Old 03-02-2009, 12:31 PM   #8926
racing_jason's Avatar
hey guys got my tc5 and i love it! great car and my favorite part is when i break... i just go to the wall insted of going to the bank getting a loan and then buy the part lol
the only thing i cant figure out is that when i go into the corner it starts to push and then all of a suden it transfers and i spin out. i can avoid it if i just stay in the throtle but at some points in traffic this is not possible?
any adjustment ideas im willing to try! thanks in advanced!
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 03-02-2009, 12:37 PM   #8927
rcterp's Avatar
Trader Rating: 35 (100%+)
Sounds like too much weight is being transferred to the front wheels. There's a ton of fixes. Stand your front shocks up, heavier springs up front, more rear toe, less front toe, etc.
Are you running a one-way or sway bars?
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 03-02-2009, 12:45 PM   #8928
sry i should have been clearer lol
im running foam usually 13.5
the other thing i just thought of is would average grip tracks cause this problem. also i have tried standing shocks up in front or stiffer spring in front, also thicker rear oil, and less rear droop
Old 03-02-2009, 01:00 PM   #8929
rcterp's Avatar
I would assume you'd want to run a spool up front, the one-way would give you way too much steering on carpet/foam. It sounds like the front of the car is diving in too much; I would look at a heavier sway bar up front and/or lighter in the rear; and maybe change the castor a little. I have also found that my TC5 drives better with a little larger turn radius than other cars.
Φ
Old 03-02-2009, 02:33 PM   #8930
the steering may be a good idea the spool though not so much i hate the way a spool makes a car feel. thank you for the idea though. sway bars i dont know if they would help to much i have gone to gold and it made the problem smaller but it was still there
Old 03-02-2009, 03:11 PM   #8931
Originally Posted by Jsaves View Post
Josh,
How much do you go into making sure the car is balanced front - back and left - right.
I use small scales and try to the the left right within 3 grams.
If you do this is it the last thing after all the other set ups ie. droop, ride height ...
Thanks for all your help
God Bless
Sorry but I just about never use a scale.
But when I do check the car it goes in this order:
set ride height at all 4 corners
check camber
set droop
check tweek
The scales are probably a good idea for the first time set up for weight placement. But i've just gotten used to doing it with out them.
Josh Hohnstein is offline   Reply With Quote
Old 03-02-2009, 07:39 PM   #8932
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
did they ever sort out the shocks on the tc5 (leaks?) thx. lookin at the car for this yr.
R
UltegraSTI is offline   Reply With Quote
Old 03-02-2009, 08:05 PM   #8933
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default lipo tray
hello guys
I would like to know if this 2 fit together o the TC5.
Want to get them from stormer hobbies.
https://www.ssl-stormerhobbies.com/c...l?pn=MAN132102
https://www.ssl-stormerhobbies.com/c...pn=CORSRC79867
I don't like using the normal weights people use here at the track, I think it is more clean to use those.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 03-02-2009, 08:28 PM   #8934
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by Fabricio View Post
hello guys
They should. I can't speak to that exact plate, but I am using basically the same plate from PPD with that tray and they fit just fine.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 03-02-2009, 08:42 PM   #8935
geeunit1014's Avatar
R
As far as I know, its all just operator error in getting the o-ring to seat. If your gonna drop for a TC, this is definately the best deal
PS I have the shocks from that Kyoslow if you need them
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 03-02-2009, 08:45 PM   #8936
rcterp's Avatar
+1 - My shocks have had zero problems.
Φ
Old 03-02-2009, 09:25 PM   #8937
Tubaboy's Avatar
hello guys
The Mantech weighthas raised long edges on the lipo side to help hold the lipo in place. Was looking over one this past weekend at a race. It's sharp. I plan on picking one up!
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 03-03-2009, 05:40 AM   #8938
Trader Rating: 19 (100%+)
+2 no prob with the shocks here and my TC5 is the orginal one that was out.
zake540 is offline   Reply With Quote
Old 03-03-2009, 05:54 AM   #8939
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
Hi guys I have a question about mix and macthing brushless motor and ESC. I know for a fact that you can interchange a different brand motor and ESC. A friend of mine traded me a tekin 17.5 sensored motor and I used it with novak GTB the problem I'm having is the motor would run half a seconds and then stop. What am I doing wrong? I'm using the novak sensor wire I followed the A B C tabs on my motor. What could possibly do this? When I switch back to my novak 17.5 SS everything works fine. The tekin motor was ran one day race and it doesn't smell burnt at all. Please help.... Do i need to buy a Tekin ESC to make it work?
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 03-03-2009, 06:22 AM   #8940
speedsterblade's Avatar
Are you getting any specific flashing on the GTB after it stops? I had a similar problem but had 8 or 10 flashes after it stopped. I had to have it replaced.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
