Old 02-17-2009, 12:00 PM   #8866
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by losi guy View Post
I finally got a chance run my tc5 and all I can say is this car is awesome. Very good race results the first time out.
Possibly time for a new user name??
This one may be available, how bout....Team Ass. Guy. jk.
Really though welcome aboard.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 02-17-2009, 12:47 PM   #8867
Scottrik's Avatar
Trader Rating: 243 (100%+)
Originally Posted by racing_jason View Post
What is the 2.5mm arm shim?
I'm guessing he's going by the "stated" measurement Associated claims the shims are, which would be a 1.5mm plus a 1mm.
Of note, Bryan and I found that Josh's setup sheet he's taken to using the ACTUAL measurement of the shims (which is about 20% less than Associated's stated thickness in most cases) and recording that.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-17-2009, 01:04 PM   #8868
yodace's Avatar
R/C Tech Charter Subscriber
looking for a asphlat set-up? would u guys recommend the same 5.0 for outdoor gearing?
yodace is offline   Reply With Quote
Old 02-17-2009, 02:01 PM   #8869
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
I pm'ed admins about changing that for over a year and no reply to hook me up. Not sure about your name change suggestion Can't wait to get it out on the track again.
How are you guy's measuring your droop, like 2mm above ride height? What's the easiest way? I run 5mm ride height and 2mm above ride height, I usually try to stick my ride height gauge in under the screws.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 02-17-2009, 02:39 PM   #8870
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
I can't seem to find the part anywhere.
Associated #1403 (TC5 Steering Links) does not show up on Tower or Horizon.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 02-17-2009, 02:47 PM   #8871
minittrackmann's Avatar
I was told start at around 4.5 and watch motorr temps. Im going to try 4.80.
Cody
minittrackmann is offline   Reply With Quote
Old 02-17-2009, 05:39 PM   #8872
h
franc furter is offline   Reply With Quote
Old 02-17-2009, 06:27 PM   #8873
I am having a problem with my tc5 pushing coming out of a turn. I have tried different spring combos but can't seem to fix problem. I put silver silver on car now and helped some. I run sorex 28 on low traction carpet. All the setups i see run 6 or 7 on droop gauge front and 4 or 5 rear. Was wondering if anyone has tried oppisite and if it might help my problem thankx.
Old 02-17-2009, 09:49 PM   #8874
Send a message via MSN to Killerkevin
Originally Posted by Josh Hohnstein View Post
Here is a new setup for you guys to try if you want.
I feel that this is the best I have had my car.
Hey Josh I know what motor you are running but what turn was it? Thanks for any info.
Kevin Phillips
Regina Fastraxx RC Club http://fastraxxforum.phpbb-host.com/phpbb/index.php
Killerkevin is offline   Reply With Quote
Old 02-17-2009, 11:03 PM   #8875
Scottrik's Avatar
Don't tell Kevin...he's already to dang fast for us!!
Kevin--any odds you guys coming down for the 2-day and giving us some smack-down, Canadian Bacon style?
Old 02-17-2009, 11:18 PM   #8876
Not to sure about it. There was some talk about the race in our club and in Saskatoon, but not sure. I won't be able to make it this year unfortunately, but will try for next years. I had fun at your guys race last year......ps you guys missed a good race in Regina this last weekend. 51 racers
Kevin Phillips
Old 02-17-2009, 11:37 PM   #8877
I guess what I am actually looking for is the spur gear and pinion range for 64 pitch running 17.5 and 13.5 motors. I just would like to know how big a pinion I can use if I was to use a 106 tooth spur and how small a person can go with that spur gear. Thanks if anyone has an answer for this.
Kevin Phillips
Old 02-18-2009, 05:39 AM   #8878
Hi Kevin,
Most of the time I run a Trinity duo 13.5
As for gears I switch between a 98/40 and a 106/43.
A 98/39 is about as small as you can go, it moves the motor all the way back.
The 106 spur moves the motor about half way forward with 13.5 gearing. Depending how you want the car to handle both are a good tuning option.
With your 106 I think the smallest pinion you will get on there will be in the low 30's. I'm not sure on the biggest.
If you just want to stick with 1 spur a 100 should reach all of your needed ratios for 13.5/17.5 unless you run at some really small tracks.
Josh Hohnstein is offline   Reply With Quote
Old 02-18-2009, 05:45 AM   #8879
Trader Rating: 19 (100%+)
This is for the next time someone ask if the TC5 is a capable car. Just let them watch this video of Kevin Hebert laying it down!
http://www.youtube.com/watch?v=MSsnu...e=channel_page
zake540 is offline   Reply With Quote
Old 02-18-2009, 07:04 AM   #8880
Thank you very much Josh that is exactly what I was looking for.
Kevin Phillips
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
