Old 02-12-2009, 07:18 PM   #8836
minittrackmann's Avatar
Whats a good setup for the FT TC5 without the ITF chassis on rubber tires medium to high grip asphalt. Running Lipo and 13.5.
Cody
minittrackmann is offline   Reply With Quote
Old 02-12-2009, 08:03 PM   #8837
mr crum's Avatar
Send a message via Yahoo to mr crum
Cody
go to teamassociated.com there are several to choose from
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 02-12-2009, 11:10 PM   #8838
Team STPN's Avatar
Originally Posted by Josh Hohnstein View Post
I've tried jaco blue's, sorex 28's and xenon tires and have not changed anything.
Thanks..
Team STPN is offline   Reply With Quote
Old 02-13-2009, 01:27 AM   #8839
Here is a new setup for you guys to try if you want.
I feel that this is the best I have had my car.
Hi Josh,
Thank you for posting the setup, I will give it a try. How does it compare to your previous setup, with the higher roll centers?
Best,
Peter
petk is offline   Reply With Quote
Old 02-13-2009, 05:26 AM   #8840
I went onto Team Associated but when I clicked the setup link nothing came up. It used to work for me but it doesn't seem to anymore!?
Whats wrong. Is it my computer or the website.?
Cody
Old 02-13-2009, 05:40 AM   #8841
mr crum's Avatar
Cody
u have to have adobe reader to download the setup sheet
TEAM B.R. RACING
Old 02-13-2009, 10:08 PM   #8842
I need some advice! I recently purchased a tc5f, and I'm in the process of putting it together. I will be running a mm/cc 5700kv with a 2cell 30c 6500 lipo. I do not plan to race indoor on carpet, mainly outdoor street/parking lot usage.
what is the "best" spur/pinion combo? any suggestions for some wheels and tires? Also, does anyone have any other suggestions for various upgrades outside of the stock parts? any other tips for a new tc5 owner?
I've owned a dozen other rc cars, but feel like the tc5 is a bit over my head, haha. I appreciate the help!
Burnin4 is offline   Reply With Quote
Old 02-14-2009, 07:56 PM   #8843
I noticed that the inside of my front wheels are rubbing on the shock ball end when the wheels are turned. Using Vintage Trans am wheels, ball stud is in outside hole. What effect will happen if I move ball stud to inner hole? Any other sugestions?
Lugnutz1 is offline   Reply With Quote
Old 02-14-2009, 08:41 PM   #8844
katfish317's Avatar
Moving the bottom of the shock inward will soften the suspension. You can offset this by moving the top of the shock out one hole also. But this may not give you the same feel in the suspension.
katfish317 is offline   Reply With Quote
Old 02-15-2009, 05:52 PM   #8845
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
I finally got a chance run my tc5 and all I can say is this car is awesome. Very good race results the first time out.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 02-15-2009, 06:02 PM   #8846
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey josh, how is this setup compared to your last setup with the spool. my track is 90x40 but technical and was wondering if a oneway is hurting me and if i should switch to the spool thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-15-2009, 07:27 PM   #8847
any help? Thanks!
Old 02-15-2009, 07:35 PM   #8848
Scottrik's Avatar
Trader Rating: 245 (100%+)
Realistically, for playing in the street or parking lots use whatever you've got. "Setups" are for folks who are racing competitively and are seeking advantage to go that tenth or two faster. Out in the parking lot it's just about whatever is fun...if you don't have a clock or a couple guys running in the same tenth or two to measure yourself against it really doesn't matter.
Just build it and go have fun. Keep track of the motor temp so you don't overheat, but don't obsess about exactly this droop, that shock setting or the exact killer fdr.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-15-2009, 09:54 PM   #8849
fair enough. can I at least get a spur/pinion recomendation? haha! also, any suggestions for a nice set of foam tires and wheels for street? thanks!
Old 02-16-2009, 08:37 AM   #8850
Originally Posted by petk View Post
Hi Josh,
Best,
Peter
The new setup seems to have a better balance. The front and rear of the car roll over at the same time when your in a turn. With the old setup it seemed like the rear of the car would stay flat and the front would try to roll alot.
I have tried this setup at 3 tracks. Big, little, open, tight, high bite, low bite, oneway, spool. It seems to work well in all carpet conditions.
xtreme.......i'm not sure a spool is the way to go on a tight technical track.....unless braking is needed.
Josh Hohnstein is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
