Old 03-05-2009, 11:19 PM   #8956
Hey guys, I need some help here, I just accommodated a FT TC5R brand new in the box. I was puting the diffs togather and found the screw is too short. I have compressed the spring with vise grips then heat heating it up with the torch. Still can't get it to go. I ended up breaking the ears offtrying too press down on it with a screw driver. Any suggestions.
mark_stnly is offline   Reply With Quote
Old 03-06-2009, 02:39 AM   #8957
getpip's Avatar
This may sound obvious but make sure your nylock nut is seated all the way down in the opposing diff half.
These are quite snug and sometimes take a little persuading to seat all the way in.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 03-06-2009, 03:18 AM   #8958
mr crum's Avatar
Send a message via Yahoo to mr crum
go to ur lhs and ask them for a t nut for a rc10 t3 stadium truck never have this problem again
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-06-2009, 06:40 AM   #8959
balistic's Avatar
Trader Rating: 113 (100%+)
Originally Posted by balistic View Post
What about the stiction question? Is ride height measured from the car rebounding of bottoming?
is this too stupid a question? I am guessing at the answer with a used car.
balistic is offline   Reply With Quote
Old 03-06-2009, 07:16 AM   #8960
Thanks guys
Old 03-06-2009, 11:11 AM   #8961
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
It is only a stupid question if...I always pushed down on my car and then measure ride height.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-06-2009, 11:15 AM   #8962
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Is a spool recommended for a small tight track or would a diff be a better choice?
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 03-06-2009, 11:19 AM   #8963
Maybell's Avatar
If you are running on tarmac with rubber tires, then a spool is better most of the time.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-06-2009, 12:52 PM   #8964
trdsupra88's Avatar
That would have helped, thanks, Im running sorex's in a P-lot, 7-9 seconds
I cut my own hair ☆
Old 03-06-2009, 02:17 PM   #8965
Maybell's Avatar
Then try a spool for sure...also try #3 roll-center holders, 3.5 deg rear toe(all inboard toe) and soft suspension parts, with the ITF chassis and topdeck. What kit did you buy? TC5R?
Old 03-06-2009, 02:54 PM   #8966
trdsupra88's Avatar
Thanks for the advice...I got the TC5 afew months back and ran it for the first time at BC raceway in California and the spool worked great but the track here in Vegas is super tight and technical...I am running 1.5* of camber and rear toe, no toe in the front...blue springs in front and green in the rear with 35w fluid and the silver sway bar in the front with the ITF top plate...thanks again for the help...off to the races
I cut my own hair ☆
Old 03-06-2009, 07:43 PM   #8967
mr crum's Avatar
i run same setup but 3 degrees rear toe and 1 degree toe uot on the front that will help u in the turns
TEAM B.R. RACING
Old 03-06-2009, 08:06 PM   #8968
I tell u what I am beginning to hate this TC5R, first it was the diff issue, then one of the turnbuckles for the steering wasn't threaded right, and now the steering bellcrank rod that bolts to the bottom of the chassis wasn't even drilled or tapped. Its sad its a brand new kit. I should've bought a Shuey.
Old 03-07-2009, 12:15 AM   #8969
trdsupra88's Avatar
Which helps the turn in the most? I just got back and it was incredible! The only issue I had was a bit of push when entering from high speed dive ins...if I broke, then drove through it didnt happen but im more of a diver...
I cut my own hair ☆
Old 03-07-2009, 06:19 AM   #8970
Lebatek's Avatar
Send a message via AIM to Lebatek
The Tamiya blue anodized .5mm and 1mm axle spacers we use are part number 53646 or OP646. They go outside the hex.
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
