Old 03-03-2009, 08:30 AM   #8941
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
Originally Posted by speedsterblade View Post
Are you getting any specific flashing on the GTB after it stops? I had a similar problem but had 8 or 10 flashes after it stopped. I had to have it replaced.
Yes the red light is flashing I just turned it off. Which one did you replaced the GTB or the Motor.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 03-03-2009, 11:23 AM   #8942
speedsterblade's Avatar
it was the GTB I had to replace....
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 03-03-2009, 10:16 PM   #8943
Team STPN's Avatar
Originally Posted by Josh Hohnstein View Post
Sorry but I just about never use a scale.
But when I do check the car it goes in this order:
set ride height at all 4 corners
check camber
set droop
check tweek
The scales are probably a good idea for the first time set up for weight placement. But i've just gotten used to doing it with out them.
Hey Josh,
Quick question for the .5 & 1 mil axle spacers. Where do you them??
Team STPN is offline   Reply With Quote
Old 03-04-2009, 05:09 AM   #8944
Originally Posted by Team STPN View Post
Hey Josh,
The ones I use are sold by tamiya but im sure alot of companies sell them. I'll see if I can find some part numbers.
Josh Hohnstein is offline   Reply With Quote
Old 03-04-2009, 08:44 AM   #8945
berserk's Avatar
is anyone using front body post from other brands? the front post included in the kit seems short. thanks.
berserk is offline   Reply With Quote
Old 03-04-2009, 09:03 AM   #8946
balistic's Avatar
Trader Rating: 113 (100%+)
check camber
set droop
check tweek
I was looking at this and wondering why not do the fixed adjustments first?
Droop
Camber
Ride height
tweek
I was also wondering if stiction is measured as a component of ride height?
Another way of asking that is do you measure ride height from where the car settles onto the springs or where it rebounds to
balistic is offline   Reply With Quote
Old 03-04-2009, 10:50 AM   #8947
Droop
Camber
Ride height
tweek
If you try to set your camber while your ride height is off you will have some pretty messed up camber settings when the ride height is set correctly.
Old 03-04-2009, 12:58 PM   #8948
balistic's Avatar
Ok then, so the ride height sets the position of the wheels (1) then the camber (2) The droop only changes the drop out of the suspention. I get that, I was thinking droop effected the position of the wheels, but the suspension is in sag.
What about the stiction question? Is ride height measured from the car rebounding of bottoming?
Old 03-04-2009, 04:49 PM   #8949
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
They really are not that short unless you are using a body other than a sedan.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-04-2009, 05:50 PM   #8950
Team STPN's Avatar
I would appreciate that..thanks..
Old 03-04-2009, 06:35 PM   #8951
Jerry P's Avatar
Trader Rating: 44 (100%+)
They do seem kind of short when running a Mazda Speed 6. Roof height is set to pass roar tech inspection. I am running the top most hole on the body post. On my foam car with a Mohawk 2 the front post's have plenty of space.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 03-04-2009, 08:02 PM   #8952
STLNLST's Avatar
Trader Rating: 19 (100%+)
53646 is the part number you might be looking for from Tamiya LXFSD2 is the tower part number. These may be on my car on the 14th if we dont get rained out.
STLNLST is offline   Reply With Quote
Old 03-04-2009, 08:17 PM   #8953
theDover's Avatar
Gearing help please.
Running a 5.5 BL on an outdoor asphalt track 120' x 60'.
Any suggestions with pinion/spur to start with would be appreciated.
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ facebook
theDover is offline   Reply With Quote
Old 03-04-2009, 09:17 PM   #8954
Team STPN's Avatar
Can you get me .5 and 1 m spacers?? I promise i will not use your name in vain
Old 03-04-2009, 09:25 PM   #8955
STLNLST's Avatar
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
