Old 03-16-2009, 06:23 PM   #9061
B-DAWG's Avatar
Thanks for help guys, I got my parts on the way and I also picked up a Manutech lipo weight. So I hope I can get it all balanced out and set-up for this weekend
Spektrum DX3R
Revo - RB Mods OS .18 TZ
RC8 - RB Mods OS .21 Vspec
Mugen MTX4R - OS speed .12 TZ
TC5 - Mamba Max 5700Kv
B-DAWG is offline   Reply With Quote
Old 03-16-2009, 10:33 PM   #9062
Team STPN's Avatar
Any suggestions on balancing the chassis???
Team STPN is offline   Reply With Quote
Old 03-16-2009, 11:27 PM   #9063
Trader Rating: 23 (100%+)
I am looking for a tc5R if anyone has one for sale. I prefer one that has been ran indoor only as well. I also posted in the wanted section as well in case you ask. Email me with what you got at bmcallister01@aol.com
bmcallister is offline   Reply With Quote
Old 03-17-2009, 03:18 AM   #9064
mr crum's Avatar
Send a message via Yahoo to mr crum
if u have a harbour freight where u live by some pocket scales when i bought them they were 13 dollars a piece they work great and they dial the car in something fierce
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-17-2009, 04:03 AM   #9065
Trader Rating: 17 (100%+)
Originally Posted by LATC3 View Post
what do ya mean?
just wondering if there is a new version in the pipeline , I currently run 2 of them with some good success but things do tend to wear out so would like to know what team associated have planned next , they dont seem to concerned with Touring cars at the moment
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 03-17-2009, 05:51 AM   #9066
Default Gearing
I need some help on were to start with pinion and spur gear. TC5, Tekin RS speed control, 17.5, Foam tires, 64 pitch gears and small to medium track.
Lugnutz1 is offline   Reply With Quote
Old 03-17-2009, 08:39 AM   #9067
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I am guessing here because manufacturer's tend to keep to themselves about their product life cycles. However, I don't see them changing the 5 anytime soon. Keep an eye on RC50.com for pictures from the Nationals this weekend. The A-Team will be there so there will most likely be pictures posted if Nash can get them.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-17-2009, 08:49 AM   #9068
STLNLST's Avatar
Trader Rating: 19 (100%+)
I have some chassis balancing tools if you need them. They work for left to right balancing but not front to back. Balancing is only one of your problems Better get Mo on the phone and get dialed in
STLNLST is offline   Reply With Quote
Old 03-17-2009, 09:26 AM   #9069
speedsterblade's Avatar
Can't you use the holes in the center of the shock towers to string it up and get her balanced? I'm still determine what packs to urn & where to lead it up and haven't tried that myself..but thought that is the purpose of those holes...
also I hear you can use a board w/ nails if the bottom of the chassis has centered holes.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 03-17-2009, 09:32 AM   #9070
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Using 4 scales gets it from side-to-side as well as front to back...I attempted to use the two holes on the bottom but it is a pain in the ass...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 03-17-2009, 09:37 AM   #9071
STLNLST's Avatar
You can use the shock tower method as wellas the balancing balls. The scales would be the way to go to get front and back as well as side to side.
Old 03-17-2009, 08:27 PM   #9072
Team STPN's Avatar
Old 03-18-2009, 07:33 AM   #9073
Quiz for the setup Guru's.... What would you change on Keven's setup if you had 1/2 the grip of the snowbirds track? The local's that went to the birds said our track is about 1/2 the grip of the birds... What would you change and why? OR do you really have to see what the car is doing to make a call on what to change?
I'm trying to learn as much as I can about setups. I've been running this setup except I haven't gotten to the Arm mounts changes & running AE springs & pistions, I'm still running the Foam kit setting for the arm mounts (2's both front arms, 3's both rear arms. I like the setup much better than the Foam kit setup so far but haven't got to run it much.
Originally Posted by Keven H View Post
Here is the latest setup I have been running for 13.5 or 10.5 ! It is the one I used at Snowbirds !
Front :
ride height : 4.2
camber :1.5
caster :6
Toe : 1 out
hex spacing .5mm
wheelbase : 1mm
steering link : 2B
Bumpsteer : 3mm (silver ballstud )
Shock position : 2A
Camber link : 3
Arm mounts Both 3A
2.5mm for arm mount shim
1.5mm uptravel
black rollbar
60 weight oil
#3 piston
xray 28lbs spring
Thick Grease in front diff
A3 belt tension (midlow)
REAR :
ride height : 4.2
camber :2.5
1 deg Hub
Toe : ~2.75 deg
hex spacing .75mm
wheelbase : 2mm
Shock position : 2B
Camber link : 3A
Arm mounts Both 2A
1mm for arm mount shim front
2.5mm for arm mount shim rear
1.5mm uptravel
black rollbar
30 weight oil
#57 piston
xray 17lbs spring (white)
B15 for belt tention (lowest)
Parma Magenta Tires (new compound)
56.4mm
protoform r9 body
hope you guys like it !!!
www.nashrcracer.com
Old 03-18-2009, 08:40 AM   #9074
Suspended
hey speedster.....that setup will be good on just about any bite carpet..you can try taking off the rear sway bar..kevin is a set up guru..he helped me a lot at the snowbirds...and i have ran that setup just about everywhere since..you wont be dissapointed with it...
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 03-18-2009, 09:17 AM   #9075
Thanks for the input!
I like the feel of it...but the rear gets loose on me on the 2nd half of a run. With my limited rug & setup experience (in 3rd season racing) I don't have much to compare it to except what my old tc4ft felt like...I eventually got it dialed for my track but that is my only reference for foam TC.
I did run withOUT any rear sway bar but was running sliver bar up front at the time...on the slow tighter turns the rear tires would lift -late entry to mid corner...adding the rear swaybar back help keep the chassis more level and rears planted. still have the loose 2nd half of a run problem...
Another thing I tried was using .5 degree hubs...I had to cause I broke a 1 degree and didn't have any 1 spares at the time. I'm back on 1 degree now. I prefer less rear toe for higher corner speeds but definitely didn't help my car getting loose later in a run!
the common tire for my track (ThunderRC/nashville) jaco double pinks. I run them on all corners and dope w/ paragon the fronts 1/4 or less and rears full.
www.nashrcracer.com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
