Old 02-08-2009, 02:26 PM   #8791
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
Originally Posted by eddie10 View Post
Can someone steer me in the right direction. im looking for a FDR for 17.5 and 13.5, big track with 115ft straight
I would start with the following and monitor your motor temp.
17.5 - 3.5
13.5 - 4.5
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
Old 02-08-2009, 03:59 PM   #8792
getpip's Avatar
Originally Posted by Kraig View Post
Springs easy to forget. There should be a FAQ between the cars because this question almost always comes up every other week.
Sorry Kraig .. I wasnt suggesting you were lazy ... I was suggesting the original questioner should have made just a teensy bit more effort to look it up rather than relying on thoroughly good blokes like yourself!!!
And me
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 02-08-2009, 05:54 PM   #8793
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by treemagnet View Post
hey everyone
just wondering if many ppl have Tamiya TRF shocks on their TC5s?? i hear bout how good they are so thinking bout putting on mine??
thoughts??
thanks treemagnet
i know several ppl using trf shocks they seem to work for them i use tc3 shocks they dont leak at all compared to the tc5 shocks
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 02-08-2009, 06:29 PM   #8794
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
17.5 - 3.5
13.5 - 4.5
Is the general rule of thumb...lower FDR(3-5) for large tracks and higher FDR(6-9) for small tracks? I am trying to figure it out for a very small track...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 02-08-2009, 07:51 PM   #8795
Jsaves's Avatar
Josh,
Well I got myself a TC5r, had the TC5 with a itf top plate, and tried out your set up ( trackside ).
Well I won two of three heats and tq.
Racing happened in the A main, but I did end up second. Also it has been a while since I tq.
The car was very fast and consistent. It was not loose at all.
I found with your spacer change from 1 mm to .8 etc. I made a goof that Scottrik pointed out. I went with 3.5 mm, the old spacer measurement, to match the 3.4 mm. That is how come it was loose. It did not have the toe needed for the rear.
Thanks for all you guys taking your time and helping us all out.
Thanks Josh H.
God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 02-08-2009, 08:36 PM   #8796
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
And me
Not a problem at all. Sometimes people don't know even when when looking at it. So no worries at all.
You should hear some of the questions I ask Josh.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-09-2009, 06:42 AM   #8797
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
I've got the Orion 3800 30c lipo's with the Specialized RC battery tray. PPD weight tray is on the way.
The problem I'm seeing is that there is about 1.5mm play in the battery side-to side and top to bottom. I assume/hope the PPD tray will take the play out of the vertical but what are people using to take out the play in the horizontal direction?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 02-09-2009, 10:41 AM   #8798
balistic's Avatar
Trader Rating: 113 (100%+)
I am an off roader and am getting into TC racing. I have now and in the past been an associated guy. No one at the two tracks I have been to has a
TC5R and get scowls when I mention it. I have seen Cyclones, 416s, X-Rays and just wanted to go to the horses mouth and ask.
How does the TC5R stack up against these other more expensive cars?
balistic is offline   Reply With Quote
Old 02-09-2009, 10:59 AM   #8799
mo
mo's Avatar
The TC5 is just as capable as any other car out there. Really all the cars are pretty equal. It all comes down to the skill of the driver. When they scowl at you, you can wave the wad of cash you have left over at them and drive on by.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 02-09-2009, 11:03 AM   #8800
speedsterblade's Avatar
Can't answer that one as I run foam/carpet and holding it's own on the rug for me... but have to ask if your avatar is from JenningsGP? I see your in CA but that track looks more like Jennings than willowsprings or anything out west.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 02-09-2009, 11:12 AM   #8801
rcterp's Avatar
Trader Rating: 35 (100%+)
It performs great for me. It's easy to work on and parts are easy to get. It's all personal preference. You might be getting the scowl because there were some quality control issues in the beginning such as holes in bulkheads not being tapped, turnbuckles not being threaded, etc; but AE made good on everything and their customer service was great.
There are a couple things that you should correct with the car from the beginning (steering slop, ream out the arms, etc.) but those are pretty minor.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 02-09-2009, 11:55 AM   #8802
balistic's Avatar
That is a great spot, it is North Florida. I work for the California Superbike school maintaining the fleet so I get occation to tear some tires up at tracks all around the country.
It also means I get to RC all around the country durring the summer.
Old 02-09-2009, 12:03 PM   #8803
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Personally, I think the TC5 is one of the more frustrating cars to work on. I run mod and 13.5, so I have to change the pinion, spur and motor. To change the spur, you have to take out 9 screws plus the 3 in the spur. Because I have to take the top deck off, I must also put my antenna back in with each spur swap. The Xray 009 is only 4 screws, the Yokomo BD is only 2, and I believe the Cyclone is only 4. For the most part, the pinion has to be changed by taking out the motor bulkhead as the belt is in the way. In mod this is not the case because usually the pinions are small enough to fit between the belt.
Other than these above issues that I have with the car, the rest is just peachy. I find that its a very easy car to tune, with a wide sweet spot. Of course, this all depends on your setup ability.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 02-09-2009, 12:05 PM   #8804
Nice, that job rocks! JGP was were it started for me.. I knew some of those brake & apex markers were fimilar. Old Ed B. schooled me. raced wera & ccs for 3 years... Not enough $ to keep it going so got back in to RC'n.
sorry for thread jackn'. ..and I do have a TC5 related question... TIR parts in the states or realiable place in the UK to get cvds & layshaft? the stock ones at full lock..we'll most know...
www.nashrcracer.com
Old 02-09-2009, 03:31 PM   #8805
balistic's Avatar
[QUOTE=rezenclowd3;5408761]Personally, I think the TC5 is one of the more frustrating cars to work on. I run mod and 13.5, so I have to change the pinion, spur and motor. To change the spur,
QUOTE]
I bought a used Cyclone and it is 6 in the plate and two in the motor.
I have been racing Associated's exclusivly with the exception of a Slash and living in so cal and having a simular background as Mr Lett I was already leaning twords the TC5R. I just like or know the way they put stuff togeather.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
