Old 03-30-2009, 09:56 PM   #9166
katfish317's Avatar
You can use simple green also for tire cleaner, it removes all the old rubber and makes them tacky like new.
katfish317 is offline   Reply With Quote
Old 03-31-2009, 04:10 AM   #9167
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by bvoltz View Post
the screw is not long enough to connect this. When I remove the spring it will reach the nut.
I even used tried the screw from the current diff and it would not work either. It only works with the plastic halfs..
What am I'm doing wrong?
i forget the part number but go to ur lhs and ask them for a t nut for a rc10 t3 stadium truck they work much better
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-31-2009, 07:49 AM   #9168
Hey guys, I need to order a TC body and I am wondering what ppl are using now adays. I will be racing 19t and open mod on carpet with foam and rubber.
Josh
JoshM20 is offline   Reply With Quote
Old 03-31-2009, 09:00 AM   #9169
revo61's Avatar
Trader Rating: 18 (95%+)
DNA2, Mazda 6 or speed 6 are most popular.
Josh
JQ The Car White Edition/Reds R7E/Reds 2113 pipe
Airtronics MT4/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM /WWW.DIALEDHOBBIES.COM /WWW.TALLAHASSEERC.COM
revo61 is offline   Reply With Quote
Old 03-31-2009, 10:34 AM   #9170
geeunit1014's Avatar
Josh
Foam - R9-F
Rubber - LTC-R
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-31-2009, 10:52 AM   #9171
ahh now we have a debate!
Looks like the R9 and LTC would give you more steering, more forward downforce. Is that the case?
Old 03-31-2009, 02:04 PM   #9172
mr crum's Avatar
idk about this ltc u speek of but the r9-r give u alot of front downforce almost 2 much
TEAM B.R. RACING
Old 03-31-2009, 02:36 PM   #9173
raven101's Avatar
Send a message via MSN to raven101 Send a message via Yahoo to raven101
Default set up isues
i have a problem with my set up that hopefully someone can help with. every thing is set up fairly well the problem i am having is when exiting a tight corner say like a right hand hair pin, the right rear tire plants so hard that it will lift the left front letting the front diff unload and allowing the car to spin exiting the corner. it unloads so hard it actually blew a pre glued jaco rubberz tire off of the prizm wheel. i am powered by a 13.5 losi xcellerin system running a 75 tooth spur and a 30 tooth pinion. not to excessive i dont think.
any help would be great.
thanks in advanced
associated tc5r, academy sb v2, associated tc6, tekin,
castle creations, orion, novak, reedy. lets all have fun. support your local hobby shop, and dee and mee if its not local.
raven101 is offline   Reply With Quote
Old 03-31-2009, 02:44 PM   #9174
John_S's Avatar
Can you post your setup and what surface you run on?
John_S is offline   Reply With Quote
Old 03-31-2009, 02:59 PM   #9175
raven101's Avatar
i run on soda preped assphault, blue spring front, green rear. -1.5 deg camber front -2.0 rear. 0 deg total toe front +1deg. total toe rear. no sway bars 5.5mm ride hight rear, 5.25 front. 4 deg. caster. 2mm wheel base rear 1mm front. 40 wt. oil front and rear
Old 03-31-2009, 10:37 PM   #9176
bvoltz's Avatar
Trader Rating: 44 (100%+)
Ok, I know what you are talking about, it is a white T nut, correct?
But the screw is not reaching the T Nut....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 04-01-2009, 04:49 AM   #9177
Stone D's Avatar
Location: Too close to the great mouse house known as Disney World.
Send a message via Yahoo to Stone D
Talking
Now I'm probably the worst person to try to answer this one, so I look forward to any corrections made to me. Guess I'm testing my knowledge?
Anyway, the adding the sway bars should definitely help with that issue, as would lowering the front, or alternately raising the rear. I believe you are running whats known as a pro-squat, with the rear being lower. This will cause the rear to plant more on a hard takeoff, such as exiting a tight curve.
The bonus to that setup is that it will help reduce dive on corner entry. So my guess is that you are fast into and through the turns, but are having problems with exiting.
The sway bars would also help reduce body roll, which would help keep the tires planted on turns as well.
If I'm wrong, anyone and everyone please feel free to correct me, and also teach me a thing or two. Trying to learn here...
Stone D is offline   Reply With Quote
Old 04-01-2009, 06:32 AM   #9178
raven101's Avatar
sway bars are something i forgot to mention i did have them on front and rear but someone else said try without, after taking them off it did help alittle but the front still lifts. i will try raising the rear and see what happens. i will let you know later this afternoon.
Old 04-01-2009, 06:33 AM   #9179
Send a message via MSN to Bigger Brother
Personally I would have said that your rear spring is too soft. I almost always use blue front and silver rear springs outdoors, green springs only if the track is not prepared or very bumpy.
Other than that, I'd check your droop settings are equal left to right and that the car is properly balanced.
What roll centres are you running (ie which suspension arm blocks and which mounting hole?)
HTH
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-01-2009, 08:27 AM   #9180
Try adding more rear toe more like 2.5-3 deg thats what i always run, also what position are the shocks in on the tower and arms.
Niall is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
