Old 03-10-2009, 02:18 PM   #8986
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by trdsupra88 View Post
Has anyone else noticed that when full steering is used, the front wheel chatter and seem bound? Just holding the car in the air and with little throttle applied, the front wheels chatter. When I turned the end points down to the point where this didnt happen, the wheels werent turned far enough to be able to make corners. Should I just turn the EPA to full and not worry about the chatter?
take ur cvds apart and put a little bit of grease in the inside of the cvd that will fix the problem
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-10-2009, 02:33 PM   #8987
speedsterblade's Avatar
where are you talking about? cause I used grease on the cvds at build so the metal to metals should be lubed...and I have the same problem at full lock ..but turning down the epa worked for fine for me.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 03-10-2009, 02:37 PM   #8988
mr crum's Avatar
do it just like u did when u built it i take mine apart every 5 or 6 races as part of maintinance i clean and lube the bearing at the same time
TEAM B.R. RACING
Old 03-10-2009, 02:49 PM   #8989
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
My wheels would have to barely turn for the chatter to stop...now that you mention the lube, it make sense that that could be the only thing causing this...Mr Crum is the man
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 03-10-2009, 02:52 PM   #8990
One thing I use for the maintenance of my CVA's is a Super Lube Product called dry lube. Comes in a spray can and it cleans quite well and breaks down old grease FAST then leaves a clean pre-lubed surface that is easier to clean next time around. I used this stuff in paintball for high/low pressure metal on metal contacts that would cycle at 20 BPS.
Some where in Illinios the mob is missing their leader.
You have nothing to fear but change itself.
ArmySIGCorps is offline   Reply With Quote
Old 03-10-2009, 04:19 PM   #8991
agressive1's Avatar
Trader Rating: 15 (100%+)
Thanks for the help guys, got most of those parts coming with the kit today.
Also im going to run a Novak 4.5 on lipo batteries, how often should i be doing diff checks and will my diffs be fine.
As far as i know the car has a front spool, alloy out drives rathen then the plastic drive cups.
AE RC8T
Hyper 8 PRO
GRP 21 PROMO
Ninja 21 BO1A
Mini LST2
DX3R
>>>>>PROLINE<<<<<
RACING TO BRING YOU THE BEST
agressive1 is offline   Reply With Quote
Old 03-10-2009, 07:42 PM   #8992
mr crum's Avatar
im just tryin to help but thanks ive been running associated onroad for bout 3 years now and i was one of the first hundred or so to get a tc5 ft not r and ive drove other cars and always think my tc5 is better the car is stout other than my mistakes on the track breaking stuff i think ive replaced the belts and a couple of outdrives anytime u have a question dont b afraid to ask
TEAM B.R. RACING
Old 03-10-2009, 07:44 PM   #8993
mr crum's Avatar
i run 13.5 i rebuild my diff bout every 6 races but u runnin that mod motor u might wanna doit every 3
TEAM B.R. RACING
Old 03-11-2009, 05:45 AM   #8994
Crum,
Are you replacing the diff rings and balls or are you just checking for flat spotting and wear?
Old 03-11-2009, 12:54 PM   #8995
mr crum's Avatar
Originally Posted by ArmySIGCorps View Post
Crum,
over a period of time the diff rings will get grooves in them once they get grooves u can flip them over then after that side gets grooves u have to replace them i replace the balls after both sides of the rings are shot so just watch for grooves then once u use both sides trash them and get the rebuild kit and start from scratch
TEAM B.R. RACING
Old 03-11-2009, 04:11 PM   #8996
Trader Rating: 23 (100%+)
I am wanting to convert my tc5f to a rubber version. Besides the itf chassis and a one way what else is used? Do I do away with the hard arms as well?
bmcallister is offline   Reply With Quote
Old 03-11-2009, 05:19 PM   #8997
mr crum's Avatar
well i run the thick chassis with rubber tires the tc5r has a slipper spool, aluminum rear diff,itf chassis,itf top deck,all soft parts other than that it the same kit
TEAM B.R. RACING
Old 03-11-2009, 08:06 PM   #8998
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Where can i find a 64p gear chart for the TC5?
BIG DADDY8 is offline   Reply With Quote
Old 03-11-2009, 08:16 PM   #8999
revo61's Avatar
Trader Rating: 18 (95%+)
www.gearchart.com
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 03-11-2009, 08:19 PM   #9000
BIG DADDY8's Avatar
i went there but it does it in 48p. Running the novak 17.5 and need to gear it to 3.5. Like to get it in 64p.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
