Old 01-25-2009, 04:49 PM   #8596
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Thanks Ill try that...when I tightened them down I thought the same thing...whats the point?
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 01-25-2009, 04:54 PM   #8597
Trader Rating: 49 (100%+)
more chassis flex i am sure..
cleblanc is offline   Reply With Quote
Old 01-25-2009, 05:21 PM   #8598
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by GTSSTANG View Post
I need some help. I'm experiencing some torque steer on my TC5. On hard acceleration it quickly pulls to the left for the first couple feet and then straightens right out.
I am running a spool up front and diff in the rear.
I took it all apart and found a bad rear hub bearing, yet it still has the same problem with the new bearing. I even put in a new rear diff and still the same problem.
I do not think it is an issue with the front of the car as it has a spool and the bone blades are intact.
Anyone have any suggestions???
check and make sure ur car is balanced side to side
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-25-2009, 05:34 PM   #8599
Jsaves's Avatar
Josh,
I was looking over the rear toe at the bulkhead and you have .8 on the FR and 3.4 on the RR. Am I missing something because that does not seem like 3 total toe for the rear.
The car is loose off power when I enter the turn.
Thanks for your help.
God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 01-25-2009, 05:40 PM   #8600
Scottrik's Avatar
Trader Rating: 241 (100%+)
Hey Nick,
I'm very interested in your bulkheads, but have a few questions/suggestions.
I REALLY like the idea of moving the motor inboard and had been curious why Associated had not done this on the car...in fact they went to additional effort/expense NOT to. I'm guessing you run the pinion "backward" like on off-road cars? Any chance of getting a pic with a motor installed in your demo without the top plate installed and with the top plate installed so we can get the flavor of what we're facing?
At first I'd wondered "why not just get the left side plate" until I looked more carefully and saw that the layshaft bearings are now carried directly in the bulkhead and a fair bit lower than standard. So much for that thought It looks like the layshaft is carried about 3-ish mm lower (like the Exotek carriers X2)? This, obviously, cuts spur clearance on larger sizes (and my not really be relevant anyway depending)...any idea what the largest spur size that will fit with your mods?
How is belt tension affected by carrying the layshaft lower? Exotek claims a modest reduction in tension and would imagine that tension would be further reduced if you're parts are carrying it directly lower than it's current position.
I can see you've milled the chassis on the inboard side under the motor--is that done to the same depth as the standard AE milling on the outer "tab" of the chassis or have you taken both down thinner?
I must confess to not being wild about not having the "leg" in the bulkhead ahead of the motor to screw down to the chassis. I can see on your mule that at one point you must have because the chassis has been drilled where the new screw would go to pick up this leg. Correct me if I'm mistaken, but my guess is the leg was eliminated to users wouldn't have to locate, drill and countersink a hole (whose location is critical to proper fit) in their chassis. All the other screws appear to be as-located by AE. I would offer that if you made a paper template from your "mule" chassis shown that identified where the screw would live that customers could hit this easily enough. OR...I'd bet you could pick up chassis plates at dealer cost somewhere, drill and countersink them, and offer them as an extra cost option for users who lack the confidence to do that drilling.
I can imagine that the top plate provides enough bridge to keep longitudinal flex under control without this leg, but I am not at all crazy about the mass of the motor being so unsupported. It is hanging clear out ahead of the screws. My concern would be that in a hard side impact the mass of the motor could pretty easily bend the bulkhead, inertia being what it is. I've seen similar thickness 1/12 bulkheads bent due to the motor mass and they're supported all the way around and fairly close to the motor.
If you guys were to go back to (and I'm certain it was there at least at some point in development) the forward leg ahead of the motor I'd be ALL over these bulkheads, as it is I have substantial concern on this point. You'd still be "losing" the rear foot from the original AE motor mount, I just think too big a bite has been taken by eliminating that front foot.
I look forward to your responses. I think you guys are just THIS close to having a great product that I wouldn't hesitate to purchase.
Thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 01-25-2009, 06:19 PM   #8601
Send a message via MSN to Adim_X
What size bearings are you guys using in the hubs? The manual call for 6x10x4 however that size is not available from avid or amain, do I have to buy the associated ones? The only thing I can find is 6x10x3
Adim_X is offline   Reply With Quote
Old 01-25-2009, 06:22 PM   #8602
Suspended
All questions about the bulkheads have being answered to the best of my ability, in which some areas I am lacking somewhat.
I am speaking to the designer/machiner of the bulkheads tomorrow so will get everybody's questions answered and replyed to ASAP.
Thanks Nick
Nick Priest is offline   Reply With Quote
Old 01-25-2009, 06:26 PM   #8603
mr crum's Avatar
use the 6x10x3 and a half mm shim on both sides
TEAM B.R. RACING
Old 01-25-2009, 06:50 PM   #8604
Trader Rating: 68 (100%+)
Nick will these bulkheads come anodized?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 01-25-2009, 07:01 PM   #8605
Suspended
Hi steve, I'm sure they could be anodised but obviously at extra cost.
The cheaper option for you would be to have them anodised over in oklahoma as England is going through a very expensive phase at the moment unfortunatly
Cheers Nick
Old 01-25-2009, 08:05 PM   #8606
Ivan Dickson's Avatar
Trader Rating: 9 (91%+)
Post
I'm looking to get the Tc5 is it good straight out the box no need for upgrades....
SPECIAL THANKS TO ✦ MY WIFE ✦✦ GLOBAL PRIVATE FUNDING ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-25-2009, 08:25 PM   #8607
carbon madness's Avatar
The size in the manual is a misprint, the correct size is 6x10x3.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 01-26-2009, 02:23 AM   #8608
berserk's Avatar
does anyone have a good low grip asphalt rubber setup? thanks!
berserk is offline   Reply With Quote
Old 01-26-2009, 03:09 AM   #8609
mr crum's Avatar
get the tc5r and ur ready to go
TEAM B.R. RACING
Old 01-26-2009, 04:40 AM   #8610
Suspended
Originally Posted by Jsaves View Post
Josh,
God Bless
i too had that problem...went to 1degree shm in front and 4 in rear..for a total of 3 degree toe..made a huge difference..car was glued
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
