Old 02-16-2009, 09:20 AM   #8851
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Team STPN View Post
Thanks..
Someone is looking for an advantage the next time out....
STLNLST is offline   Reply With Quote
Old 02-16-2009, 09:33 AM   #8852
Default Snowbird Setup
Here is the latest setup I have been running for 13.5 or 10.5 ! It is the one I used at Snowbirds !
Front :
ride height : 4.2
camber :1.5
caster :6
Toe : 1 out
hex spacing .5mm
wheelbase : 1mm
steering link : 2B
Bumpsteer : 3mm (silver ballstud )
Shock position : 2A
Camber link : 3
Arm mounts Both 3A
2.5mm for arm mount shim
1.5mm uptravel
black rollbar
60 weight oil
#3 piston
xray 28lbs spring
Thick Grease in front diff
A3 belt tension (midlow)
REAR :
ride height : 4.2
camber :2.5
1 deg Hub
Toe : ~2.75 deg
hex spacing .75mm
wheelbase : 2mm
Shock position : 2B
Camber link : 3A
Arm mounts Both 2A
1mm for arm mount shim front
2.5mm for arm mount shim rear
1.5mm uptravel
black rollbar
30 weight oil
#57 piston
xray 17lbs spring (white)
B15 for belt tention (lowest)
Parma Magenta Tires (new compound)
56.4mm
protoform r9 body
hope you guys like it !!!
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 02-16-2009, 10:17 AM   #8853
speedsterblade's Avatar
Thanks Keven for this setup!
I don't have nothing but AE parts avail. at the monment... What would be closest AE pistion to Losi #57?
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 02-16-2009, 10:48 AM   #8854
Jim S's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to Jim S
Jim S is offline   Reply With Quote
Old 02-16-2009, 11:07 AM   #8855
Team STPN's Avatar
I need all the help I can get
Team STPN is offline   Reply With Quote
Old 02-16-2009, 11:11 AM   #8856
minittrackmann's Avatar
For 13.5 with a lipo, running no asphalt what would be a good pinion/spur to start with?
http://www.youtube.com/watch?v=61wL2Eq3qUk the layout is diferent now but you can atleast get an idea of how big the track is.
Cody
minittrackmann is offline   Reply With Quote
Old 02-16-2009, 04:26 PM   #8857
mr crum's Avatar
Send a message via Yahoo to mr crum
Cody
rubber tire 13.5 start at 4.5 and watch motor temps 150 to 160 is the sweet spot for most motors
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 02-16-2009, 05:07 PM   #8858
What exactly would that roll out equal in pinion/spur size? That confuses me alot. lol
Cody
Old 02-16-2009, 05:29 PM   #8859
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by Josh Hohnstein View Post
The new setup seems to have a better balance. The front and rear of the car roll over at the same time when your in a turn. With the old setup it seemed like the rear of the car would stay flat and the front would try to roll alot.
I have tried this setup at 3 tracks. Big, little, open, tight, high bite, low bite, oneway, spool. It seems to work well in all carpet conditions.
xtreme.......i'm not sure a spool is the way to go on a tight technical track.....unless braking is needed.
thanx josh. no need to brake at my track. so i will just try the new setup and keep the oneway as it works real good now. thanx again
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-16-2009, 05:32 PM   #8860
mr crum's Avatar
Cody
are u running foam or rubber
all u have to do to figure out final drive ratio is divide pinion into spur then multiply by internal drive ex 64 p 100 spur \40 pinion= 2.5 x 2.0 internal drive= 5.0
TEAM B.R. RACING
Old 02-16-2009, 05:34 PM   #8861
Im running rubber!
Old 02-16-2009, 05:46 PM   #8862
Well tell me if this sounds about right. 108/48 would equal my 4.50
Old 02-16-2009, 05:51 PM   #8863
mr crum's Avatar
yes 4.50
TEAM B.R. RACING
Old 02-16-2009, 11:26 PM   #8864
STLNLST's Avatar
We can start practicing for the Reedy race now. I just hope the announce the tire sooner than they did last year. We did all that last second testing only to go with the tire we told them the first time
Old 02-17-2009, 10:04 AM   #8865
racing_jason's Avatar
Front :
ride height : 4.2
camber :1.5
caster :6
Toe : 1 out
hex spacing .5mm
wheelbase : 1mm
steering link : 2B
Shock position : 2A
Camber link : 3
Arm mounts Both 3A
1.5mm uptravel
black rollbar
60 weight oil
#3 piston
xray 28lbs spring
REAR :
ride height : 4.2
camber :2.5
1 deg Hub
Toe : ~2.75 deg
hex spacing .75mm
wheelbase : 2mm
Shock position : 2B
Camber link : 3A
Arm mounts Both 2A
1.5mm uptravel
black rollbar
30 weight oil
#57 piston
56.4mm
protoform r9 body
What is the 2.5mm arm shim?
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
