Old 03-25-2009, 02:13 PM   #9121
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Im in Vegas...if you ever want to come down and race an event let me know...we can set something up where you can ship your stuff to the track...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 03-25-2009, 02:58 PM   #9122
balistic's Avatar
Trader Rating: 113 (100%+)
The dice we had is still giving me a smile, one of the best races I have ever had. Thanks for inviting me.
balistic is offline   Reply With Quote
Old 03-25-2009, 03:34 PM   #9123
trdsupra88's Avatar
Ive never raced that clean, fast, and close with anyone before...I couldnt sleep for 2 days...come back anytime man
I cut my own hair ☆
Old 03-25-2009, 10:07 PM   #9124
[QUOTE=Rojna;5547809]if u gona run rubber go for the TC5R
with the R you get updated belts ( much smoother then stock TC5 ), new diff cam holders, aluminium diff outdrives ( tc5 has plastic ) and ITF chassis plates which make the car easier to drive.
thanks for the feed back i think i will go with the ft tc5r
bigco66 is offline   Reply With Quote
Old 03-25-2009, 10:20 PM   #9125
Hyde's Avatar
yep that's you're best bet.
I'm a long time basher. and not a new to the touring car racing. its a smooth car. easy to drive. and goes where you want it to. (but my body is a wreck because I'm just getting into it lol)
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 03-25-2009, 10:26 PM   #9126
trdsupra88's Avatar
I cut a transponder mount out of the radio tray from my RC8...no PTs at the hobbytown I race at...thought I would post it up in case anyone else has to use house transponders...
I cut my own hair ☆
Old 03-25-2009, 10:29 PM   #9127
Hyde's Avatar
who puts shims on the diffs ? the ones that go next to the cams and diff? does it smooth things out a little?
and who remembers when some pro drivers put the rear tc3 shock tower in the front, so the car will have a rear shock tower in the rear and a rear shock tower in the front. has this ever been done on the tc5?!? lol
Old 03-26-2009, 06:37 AM   #9128
speedsterblade's Avatar
I shimmed mine slightly just for better alignment w/ the belts & center pulley. duno if it makes any difference...this is my first belt car but seemed logical to me to try to center the belts.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 03-26-2009, 09:12 AM   #9129
Jerry P's Avatar
Trader Rating: 44 (100%+)
Does any one have a good starting point for a TC5R on asphalt that is untreated. No VHT or soda just plain asphalt. I can use any tire/sauce combo i want.
Jerry
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 03-26-2009, 09:24 AM   #9130
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
Try Bob Stelflue's 2007 Reedy setup. It was pretty stable on a totally unprepared (and dusty) track even without treating the tires. I think that with a few minor tweaks to suit the track it should work just fine.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 03-26-2009, 10:27 AM   #9131
Jerry P's Avatar
Thanks I'll look for that set up.
Jerry P
Old 03-26-2009, 02:49 PM   #9132
mr crum's Avatar
Send a message via Yahoo to mr crum
i asked the same question and some of the pros said it will disturb the front end so i didnt try it
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-26-2009, 05:28 PM   #9133
katfish317's Avatar
Jerry
I personally have run Ryan Cavalieri's setup with a few tweaks from 2007 On Road Nats. Changes I made were fronts springs are blue not gold, I also run the front camber at 2degrees for a little more steering. This setup I have run at two different tracks, one concrete, and one asphalt and both tracks it has been great, just had to check the car over between rounds no changes at all.
katfish317 is offline   Reply With Quote
Old 03-27-2009, 08:21 AM   #9134
If you have a TC5, stay away from Integy. One of my rear arms had a swaybar hole that was unthreaded (they didn't tap it). And both the rear hub carriers aren't machined deep enough to let the bearings seat completely. When you put it all together it puts a lateral squeeze on the bearings.. I didn't notice and ruined some nitride bearings 3 packs into them.
Their support has been most unhelpful. Instead of taking their unfinished part back (rear arm) and giving me a completed one, they only offered a discount on buying another one. Integy also says that since I didn't buy them directly from them they can't verify that they are the right parts (bought them from Tower Hobbies, tower won't take them back, no surprise). They look just like the parts I took off, just like the ones in the pictures, and fit perfectly except for the mentioned problems.
So instead of fixing the problem like a responsible company, they chose to shrug it off.
Its not like I'm asking for much, just the parts I ordered, although machined RIGHT. I didn't ask them to replace the bearings or anything (that was my stupid fault assuming the parts were in tolerance).
Beware of Integy.
jackansi is offline   Reply With Quote
Old 03-27-2009, 09:05 AM   #9135
trdsupra88's Avatar
The only good thing ive seen come from them are wing mounts for the b4/t4...everything else is unfitting and unfinished...
I cut my own hair ☆
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
