Old 01-18-2009, 07:00 PM   #8521
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
Thanks cdee.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 01-19-2009, 02:47 PM   #8522
speedsterblade's Avatar
Originally Posted by trdsupra88 View Post
I hate to ask a ton of questions but what are a few pros and cons of using straps and tape? What type of tape is generally used?
It's battery tape similar to the some packing tape w/ strong fibers running the length of the tape so it doesn't stretch much. LHS should have or be able to get some. I used it at first cause it was lighter than posts and straps. Now w/ lipos it can be used where the straps don't fit right. cons can be it can rub and get cut if you don't sand/smooth the chassis edges. Also the battery can shift if you don't get tight.
I also used it to tape a half of front bumper for some protection on the exposed side of my lipo.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 01-19-2009, 03:48 PM   #8523
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
thanks...I have been thinking of putting the battery posts from the B44 behind where actual battery post mount and use washers or lead wieghts with holes to easily adjust the weight balance...if I do, I will post pics...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 01-19-2009, 04:24 PM   #8524
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
To help secure the lipo from moving around you could also glue weights along the outer edge of the battery. I had about 3 that I glued down the center of the chassis to keep the battery from sliding into the belt.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-19-2009, 04:55 PM   #8525
mr crum's Avatar
Send a message via Yahoo to mr crum
if u guys have acces to a cnc machine i found a guy local that machined me a batterry tray out of never rott pvc lumber u can get at home depot it works beautifully i can post a pic if u guys are interested
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-19-2009, 06:49 PM   #8526
Go for it
i want to see that
revolver1 is offline   Reply With Quote
Old 01-19-2009, 07:20 PM   #8527
Trader Rating: 24 (100%+)
i thought i read somewhere you guys were having problems with the stock wheel nuts coming loose.
what is the alternative you guys came up with.
vic0280 is offline   Reply With Quote
Old 01-19-2009, 07:41 PM   #8528
RichyRich's Avatar
Default 5200 lipo battery for TC5
I use a EP 5200 with a lipo plate on my TC5 and it works great. There is just enough clearance to get the battery in and out and you have to pull the balance wire through but otherwise it's good to go. You use the factory strap to hold the battery down and don't over tighten the thumb screw's or you will tweak the chassis.
RichyRich is online now   Reply With Quote
Old 01-19-2009, 11:17 PM   #8529
artica's Avatar
Originally Posted by jag88 View Post
I know Cyclone and Xray still offer them. Apparently AE doesn't feel the need.
Any thoughts on whether or not they would fiton a tc5? even with a litltle bit of help?
artica is offline   Reply With Quote
Old 01-20-2009, 04:34 AM   #8530
Trader Rating: 17 (100%+)
Smile
Hey there, have had TC5 for a few months now , had problems with the rear end stepping out, searched through this thread and found the answers, raced last weekend at our local track, car was awesome, TQ'd and won the day, thanks to all for the input.
lethallee69 is offline   Reply With Quote
Old 01-20-2009, 06:53 AM   #8531
jag88's Avatar
I don't think so pully size, shaft diameter are different ...... but then again, never say never !
jag88 is offline   Reply With Quote
Old 01-20-2009, 04:50 PM   #8532
Trader Rating: 3 (80%+)
What overall shock length is being ran on the car?
I ask because I apperently arent running enough because at full travel its about the right droop that keven suggested to start at. any help would be great.
ryan sparks is offline   Reply With Quote
Old 01-21-2009, 09:03 AM   #8533
Default Stock Gearing
Hey Guys - Sorry if this is posted previously. Went back a number of pages but didn't see anything. I'm running the TC5R on asphalt, and we are going to racing stock (17.5 Brushless). Gearing on this motor is in the rage of FDR 3.5. Anyone have any suggestions on spur pinion combination that will achieve this FDR? Can the center pulley be changed to a larger one so the Spur/pinion sizes aren't so ridiculous?
I've found spur pinion combos in 64p that will work, barely, but nothing in 48p. Any suggestions greatly appreciated.
Thanks for any help. We were racing 10.5 and just switched, and I'm having a hard time finding sources for spur/pinion to get a 3.5 fdr.
markg is offline   Reply With Quote
Old 01-21-2009, 09:26 AM   #8534
revo61's Avatar
Trader Rating: 18 (95%+)
Look at gearchart.com I think 40/70 will work if you can find a pinion that big.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 01-21-2009, 09:35 AM   #8535
One of the problems I've had is finding 48p pinions that big. I find them up to about 35 and no larger. Anyone know of a source for large 48p pinions?
This would be so much easier if there was an option for center pulley to go from a 20t to a 23t, but guess that means there would be a problem with belt length...
Thanks for the feedback...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
