline   Reply With Quote
Old 04-01-2009, 01:18 PM   #9183
raven101's Avatar
still spinning exiting the hairpin. going to try adding the rings on the top plate.
Old 04-01-2009, 01:22 PM   #9184
raven101's Avatar
could my choice of body have an affect on the handeling also? I am running a protoform LTC-R.
Old 04-01-2009, 01:23 PM   #9185
John_S's Avatar
How does your diff fell is it smooth and tight? I run my diff tight. If your diff slips atoll then there is a higher chance your car will spin out exiting a corner. p.s i have used the ltc-r and never noticed this issue
Old 04-01-2009, 02:21 PM   #9186
raven101's Avatar
the diff is smoth and i have it set tight then backed off 1/8th turn
Old 04-01-2009, 03:12 PM   #9187
Send a message via MSN to Bigger Brother
What are your droop settings front and rear?
Personally, I would only run with 0.5mm difference in ride height front to rear (ie lower the rear to 5.5)
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-01-2009, 06:41 PM   #9188
mr crum's Avatar
Send a message via Yahoo to mr crum
set ur ride heighth to 5.5 all the way around then set ur droop to 6 in the front and 4 in the rear
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 04-02-2009, 12:28 PM   #9189
B-DAWG's Avatar
The carpet is killing my bearings. I tried avid and there not instock. Where's everyone getting there bearings? I really hate to have to go back with stock.
Spektrum DX3R
Revo - RB Mods OS .18 TZ
RC8 - RB Mods OS .21 Vspec
Mugen MTX4R - OS speed .12 TZ
TC5 - Mamba Max 5700Kv
B-DAWG is offline   Reply With Quote
Old 04-02-2009, 02:17 PM   #9190
raven101's Avatar
tower hobbies has the acer ceramic bearing kit for the tc5 part# ca013 for 89.95 for the set.
Old 04-02-2009, 08:14 PM   #9191
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Default lipo plate and tray
I seen so mant differant weight plates and lipo trays for the tc5. What is the best one. I run the Diggity rip stick 5300.
BIG DADDY8 is offline   Reply With Quote
Old 04-02-2009, 08:59 PM   #9192
Maybell's Avatar
Check out the PPD Billet ballast system. Thats what I use anyway. It works great! www.ppdbillet.com
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 04-02-2009, 10:09 PM   #9193
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
+1 For the PPD tray, and its not a copy like another brand is around here is hehe
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 04-02-2009, 10:13 PM   #9194
Rommel's Avatar
+2 for the PPD tray.
Rommel is offline   Reply With Quote
Old 04-03-2009, 08:41 AM   #9195
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Originally Posted by jag88 View Post
Rick Hohwart, any plans on some new cvds and axles that actually fit the bearings ?
Current axles have to small a dia. and therefore create slop.
Thanks.
Any ideas how to remove this slop?
IIGQ4U is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
