Old 03-12-2009, 05:24 PM   #9016
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by ArmySIGCorps View Post
Are you polishing the rings? I'm doing that and setting the diff to a medium, medium/loose setting but I'm worried that I'm not doing enough to keep them in better shape.
nope straight out of package and i seen the thread the tc5 diffs are great so save ur money ive replaced diff parts twice in almost 2 years maintenance is the key
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-12-2009, 05:25 PM   #9017
mr crum's Avatar
Originally Posted by chrisfrom619 View Post
Since I started with 48 pitch I stayed with it I used 72t spur for pinion 35,37,39 & 41 depending on track layout.
the only diffrence in 48 and 64 is noise less with 64 but i find the teeth on 48 are much more durable
TEAM B.R. RACING
Old 03-12-2009, 08:16 PM   #9018
I AM LOOKING TO GET INTO ONROAD RC I HAVE BEEN RACING OFFROAD RC FOR ABOUT 10 YEARS NOW SO I KNOW THAT RC IS ALL ABOUT GETTING THE BEST BANG FOR UR BUCK. SO I SAID ALL THAT TO ASK THIS QUESTION WHAT IS THE DIFFRENCE BETWEEN THE FT TC5 AN THE FT TC5R? AN IS IT WIRTH ME PAYING THE EXTRA 100.00 DOLLARS FOR THE FT TC5R OR SHOULD I JUST BUY THE REGULER FT? I NEED YA'LLS HELP THANKS
bigco66 is offline   Reply With Quote
Old 03-13-2009, 12:52 AM   #9019
Plus 64 dp gives you a more direct feeling while driving. That's because you've got around 1,5 times more teeth on your gears than when you use 48dp. This means throttle and brake will be more directive because it can transfer the movement sooner. Downside is that 64dp is more likely to damage when something comes between your spur and pinion.
The TC5 is with a normal topdeck and chassis. The TC5 has got the ITF chassis and topdeck, which are a bit thinner and better for rubber/asphalt racing. Furthermore with the R you've got the solid axle, in stead of a diff. If you will go racing on rubber/asphalt you'd better take the TC5R, if you will go racing on carpet/foam take the TC5 of TC5F
Rick Thomson is offline   Reply With Quote
Old 03-13-2009, 06:18 AM   #9020
Trader Rating: 58 (100%+)
Which chassis is recommended for rubber on carpet?
Where ever I may roam
Bigcheese is offline   Reply With Quote
Old 03-13-2009, 06:31 AM   #9021
ITF. Or the TC5R car.
Some where in Illinios the mob is missing their leader.
You have nothing to fear but change itself.
ArmySIGCorps is offline   Reply With Quote
Old 03-13-2009, 07:13 AM   #9022
balistic's Avatar
Trader Rating: 113 (100%+)
I have raced motorcycles for years and when I hear people say " I could feel this or that" I laugh. I thought I was never going to get "that special feel" they had. then when I started beating them I realized they were full of it.
the best example was the 2003 Kawasaki ZX6R ZXRR. there was a 1.4 mm difference is stroke and a magazine guy attributed the RRs better turn in to reduce crankshaft enertia. well it was the same blank offset ground, same mass. I rode both and I new the chassis specs were the different (I couldn't feel that either). He was pulling it out his arse trying to sound smart.
Not that you are doing the same but I know I wouldn't "feel" the difference. I am just trying not to hit the boards right now.
I know I would hear the difference though. I hear the 1/8th scale electric with 32 pitch and they sound a box of bolts going by.
balistic is offline   Reply With Quote
Old 03-13-2009, 08:22 AM   #9023
mr crum's Avatar
u want ft tc5 it has thicker chassis or even the tc5 f the tc5 r has the itf chassis
TEAM B.R. RACING
Old 03-13-2009, 08:31 AM   #9024
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default what
wouldnt you want the tc5r rubber tire car with the itf chassis on carpet and dosent that car come with the itf chassis? or you want the thick chassi on carpet to take some flex out of the car . im new to the tc5 cars
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 03-13-2009, 09:10 AM   #9025
The FT TC5R kit. Call your LHS and have them order one!
Old 03-13-2009, 09:39 AM   #9026
... WHAT IS THE DIFFRENCE BETWEEN THE FT TC5 AN THE FT TC5R? ...
if u gona run rubber go for the TC5R
with the R you get updated belts ( much smoother then stock TC5 ), new diff cam holders, aluminium diff outdrives ( tc5 has plastic ) and ITF chassis plates which make the car easier to drive.
Actualy YOU have the option to build it as a limited slip spool or a diff, all parts are included.
Rojna is offline   Reply With Quote
Old 03-13-2009, 09:41 AM   #9027
Thanks for the comments!
I have a used early 2.5 chassis I haven't even driven yet. I'm setting it up for VTA on carpet & trying to decide if I want to blow the money on the new chassis plates. I put the rubber setup on it & I'll see how that does. I have spent enough on getting to this point & I still need the 21.5 motor yet. lol
Old 03-13-2009, 12:01 PM   #9028
mr crum's Avatar
for carpet u want the thicker chassis
TEAM B.R. RACING
Old 03-13-2009, 12:50 PM   #9029
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
When running on carpet with rubber tires the local hot shoes are running the ITF chassis pieces with the hard suspension pieces as that fits the high bite condition.
If you are running foam on carpet then the 5F kit is the one to go with.
If I remember correctly, I found it less expensive to buy the 5R kit and then add the hard suspension pieces. I started with the Caster blocks and then knuckles and then arms.
If you are running low to medium bite traction on carpet with rubber tires you won't have any problems getting the 5R to work.
Unless you are a Pro and can notice a slight change it won't matter which one you get. Just go the track and have some fun.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-13-2009, 05:08 PM   #9030
B-DAWG's Avatar
Hey guys, I coming from nitro (MTX4R) so forgive me for the stupid questions. I just built a FT TC5 kit and I'm ordering the oneway and spring kit. Are there any other parts that I need for spares or must have upgrades? I plan on running on carpet (170 X 40) with either foam or rubber. My system MM 5700 on 2S. Is there a diff upgrade for the rear?
Spektrum DX3R
Revo - RB Mods OS .18 TZ
RC8 - RB Mods OS .21 Vspec
Mugen MTX4R - OS speed .12 TZ
TC5 - Mamba Max 5700Kv
B-DAWG is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
