Old 01-14-2009, 01:28 PM   #8446
Originally Posted by revolver1 View Post
Could someone tell me what side of car you tight differentiel on tc5
i know its not clear ,i am a french man lolll, i rebuild my differentiel
and now what side it goes ?? it is important ??
tx Stef
no body know
revolver1 is offline   Reply With Quote
Old 01-14-2009, 01:54 PM   #8447
Gone Racin's Avatar
Default diff
Hello, the bolt goes on the right side.looking from the rear of the car.it also goes trough the short side of the diffs houseing hope this helps
Gone Racin is offline   Reply With Quote
Old 01-14-2009, 02:21 PM   #8448
stegger's Avatar
Total newb question on the TC5, i will be picking up an TC5 FT in the next few days. What mods if any or build tips do people recommend i will be running the car as a carpet/foam setup with brushless/Lipo. Thanks didn't want to go through 282 pages to find the answers. lol
stegger is offline   Reply With Quote
Old 01-14-2009, 03:24 PM   #8449
Maybell's Avatar
If you are getting a regular TC5FT, it comes with a foam setup and all the things you need for foam racing to get you started...
Try the hard suspension parts and the aluminum diffs when you wear out the stock ones.
If you get the TC5F kit it comes with that stuff...
For brushless lipo if you are going to run spec motors, get check out the PPD balast system and get some small spur gears and BIG pinions...sizes in the area of 74-79 spur and 33-36 pinion at 48pitch.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-14-2009, 03:41 PM   #8450
Tx
Old 01-14-2009, 05:48 PM   #8451
Trader Rating: 49 (100%+)
what is the best thing to use to remove glue, as in the glue from the double sided tape used to hold in the esc and receiver? thanks
cleblanc is offline   Reply With Quote
Old 01-14-2009, 05:54 PM   #8452
mike nelson's Avatar
If its really stuck on I put traction compound on it let it soak in for several minutes and it usually breaks it down where you can just wipe it off. Motor spray works also, just let it soak in for a couple minutes
TEAM ASSOCIATED--NOVAK--J-CONCEPTS--REEDY--LEISURE HOURS HOBBIES--FUTABA--COMPETITION ELECTRONICS--UP-GRADE RC--TRAKPOWER--
mike nelson is offline   Reply With Quote
Old 01-14-2009, 06:14 PM   #8453
katfish317's Avatar
Goo Be gone, but usually I can just scrape it off with my finger nail.
katfish317 is offline   Reply With Quote
Old 01-14-2009, 06:16 PM   #8454
katfish317's Avatar
Originally Posted by jag88 View Post
Rick Hohwart, any plans on some new cvds and axles that actually fit the bearings ?
Current axles have to small a dia. and therefore create slop.
Thanks.
I got the world cvd's and they are great, no slop at all, they cost a little more, but they are well worth it as they really free up the drive train and do not bind under full lock. Larger bearing in the hubs would be nice too though!
Old 01-14-2009, 06:23 PM   #8455
Originally Posted by mikel33 View Post
http://www.ppdbillet.com/ - link to the plate I used. I don't use the side plate, that's too much weight.
http://www.corallyusa.com/istar.asp?a=6&id=SRC79867!SRC - battery tray
so you use both of these together correct? if so do they mesh well? and also, do you still have to add lead weight anywheres?
Old 01-14-2009, 06:26 PM   #8456
thanks fellas
Old 01-14-2009, 06:28 PM   #8457
cutjo3's Avatar
They mesh together perfectly. The Specialized RC tray has a cutout that seems to be made for weight plates. I haven't added any other weight yet with the lipo mounted in the outermost position.
Current Rides
MGT 8.0
Old school RC10
Old School Losi JRx Pro
Previous Rides: B44, RC18MT, RDX PHI, FT RC18T, RC8, TC5(2), RC8T :(
cutjo3 is offline   Reply With Quote
Old 01-14-2009, 07:01 PM   #8458
thats some of the best news i have heard. i'll be ordering both shortly!! i hate the look of those lead weights. well worth the money to me!!
thanks
Old 01-14-2009, 07:04 PM   #8459
Jim S's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to Jim S
what is the difference between a spool and a oneway
Jim S is offline   Reply With Quote
Old 01-14-2009, 07:17 PM   #8460
mr crum's Avatar
Send a message via Yahoo to mr crum
a spool is a solid front axle and a one way is solid on power and free wheel during braking
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
