Old 01-21-2009, 12:00 PM   #8536
Trader Rating: 3 (80%+)
does anyone know if Keven is running the foam inserts in his shocks?
ryan sparks is offline   Reply With Quote
Old 01-21-2009, 12:40 PM   #8537
racer x 1's Avatar
Trader Rating: 27 (100%+)
anyone know the recommended fdr when running a bl lrp 4.0? will be running on a large asphalt track
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-21-2009, 03:16 PM   #8538
Truck_Buster's Avatar
Trader Rating: 63 (98%+)
I have a question about the spool assembling. In the manual it shows the diff nut and the 2 washers but no bearings. Is that correct and also when putting the pads in do you still use the bearings or not?
Losi 8ight 2.0
Truck_Buster is offline   Reply With Quote
Old 01-21-2009, 03:35 PM   #8539
AE-Reedy
No diff balls , thrust balls are optional.
Sean Cochran is offline   Reply With Quote
Old 01-21-2009, 04:19 PM   #8540
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Are the thrust balls for the slipper spool included in the kit?
brians11 is offline   Reply With Quote
Old 01-21-2009, 04:39 PM   #8541
Bruce Grembowski's Avatar
Originally Posted by markg View Post
One of the problems I've had is finding 48p pinions that big. I find them up to about 35 and no larger. Anyone know of a source for large 48p pinions?
This would be so much easier if there was an option for center pulley to go from a 20t to a 23t, but guess that means there would be a problem with belt length...
Thanks for the feedback...
I "solved" this issue by going to a smaller spur gear, a 69T. This lets me run pinions from 32T through 36T. These give the following FDR's:
36T 3.83
35T 3.94
34T 4.06
33T 4.18
32T 4.31
These values work fine for indoor carpet with a 17.5BL motor. I tried running a 13.5, but even with the 32T pinion, I was geared too high, so I would've had to go to a 72T or 75T spur.
FYI, I got the 36T pinion from my LHS, RC+ in Salem, OR.
If you can't wait for your LHS to order them, you could try Stormer Hobbies. They have Robinson Racing black aluminum pro pinions in 48P from 37T to 47T in odd sizes, in stock:
https://www.ssl-stormerhobbies.com/c...=ns&pn=RRP1337
HTH,
Grem
Bruce Grembowski, ROAR #11-115675
Rose City Scale Racing (http://www.rosecityscaleracing.com)
Bruce Grembowski is offline   Reply With Quote
Old 01-21-2009, 04:41 PM   #8542
mr crum's Avatar
Send a message via Yahoo to mr crum
use the thrust bearing or it will loosen up trust me u will thank me later build it like a diff but put the pads instead of diff plates and no diff balls
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-21-2009, 04:47 PM   #8543
Trader Rating: 68 (100%+)
yes it basically comes to be able to build 2 diffs with the option to make a spool.
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 01-21-2009, 04:53 PM   #8544
thanks, you're the man
Old 01-21-2009, 04:54 PM   #8545
No you are,got a car coming?and i learned you need to run the thrust balls to keep the spool from backing off
SpeedZone Batteries
Old 01-21-2009, 04:58 PM   #8546
not yet, i'll be out of commission for a couple weeks
Old 01-21-2009, 05:08 PM   #8547
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Don't forget to put a little lock tight on it as well for double protection.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-21-2009, 07:34 PM   #8548
Grem and others - Thanks for the replies. Found pinions and spurs at horizon. They have teh 72t spur and odd size pinions up to about 47t, which should get me there. Appreciate the help.
Going to be perusing the posts to catch up on advice for setups and such. Need to find a couple of tenths per lap - dont we all
markg is offline   Reply With Quote
Old 01-21-2009, 08:41 PM   #8549
Hey Guys - have gone way back in posts but didn't see what I needed. Has anyone posted a good TC5R setup for running 17.5 stock, rubber tires, on med bite asphalt track? Generally using RP36 tires that work well on our track unless its really cold, then we run CS22. The box setup was pretty good, but need to find a little more mid and exit corner speed. Thanks for any replies.
Old 01-22-2009, 01:48 AM   #8550
treemagnet's Avatar
Trader Rating: 17 (100%+)
Default stuff
hey everyone.
i need some advice on an idea. i broke my last dog bone blade 2day and prob wont have any for my race this sunday. so i cant use my spool. wat bout if i take the diff with the plastic outdrives, remove the balls and put some superglue in there and tighten it up. hey presto! a spool think this will work? im thinking the plastic outdrives might break or bend but i only race 540 class so should be ok
thanks treemagnet
treemagnet is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
