Old 03-24-2009, 04:59 PM   #9106
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default Set up
Hello guys,
I was looking at the posts, there a lot of information here.
The thing is I race in a track that is bumpy, and have low grip (asphalt track).
The tires are handout, also the motor, Lrp Stock Spec 9.5.
On the first race of the season, my car did not well, to tell you the truth I ended in the last position.
I am using the ITF top deck and chassis, blue springs in the front and silver in the rear.
The car was completely loosing the rear on the corners.
I am thinking of using the gree spring on it and I am going to use a thinner oil on it.
What else should I look for.
Some guys told me to use 6 degrees caster blocks on the front, what it will help on my driving?
I am from Brazil and I would like to leave my messenger adress, I do not know if I am allowed to that but there it goes: surfingaddiction@hotmail.com
The idea is to have contact with other TC5 drivers to exchange information, on my track most started with this chassis but now most have migrated to S400 and Cyclone TC.
I want to keep going with the TC5.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 03-24-2009, 05:37 PM   #9107
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by Fabricio View Post
Hello guys,
how much rear toe do u have and if u have none u need 3 degrees on each side that is a great starting point run 35 weight oil and blue springs all the way around ride heigth at 5.5
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-24-2009, 05:54 PM   #9108
Fabricio's Avatar
I will try with this figures.
What about rear camber?
Old 03-24-2009, 06:31 PM   #9109
mr crum's Avatar
2 degrees all the way around
TEAM B.R. RACING
Old 03-24-2009, 07:46 PM   #9110
racer x 1's Avatar
Trader Rating: 27 (100%+)
hey guys i was wondering if i could get some other opinions on running the itf top deck? most of the guys i run with here in socal say that it is not a necessity only another tuning option. I am currently running a modified stock top deck that allows more flex, however when i have compared the torsional flex that my car has compared to the cyclone, xrays, and 416 they all seem to have more flex torsionally then the tc5.
thanks for the help
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 03-24-2009, 08:06 PM   #9111
katfish317's Avatar
Personally I run both upper and lower ITF chassis parts. But I do not use the orings unless the track has little grip then I use them. A modified top deck is okay but it is still thicker then the ITF top deck and that will make a small difference in torsional flexibility.
katfish317 is offline   Reply With Quote
Old 03-24-2009, 08:41 PM   #9112
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
What can you expect from going from 1.5* to 2* for camber?
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 03-24-2009, 08:50 PM   #9113
rcterp's Avatar
Trader Rating: 35 (100%+)
More traction where you put it. If you go from 1.5 to 2 up front you'll get more steering. If you go from 1.5 to 2 in the back you'll push more.
Anything over 2 and you're going past the optimal point.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 03-24-2009, 10:06 PM   #9114
trdsupra88's Avatar
Hey, I changed springs, then body and still wasnt able to get rid of the push I was having and realized I didnt have another heat to try toe out...will .5* of camber overcome the push better than .5* of toe out? thanks guys.
I cut my own hair ☆
Old 03-24-2009, 10:07 PM   #9115
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Are you able to lay down your shocks? Have you played with roll center?
IIGQ4U is offline   Reply With Quote
Old 03-24-2009, 10:47 PM   #9116
trdsupra88's Avatar
no...I guess I need to research roll center now...
I cut my own hair ☆
Old 03-25-2009, 05:04 AM   #9117
mr crum's Avatar
i would try more toe out b4 i put more camber
TEAM B.R. RACING
Old 03-25-2009, 05:07 AM   #9118
mr crum's Avatar
thanks for the help
i run rubber tire on asphalt i love the thick chassis and top deck i like making the suspension work and with the thicker chassis u have fewer tweaks to hunt down
TEAM B.R. RACING
Old 03-25-2009, 09:12 AM   #9119
trdsupra88's Avatar
Thanks again Crum...
I cut my own hair ☆
Old 03-25-2009, 12:29 PM   #9120
mr crum's Avatar
anytime man just tryin to help wat city are u in trd
TEAM B.R. RACING
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
